ARMBIAN for Amlogic S905 and S905X (ver 5.44 =<)
balbes150
Image update 20170302. Now, all the images should work the procedure for installing to the internal memory. To use setup, you must consider a number of nuances. 1. Before installation we strongly recommend to do a full backup of the internal memory (e.g. team dd_backup_x) and move the copy to another storage medium (e.g. on a PC). 2. Be sure to check all devices (wifi, sound etc etch). 3. If all the required works when run from external media, you can start the installation. To start the terminal. To switch to the superuser "root" to execute the command "su -" (su "space", "minus"). Run as root the command "./install.sh" . The procedure is not fast, as there is a complete copy of the operating system from external media in memory (eMMC). Notice for owners of TV boxes with 8 GB of eMMC. When you install the desktop versions (MATE and XFCE) TO START the installation, optimize system. To reduce the amount of programs installed for example to uninstall office packages. What would be the size occupied by the system on external drive was less of the size of the internal memory (partition /dev/data). By default , desktop take more seats than the existing partition in the internal memory (/dev/data). Therefore, the system will fail to start.
@balbes150
this is a mightyfine piece of work here :-) really seems like you've gotten the bugs out. so im on  debian desktop 20170228. typeing from the a95x now i've got system up time over 3 hours and my cpu temp is steady at 57c  this image seems to work very well and ive allready updated and installed other packages etc.
     so , QUESTION =  since im not overly concerned with the emmc install is there a big difference between  20170228 and the 20170302 images ?
also i'm wanting very much to learn how this is built as I want to try to port Kali and parrotsecurity os to this platform. Can you give me any pointers tips or tricks ? is there a  a general tutorial/guide for this type of thing ? can you tell me what the major differences between the a95x-s0905x and Odroid c2 platforms are ? i found a pre rolled img for Odroid c2 that id like to port to the nexbox would they be close to compatable?
thanks very much for your time and effort in this project , you've given my silly android box new purpose,
and given me inspiration.
Cheers
Astr4y4l
@Tieu Vinh Long
hi , i've done some modification for cooling but can't decide between liquid coolant or air-injection ,
i've some ideas  to discuss is there a way to private message me so as not to clutter the forum with off-topic posts?
and do you have a place to upload pictures of the modifications i'm makeing?
New image (dir Test 20170303) correction module mali. Checked on S905X - everything works, the temperature is over 70 degrees, the system is not falling. Please check at home. Please check the work WiFi network.
Hello!
I installed Armbian_5.26_S9xxx_Ubuntu_xenial_3.14.29_server_20170303.img to a generic S905x tv box that calls itself a 'QcoCe Z11' and it almost works perfectly.
My main issue is I am only getting audio from the HDMI out, not from the analog outputs I am using for speakers around the house. This is what I get from aplay -l and -L
**** List of PLAYBACK Hardware Devices ****
card 0: AMLM8AUDIO [AML-M8AUDIO], device 0: I2S.39 T9015-audio-hifi-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: AMLM8AUDIO [AML-M8AUDIO], device 1: SPDIF.40 dit-hifi-1 []
  Subdevices: 1/1
card 0: AMLM8AUDIO [AML-M8AUDIO], device 2: PCM.41 pcm2bt-pcm-2 []
  Subdevices: 1/1
sysdefault:CARD=AMLM8AUDIO
    AML-M8AUDIO,
    Default Audio Device
dmix:CARD=AMLM8AUDIO,DEV=0
    AML-M8AUDIO,
    Direct sample mixing device
dmix:CARD=AMLM8AUDIO,DEV=1
    AML-M8AUDIO,
dmix:CARD=AMLM8AUDIO,DEV=2
    AML-M8AUDIO,
dsnoop:CARD=AMLM8AUDIO,DEV=0
    AML-M8AUDIO,
    Direct sample snooping device
dsnoop:CARD=AMLM8AUDIO,DEV=1
    AML-M8AUDIO,
dsnoop:CARD=AMLM8AUDIO,DEV=2
    AML-M8AUDIO,
hw:CARD=AMLM8AUDIO,DEV=0
    AML-M8AUDIO,
    Direct hardware device without any conversions
hw:CARD=AMLM8AUDIO,DEV=1
    AML-M8AUDIO,
hw:CARD=AMLM8AUDIO,DEV=2
    AML-M8AUDIO,
plughw:CARD=AMLM8AUDIO,DEV=0
    AML-M8AUDIO,
    Hardware device with all software conversions
plughw:CARD=AMLM8AUDIO,DEV=1
    AML-M8AUDIO,
plughw:CARD=AMLM8AUDIO,DEV=2
    AML-M8AUDIO,
But if I run alsamixer I only have one volme control, for DAC Digital, the other outputs (audio spdif, audio i2s, ext spk) all will only allow me to mute/unmute.
