seif Posted January 18, 2023 Share Posted January 18, 2023 Hello armbianers ! Armbian 22.11.1 Bullseye with Linux 5.15.80-sunxi on a banana pi m1 I've connected a lipo battery to my bpi m1, and now when I try to shutdown -h 0, it ends up in a kernel panic and instead of shutting down it remains powered up. Is there anything I can do to fix that? I'd know how to shut it down talking to the axp209 via i2c, but I'm not sure how/where to put that, or if that would be or not the proper way to go. Thanks, George. 0 Quote Link to comment Share on other sites More sharing options...
seif Posted January 18, 2023 Author Share Posted January 18, 2023 Ok, never mind. I went in a loop to [ armbian-config/switch to other kernels, chose the next newer kernel, apt update && upgrade ], and after a few rounds I got to: Armbian 22.11.1 Bullseye with bleeding edge Linux 6.0.10-sunxi In which everything works as it should ! :-) shutdown -h 0 is now turning it off. Cheers, George 0 Quote Link to comment Share on other sites More sharing options...
seif Posted January 20, 2023 Author Share Posted January 20, 2023 (edited) Hello! Lemaker Banana Pi M1 Armbian 22.11.1 Bullseye with bleeding edge Linux 6.0.10-sunxi The problem with the kernel 6.0.10 is that /sys/power/axp_pmu/ is no longer there... nor anywhere else as far I know. tree /sys/power/axp_pmu/battery/ /sys/power/axp_pmu/battery/ ├── amperage ├── capacity ├── charge ├── charging ├── connected ├── power ├── ts_voltage └── voltage Any ideas why? Can I fix that? How? Thanks, George. Edited January 20, 2023 by seif 0 Quote Link to comment Share on other sites More sharing options...
