Wifi-Driver rtl8812
nikodemus
I try to install the package rtl8812au-dkms and it fails with:
  CC [M]  /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/core/rtw_beamforming.o
  CC [M]  /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/core/rtw_odm.o
  CC [M]  /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/core/efuse/rtw_efuse.o
  CC [M]  /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/os_dep/osdep_service.o
/var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/os_dep/osdep_service.c: In function ‘rtw_change_ifname’:
/var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/os_dep/osdep_service.c:2183:28: warning: passing argument 1 of ‘_rtw_memcpy’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
 2183 |         _rtw_memcpy(pnetdev->dev_addr, padapter->eeprompriv.mac_addr, ETH_ALEN);
/var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/os_dep/osdep_service.c:807:24: note: expected ‘void *’ but argument is of type ‘const unsigned char *’
  807 | void _rtw_memcpy(void* dst, const void* src, u32 sz)
/var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/os_dep/osdep_service.c: In function ‘rtw_random32’:
/var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/os_dep/osdep_service.c:2310:16: error: implicit declaration of function ‘prandom_u32’; did you mean ‘prandom_u32_max’? [-Werror=implicit-function-declaration]
 2310 |         return prandom_u32();
      |                prandom_u32_max
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:250: /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/os_dep/osdep_service.o] Error 1
make[1]: *** [Makefile:1992: /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-6.1.0-rc5-rk3568-odroid'
Same issue, if I try to compile the driver manually:
  CC [M]  /home/astrodroid/rtl8812au/core/efuse/rtw_efuse.o
  CC [M]  /home/astrodroid/rtl8812au/os_dep/osdep_service.o
/home/astrodroid/rtl8812au/os_dep/osdep_service.c: In function ‘rtw_random32’:
/home/astrodroid/rtl8812au/os_dep/osdep_service.c:2591:16: error: implicit declaration of function ‘prandom_u32’; did you mean ‘prandom_u32_max’? [-Werror=implicit-function-declaration]
 2591 |         return prandom_u32();
      |                prandom_u32_max
make[2]: *** [scripts/Makefile.build:250: /home/astrodroid/rtl8812au/os_dep/osdep_service.o] Error 1
make[1]: *** [Makefile:1992: /home/astrodroid/rtl8812au] Error 2
Which package I missed to be installed, that this function may be available. With the original Odroid M1 Ubuntu LTS 22.04 and Linux 5.19 this package could be installed.
Thx
You need to adjust sources that will be compatible with kernel 6.0.y If you know what needs to be done, then it looks like this: https://github.com/aircrack-ng/rtl8812au/pull/1008/files some of ours https://github.com/armbian/build/tree/master/patch/misc Can be few hours of work ...
The U-boot from hardkernel does not boot from USB when in skip_spiboot mode.
An SD-card with the hardkernel image boots fine with the wifi adapter attached, even with  skip_spiboot.
Therefore tripping over the cd-device during boot is a very specific Armbian problem.
The problem probably starts with the pre-release bootstrap, after the initial boot phase and before switching to nvme partition.
A wifi adapter which identifies itself as a cd-device is a problem in itself, of course.
With a working spiboot for the M1, it should be managable though.
Common to all modern kernel based Linux distributions that does not chain load with propriety kernel? Armbian is a build system that assembles and provide ready to run Debian like / based OS for single board computers.
Yes of course, but open source boot loader is not done yet, dunno what is the status ATM, while we decide to not provide Armbian images with proprietary vendor (Petit)boot / kernel.
I don't know if there is a solution. Only a workaround - that you use some other WiFi dongle.