Does anyone know how to enable analog audio out?
Thanks
@xXx
I have a suggestion. Make the script dd_backup_x change, what would the script check in the root of the media directory /ddbr (if not created) and put the backup in that directory. This is to ensure that when you installed to the internal memory, this directory is NOT copied to eMMC.
Well ..
latest debian xfce. And is working. The media player hung immediately.  Had to pull power plug to shutdown.  Apt-get remove --purge mpv.
Apt-get install vlc.. about to see if that works for me.. hope for success ...
Sure, i can do that.
I'm a bit short of time these days, but at some point (hopefully soon) i'll post a new script with all the changes.
17 hours ago, mmss said:
Hi, with debian on s905x hardware acceleration is working?
I haven't checked.
Then one other suggestion, add the option to create a copy of the first 3.5 GB of internal memory (not total memory). Most firmware in its original state beyond these limits. Therefore, to restore enough to make a copy of the first 3.5 GB.
The new backup/restore script is ready and tested.
Not a new script really, just some usefull additions.
Some proof here
You can download it from here
All the changes are in the script's comments as usual.
Hope it helps.
Found a small bug in the script when checking free space. If free space is less than the total size of the internal memory, the work stops. But this is not correct, to create the compressed copy can be quite much less space. While disabled interrupt the script in this parameter, there is only a warning.
If the script allow the user with less space to continue, and then the user choose uncompessed backup by mistake, the system will hang.
I could update the script to allow only compressed backup if the free is less than EMMC size, but again... you cannot predict the compessed
size of the final backup ( depends of the compressibility of user's files ) and a hang can happen again.
So i decided to leave it as is, for safety.
If someone has to take a backup, it is better to use a USB/SDCARD that have space.
On 8. 3. 2017. at 3:51 PM, mmss said:
Ah ok, I asked why test.mp4 and test1.mp4 videos are jerky...
By me, too...
Look like 16 pictures pro second, no 24...
And have not full hd, only 720p.
You tube ok, kodi not.
Temperature 70dg/c, ok, florence virtual keyboard, dont work, on tronsmart airmouse I have not - , and vithout - , have not " apt-get"...
And this is a great problem for me.
I am not a very expirienced linux user
Any help, link, anything?
Tnx.
On 10.03.2017 at 10:01 PM, Tommy21 said:
Is there a place to see changelog from your armbian images?
There are no big changes, only bug fixes.
In Debian or Ubuntu ?
19 hours ago, etona said:
By me, too...
Tnx.
These images are NOT intended for full video playback. For this is LE. Is a desktop or server system to replace conventional PCs.
What do You mean under the expression "no apt-get". The system has Synaptic for graphical package installation. apt-get also works.
@balbes150
Sorry to annoy you again, but i have a little question for you:
Do i need to have the original android firmware in my MiniM8S box for the installation to EMMC to be successful?
I tried 7 times yesterday with your latest ubuntu mate image, and although everything went well ( no errors ) the system
was not able to boot after installation. I finally manage to brick my system, and the pin sorting method was mandatory
( again :D ) in order to bring it back to life. I must tell you that every time i tried installation to EMMC, i had LibreELEC on it.
And yes, i removed many packages before attempting the installation, to a point where the used space is only 2.6G
I'm trying to run the OS from EMMC, in order to improve dd_backup_x script in every situation ;).
@everyone
Has anyone managed to successfuly install ubuntu mate to internal EMMC in MiniM8S (not II) ???
If yes, how?
