OpenMediaVault Broken :-(
Hiya, I've been using OMV for a year or two with no issues. There were several updates to Armbian and other packages recently which caused a number of errors and the system going to sleep on my Windows network and not waking up. Rather than try and track every error, I'll just start from scratch.
Last time, the OMV install from Armbian-Config worked like a dream. Load it, update it and then click OMV in the menu. Simples!
This time it runs a lot of script as before, then finishes with "error openmediavault". That's it. The web browser says "Welcome to NGINX", so something has been installed. Ive tried an install and running the Debian scrip from the OMV GITHUB and it does not like that at all. Errors in BASH immediately.
So currently hoping for updates (from Armbian I guess?). I'm using latest Bullseye and I guess Armbian-Config is trying to install V6?
Edited by dogshome
Armbian didn't make OMV. AFAIK there is no need for any special installation as used to be via armbian-config. Just check official OMV install instructions for installing over Armbian Debian. It has to be Debian, otherwise it does not work. I don't know much about OMV internals or installation ...
