tipine9824 Posted October 7, 2022 Share Posted October 7, 2022 Hello. I need to set a low level on a gpio pin PA6 on boot. I'm trying to do this through the device tree: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { pinctrl-0 = <&pull_pins>; pull_pins:pull_pins { pins = "PA6"; function = "gpio_out"; bias-disable; output-low; }; }; }; }; I need to set PA6 to low. After boot, I see my overlay in device tree, but the level on the PA6 is still high. I can easily control the level through libgpiod (gpioset gpiochip0 6=1 or gpioset gpiochip0 6=0), it works. But I can't set low level at start. Full device tree - https://pastebin.com/dQKSYXjL What am I doing wrong? 0 Quote Link to comment Share on other sites More sharing options...
