nikolas Posted October 28, 2022 Share Posted October 28, 2022 hi there! i am not a developer, just a linux user. is there an easy guide installing and using with armbian rtl8822cs wifi and bt module? 0 Quote Link to comment Share on other sites More sharing options...
0 NicoD Posted October 28, 2022 Share Posted October 28, 2022 @nikolas I think this should do it. https://www.5288z.com/3071.html Next time also mention what image you are using and what board. It doesn't matter that much here, but the more info you give us the better we can help. 0 Quote Link to comment Share on other sites More sharing options...
0 Igor Posted October 29, 2022 Share Posted October 29, 2022 20 hours ago, nikolas said: i am not a developer, just a linux user. Welcome. Not a problem. Just without your input, developers usually have no idea what you are talking about. 20 hours ago, nikolas said: is there an easy guide installing and using with armbian rtl8822cs wifi and bt module? It should work OOB unless you are using one of the first builds. Try one of automated test image - if that works - for start. 0 Quote Link to comment Share on other sites More sharing options...
0 nikolas Posted October 31, 2022 Author Share Posted October 31, 2022 Welcome to Armbian 22.08.8 Bullseye with bleeding edge Linux 5.19.16-meson64 System load: 2% Up time: 37 min Memory usage: 5% of 3.70G IP: 192.168.1.111 CPU temp: 41°C Usage of /: 23% of 15G RX today: 4.1 GiB [ General system configuration (beta): armbian-config ] Last login: Mon Oct 31 12:09:47 2022 from 192.168.1.110 nikolas@bananapim5:~$ sudo modprobe 88x2cs [sudo] password for nikolas: nikolas@bananapim5:~$ sudo iwconfig lo no wireless extensions. eth0 no wireless extensions. i did a modprobe 88x2cs , seems the driver is in the kernel and up ... but iwconfig fails 0 Quote Link to comment Share on other sites More sharing options...
0 Werner Posted October 31, 2022 Share Posted October 31, 2022 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote Link to comment Share on other sites More sharing options...
0 nikolas Posted October 31, 2022 Author Share Posted October 31, 2022 armbianmonitor -u System diagnosis information will now be uploaded to Network/firewall problem detected. Trying fallback... Network/firewall problem detected. Not able to upload debug info. Please fix this or use "-U" instead and upload whole output manually to an online pasteboard service and provide the URL in the forum where you have been asked for this. armbian monitor.txt 0 Quote Link to comment Share on other sites More sharing options...
0 nikolas Posted October 31, 2022 Author Share Posted October 31, 2022 there are to many lines as output. Cannot paste them all. 0 Quote Link to comment Share on other sites More sharing options...
0 Kaffu Theine Posted December 26, 2022 Share Posted December 26, 2022 Hello @nikolas, if you still looking for a driver try my source from my git repo https://codeberg.org/Hiyurigi/rtl88x2cs feel free to submit a issue if you have an issue with my source 0 Quote Link to comment Share on other sites More sharing options...
0 SteeMan Posted December 26, 2022 Share Posted December 26, 2022 On 10/29/2022 at 12:46 PM, Igor said: It should work OOB This user is running meson64-edge. This module is not enabled in that kernel, but is in meson64-current and most other kernels. Is there a reason, or it this just a bug/mistake? Should I submit a PR to enable? 0 Quote Link to comment Share on other sites More sharing options...
0 Igor Posted December 26, 2022 Share Posted December 26, 2022 1 hour ago, SteeMan said: Should I submit a PR to enable? Try build check to check if its 6.1.y ready. If it builds, open PR. 0 Quote Link to comment Share on other sites More sharing options...
Question
nikolas
hi there!
Link to comment
9 answers to this question
