savoy Posted December 7, 2022 Share Posted December 7, 2022 I'm trying to complete the installation of Armbian onto the HC4 (HC4-P if that changes anything). With a fresh SD card I run sudo dd if=Armbian_22.11.1_Odroidhc4_bullseye_current_5.19.17.img of=/dev/sdb status=progress plug in the card to the board, plug in the ethernet cable, hold down the boot switch, and plug it into power. It all seems to run correctly: I can SSH into the board and I complete the initial steps to set-up the installation (root pass, default shell, username, real name, and locale). However it does not seem as I can access the SPI FLASH device. Running the following commands from the HC4 page do not work as there are no mtd devices. root@odroidhc4:~# ls -ltr /dev/mtd* ls: cannot access '/dev/mtd*': No such file or directory Here's a paste of the files available under /dev: https://paste.tildeverse.org/?aa94ecb514ce9e50#E5qD2kbTFiQzaHRrgnBLfMw8PMfspfVsCFrxhPATYDyi 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted December 7, 2022 Share Posted December 7, 2022 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote Link to comment Share on other sites More sharing options...
savoy Posted December 7, 2022 Author Share Posted December 7, 2022 Sorry about that! Here's the log output: https://paste.armbian.com/tezoqesuxu 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted December 7, 2022 Share Posted December 7, 2022 1 hour ago, savoy said: Running the following commands from the HC4 page do not work as there are no mtd devices. It seems that support for SPI got lost when upgrading kernel. Nothing unusual for software where maintaining is sponsored by its developers in their free time. Workaround (thank you) - previous 5.10.y kernel images from archive works well ... use it and don't upgrade (apt-mark hold linux-image* and linux-dtb*) 0 Quote Link to comment Share on other sites More sharing options...
savoy Posted December 7, 2022 Author Share Posted December 7, 2022 I used the most recent buster 5.10.12 kernel image from the archive and still seem to be getting the same issue: log output 0 Quote Link to comment Share on other sites More sharing options...
berobispo Posted January 9, 2023 Share Posted January 9, 2023 I received my new Odroid HC4 today and ran into the same problem. I used the recent armbian, but I booted into petitboot (with an attached display and keyboard), and erased the flash storage from there. This worked just fine! As far as I can tell, this has no downside when compared disabling petitboot via ssh, other than having to have a display and a keyboard. @Igor: Thank you for providing armbian!!! 1 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 9, 2023 Share Posted January 9, 2023 22 minutes ago, berobispo said: Thank you for providing armbian!!! Thank you! Impossible without help of: @Contributor/Maintainer @Moderators https://github.com/orgs/armbian/people https://github.com/armbian/build/graphs/contributors https://docs.armbian.com/Release_Board-Maintainers/ ... 2 Quote Link to comment Share on other sites More sharing options...
the78mole Posted February 12, 2023 Share Posted February 12, 2023 Hi all, i also encountered a problem getting rid of pertitboot. The button variant also works to boot into the armbian linux, but the mtd-devices are also not visible. Therefore, I tried the petitboot variant with connected monitor and keyboard, but there is nothing showing up on the screen after applying power. Fortunately, I had the official USB-serial-cable from ODROID available and could plug in it easily after opening the HC4 case. On the serial console (115200,8N1) I could execute the flash_eraseall commands. This took a few minutes especially for the /dev/mtd3. After erasing them, the board booted seamlessly into armbian. Regards, themole 0 Quote Link to comment Share on other sites More sharing options...
eacton Posted March 30, 2023 Share Posted March 30, 2023 (edited) I just set up my new HC-4 with Armbian 23.02.2 Bullseye following the instructions at https://www.armbian.com/odroid-hc4/ Unfortunately, I have exactly the same problem as themole. On the installed kernel 6.1.11-meson64, I don't see the mtd-devices. I downgraded to 5.10.16-meson64. Still no mtd-devices. I started the HC-4 without pressing the button, in the hope to apply the method "Petitboot Console Method" from the instructions. But then, nothing happens. The screen stays dark. Unlike themole, I don't have the USB-serial-cable around that I could use. So please, could you give me a hint how I can get rid of petitboot. Is there a specific kernel version I should boot? Or a specific image for the SD-card that I should use? Here is the output of armbianmonitor -u (on 6.1.11-meson64 kernel): https://paste.armbian.com/sapizoqiva Edited March 30, 2023 by eacton 0 Quote Link to comment Share on other sites More sharing options...
