donluca Posted November 24, 2022 Share Posted November 24, 2022 (edited) The board is marked as MXQ-HX-V2.0. CPU: Allwinner H3 DDR: 1GB LPDDR3 HS400 ROM: 8GB eMCP (both DDR and eMMC are on the same eMCP chip) Wi-Fi: sv6256p LAN: ?? (100Mb) Here's a picture: Before I start soldering the headers for the serial port and start debugging myself... has anyone any idea if there are compatible images among the ones already available? I've already tried: Beelink X2 Orange Pi PC Orange Pi PC + Orange Pi Zero Sunvell R69 and none of these worked. Thanks! Edited November 24, 2022 by donluca 0 Quote Link to comment Share on other sites More sharing options...
donluca Posted November 25, 2022 Author Share Posted November 25, 2022 (edited) Here's the bootlog taken from the serial port: https://pastebin.com/ctKEHm3m EDIT: ok, I basically have the same issue as this: Is there any chance a maintainer could add to the community repository a version with u-boot configured for LPDDR3 running at 336Mhz (DRAM value: 003939f9)? Edited November 25, 2022 by donluca 0 Quote Link to comment Share on other sites More sharing options...
donluca Posted November 25, 2022 Author Share Posted November 25, 2022 (edited) It seems like I'm still unable to boot, even with a custom u-boot I made, making sure that the RAM configuration is correct. Can anyone confirm that the following options are correct? CONFIG_DRAM_CLK=336 CONFIG_DRAM_ZQ=3750393 CONFIG_DRAM_TYPE=7 Those are based on the bootlog I've posted previously. I'm using the configuration for the OrangePi PC which has similar hardware. The error I get is DRAM: 0MiB Edited November 25, 2022 by donluca 0 Quote Link to comment Share on other sites More sharing options...
Backdoor Posted January 20, 2023 Share Posted January 20, 2023 Hi Donluca, have you solved? What's procedure have you do for create a u-boot + kernel + OS? bye, BD. 0 Quote Link to comment Share on other sites More sharing options...
donluca Posted January 21, 2023 Author Share Posted January 21, 2023 Sorry I didn't. In the end I just returned the item to the seller because it was different from the one listed (which was an actual MXQ Pro and not a fake one). 0 Quote Link to comment Share on other sites More sharing options...
