After installing mesa with panthor support, I installed the usual apt command from KODI network repositories. Checked his work. Surprisingly, the interface works well and allows you to play any video in full screen without any problems. The information in KODI shows that the Panfrost G610 driver is being used. Video decoding is done by SW (there is no HW support for FFMPEG yet), but even in this mode everything works smoothly.     As a sound, I use the simplest USB sound card for $1.5
