make is broken
Go to solution Solved by gene1934,
Working on making klipper, a 3d printiing util like Marlin , work on a bpi5 running armbian, fully updated
Since the last update a day back, make has been broken. I think its now expecting windows line endings, which it won't find on a linux system.
The error message is consistent:
gene@bpi51:~/src/klipper$ make
/home/gene/src/klipper/.config:13: *** missing separator.  Stop.
Line 13 is the first non-comment line in the file.
The file uses $0A only as linefeeds, no CR's exist in it. The klipper Makefile uses file ".config" as its src of instructions:
A head -14 of that file:
gene@bpi51:~/src/klipper$ head -14 .config
# This file contains common pin mappings for MKS Robin Nano V3
# boards. To use this config, the firmware should be compiled for the
# stm32f407. When running "make menuconfig", select the 48KiB
# bootloader, and enable "USB for communication".
# The "make flash" command does not work on the MKS Robin. Instead,
# after running "make", copy the generated "out/klipper.bin" file to a
# file named "Robin_nano_v3.bin" on an SD card and then restart the
# MKS Robin with that SD card.
# See docs/Config_Reference.md for a description of parameters.
[stepper_x]
step_pin: PE3
There are two $0A's linefeeds  between the "parameters." and the "[" so even this copy/paste is broken. S/b a blank line there, and is
shown that way on screen but not here in the above paste
from hexedit of that file:
65 72 73 2E  0A 0A 5B 73  74 65 70 70  65 72 5F 78  5D 0A 73 74  65 70 5F 70  69 6E 3A 20  50 45 33 0A  ers...[stepper_x].step_pin: PE3.
So I am dead in the water until this is fixed.
Thank you
Cheers, Gene
I just did another octoprint and klipper install on another bpi5, and got the exact same error from an example .config file that had never seen a local editor.
You, SteeMan, have moved this, but you haven't indicated where to, will I still be notified of updates/replies?
7 hours ago, SteeMan said:
this is reporting issues with userspace applications
Yes.
