chandlerkc Posted January 29, 2023 Share Posted January 29, 2023 Hello everyone, I would like to thank @lurk101 very much for his patience in helping me how to boot Armbian directly to NVMe in my ROCK5B. I could do that with the Official release 22.11 Jammy with Gnome from the website. The PSU I am using is a dumb 5V 3A which I used to power my Raspberry Pi 4. As I could boot the OS directly from NVMe, I asked if he would mind if I shared the information with you. He answered he doesn't, so here we go... Quote For the bootloader image I used https://github.com/huazi-yg/rock5b/releases/download/rock5b/rkspi_loader.img For the Armbian image I used the current Armbian 22.11 Jammy Gnome image. Assuming you have a bootable system with NVME SSD plugged in, The first thing to do is to zero out the NVME partition table with sudo dd if=/dev/zero of=/dev/nvme0n1 count=100 power down, then boot from an SD with the downloaded Armbian image, proceed with all the setup stuff till you get to a command prompt. You then need to transfer both downloaded images to the booted system by whatever mean is available to you. I use sftp after installing ssh. Now program the SPI flash with sudo dd if=rkspi_loader.img of=/dev/mtdblock0 It will takes 3-5 minutes to program 16MB of SPI flash. Then program the NVME SSD with the Armbian image with sudo dd if=Armbian_22.11.2_Rock-5b_jammy_legacy_5.10.110_gnome_desktop.img of=/dev/nvme0n1 Shutdown, remove the SD card, power cycle. Should boot to NVME. Redo all the setup stuff. However, I was not able to use Ethernet port neither my wifi m.2 adapter, so there is no network connection... If I have more information I will share with you, thanks a lot!! 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted January 29, 2023 Share Posted January 29, 2023 split 0 Quote Link to comment Share on other sites More sharing options...
lurk101 Posted January 29, 2023 Share Posted January 29, 2023 (edited) I suspect that the Ethernet and wifi failures are because of the 5V 15 watt rpi brick. I've had no problem with my PD supply, but with NVME and Ethernet working I've noticed 1.5 A peak current draw at 12 V (18 W). This is more power than the 5V brick can supply. Edited January 29, 2023 by lurk101 0 Quote Link to comment Share on other sites More sharing options...
specs Posted January 29, 2023 Share Posted January 29, 2023 (edited) I tried to boot my system to NVMe and the result of my trying was: - powered with constant 12v1.5W (i.e. PD problems are ruled out) - bootable SD-card and NVMe or - bootable eMMC and NVMe If there is no problem with the power (PD problems should be ruled out since you use the Radxa SPI image) the bootable NVMe overrules the SD or eMMC. This means the system won't start if the partitions was not setup correctly. I think you can only try this method with an NVMe which has no boot partition already. Which means the "dd if=/dev/zero of=/dev/nvme0n1 count=100" might have to be executed with an USB-NVMe drive or something. Without bootable NVMe partition, the system might start correctly. Since my eMMC is only 32GB I will have to try to boot from NVMe, so I will try to boot the NVMe. If I have to use an USB-NVMe module I would prefer to setup the NVMe without SD or eMMC. I'll try if that works. Edit: I did see you used the method mentioned in the Radxa Wiki, this is where you probabbly found the link for the SPI image. If the SPI image fails there is allways the rkdeveloptool-option. Edited January 29, 2023 by specs 0 Quote Link to comment Share on other sites More sharing options...
buvaluy Posted January 31, 2023 Share Posted January 31, 2023 What type of m2 key would be better for OP5? Would cheap aliexpress ssd (netac kingspeck) with b+m key be good for it? 0 Quote Link to comment Share on other sites More sharing options...
linhz0hz Posted February 19, 2023 Share Posted February 19, 2023 Reporting my experience here: I successfully used this method to flash Jammy xfce/gnome provided under this link: https://stpete-mirror.armbian.com/dl/rock-5b/rc/ Wifi works, I did not test ethernet directly but it was recognized in nmcli. So maybe the problem you see is only a problem of the image you use? 0 Quote Link to comment Share on other sites More sharing options...
chandlerkc Posted February 24, 2023 Author Share Posted February 24, 2023 I was able to boot ROCK5B XFCE from this build from the community weekly release and it is working fine, with a few issues (almost all of them related to the kernel, which I know it is being solved). 0 Quote Link to comment Share on other sites More sharing options...
Zao Posted February 27, 2023 Share Posted February 27, 2023 Worked for me too, thanks! Armbian does report that my nvme is slow (after motd there is a message that my 'sdcard' is slow). 0 Quote Link to comment Share on other sites More sharing options...
HenryA Posted May 27, 2023 Share Posted May 27, 2023 Worked for me!! Thanks :) 0 Quote Link to comment Share on other sites More sharing options...
johnnyGr Posted June 7, 2023 Share Posted June 7, 2023 Will Ethernet still work after the process above on my rock rk3588 5b? 0 Quote Link to comment Share on other sites More sharing options...
tis_a_gift Posted June 10, 2023 Share Posted June 10, 2023 I have an issue with NVMe booting after following this guide and installing this image: Armbian_23.5.1_Rock-5b_jammy_legacy_5.10.160.img.xz The Rock 5B SBC now boots correctly only about 30% of the time: Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.37.2 [/usr/sbin/fsck.ext4 (1) -- /dev/nvme0n1p1] fsck.ext4 -a -C0 /dev/nvme0n1p1 /dev/nvme0n1p1: clean, 46623/3276800 files, 906832/13107200 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. and when it fails, it does so with this error message: Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! /dev/mmcblk0p1 does not exist. Dropping to a shell! Is anyone else having the same behavior? Could it be the power supply even if no boot loop is actually occurring? My NVMe is a 1TB Samsung 980 Pro. Thx. 0 Quote Link to comment Share on other sites More sharing options...
tis_a_gift Posted June 11, 2023 Share Posted June 11, 2023 An update to my own post. There are two issues going on with the spi image: 1) the Rock 5B fails to boot and hangs inefinetly here: ... WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 this happens when rebooting from a previous successful boot. 2) the Rock 5B fails to boot since it cannot find the root file system on the NVMe (see my previous post) Now, I've tested the following two spi images: image1) /usr/lib/linux-u-boot-legacy-rock-5b_23.02.2_arm64/rkspi_loader.img which can be found in Armbian_23.5.1_Rock-5b_jammy_legacy_5.10.160.img.xz image2) https://github.com/huazi-yg/rock5b/releases/download/rock5b/rkspi_loader.img which can be downloaded from the web My findings are: With image2, the Rock 5B always boots fine when powering up the board by plugging in the power supply and always fails to reboot when rebooting the board using the reboot command. With image1, the Rock 5B rarely fails to reboot (issue 1 rarely occurs) and often fails to reboot or boot (issue 2 occurs quite often i.e. ~70% of the time). 0 Quote Link to comment Share on other sites More sharing options...
