n3o Posted February 18, 2023 Share Posted February 18, 2023 Hi to all, I'm new to this thread, even if it's a little off-topic, somebody can tell me if I can update acestream arm v7 from here https://github.com/sshmanko/acestream-armv7 with shared object files (.so) taken from apk on google play (armeabi v7a)? I have already tried to install apk for android tv and it's work, but now I want switch to armbian. 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted February 18, 2023 Share Posted February 18, 2023 Moved to a more appropriate subforum 0 Quote Link to comment Share on other sites More sharing options...
WarHawk_AVG Posted February 19, 2023 Share Posted February 19, 2023 (edited) From your initial link...installed and working on my Orange Pi PC just fine https://github.com/sshmanko/acestream-armv7 Just follow the howto just git clone https://github.com/sshmanko/acestream-armv7 Then cd into the directory it created modify the .conf file with username/password then run the .start file and it comes right up Edited February 19, 2023 by WarHawk_AVG 0 Quote Link to comment Share on other sites More sharing options...
n3o Posted February 19, 2023 Author Share Posted February 19, 2023 Yes, but the core files has changed.... so to be sure that all works fine isn't better make an update (or try to make an update)? You have checked that acestream start and working, but what does it happen if there are circustances or issues that are fixed in the last build of apk play store? the current build of github have that issues. Hope that I'm clear about want tell. 0 Quote Link to comment Share on other sites More sharing options...
n3o Posted February 20, 2023 Author Share Posted February 20, 2023 On 2/19/2023 at 5:07 PM, WarHawk_AVG said: From your initial link...installed and working on my Orange Pi PC just fine https://github.com/sshmanko/acestream-armv7 Just follow the howto just git clone https://github.com/sshmanko/acestream-armv7 Then cd into the directory it created modify the .conf file with username/password then run the .start file and it comes right up can You make a test to check if work? I'm rooting a rk3229 and I will choose if install a firmware with androidtv or a firmware with armbian 0 Quote Link to comment Share on other sites More sharing options...
WarHawk_AVG Posted February 21, 2023 Share Posted February 21, 2023 Have no clue how to use it...I just know it starts and I get the webgui 0 Quote Link to comment Share on other sites More sharing options...
n3o Posted February 21, 2023 Author Share Posted February 21, 2023 (edited) 11 hours ago, WarHawk_AVG said: Have no clue how to use it...I just know it starts and I get the webgui please, make a backup of acestream arm-v7l, overwrite the original files with .so library getted from apk (not all, only the core libraries necessary), and test if work Edited February 21, 2023 by n3o 0 Quote Link to comment Share on other sites More sharing options...
