MICE Posted October 28, 2016 Share Posted October 28, 2016 did a clean install of Armbian_5.21_Odroidc2_Debian_jessie_3.14.79.img when i today apt-get upgrade to Armbian 5.23 the same problem occured on the eMMC after rebooting the system 2 times. did the same install on a micro-sd card 1 UHS no problem :S it appears to happen every time on a Armbian version upgrade. Please HELP! upgrade log eMMC: apt-get upgradeReading package lists... DoneBuilding dependency treeReading state information... DoneCalculating upgrade... DoneThe following packages will be upgraded: armbian-firmware hostapd linux-dtb-odroidc2 linux-headers-odroidc2 linux-image-odroidc2 linux-jessie-root-odroidc2 linux-u-boot-odroidc2-default sunxi-tools tzdata9 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.Need to get 0 B/23.0 MB of archives.After this operation, 73.7 kB of additional disk space will be used.Do you want to continue? [Y/n]Preconfiguring packages ...(Reading database ... 57040 files and directories currently installed.)Preparing to unpack .../tzdata_2016h-0+deb8u1_all.deb ...Unpacking tzdata (2016h-0+deb8u1) over (2016f-0+deb8u1) ...Setting up tzdata (2016h-0+deb8u1) ...Current default time zone: 'Europe/Amsterdam'Local time is now: Thu Oct 27 08:31:27 CEST 2016.Universal Time is now: Thu Oct 27 06:31:27 UTC 2016.Run 'dpkg-reconfigure tzdata' if you wish to change it.(Reading database ... 57043 files and directories currently installed.)Preparing to unpack .../armbian-firmware_5.22_arm64.deb ...Unpacking armbian-firmware (5.22) over (5.21) ...Preparing to unpack .../hostapd_1%3a2.5~armbian5.23+1_arm64.deb ...Unpacking hostapd (1:2.5~armbian5.23+1) over (1:2.5~armbian5.21+1) ...Preparing to unpack .../linux-dtb-odroidc2_5.23_arm64.deb ...Unpacking linux-dtb-odroidc2 (5.23) over (5.21) ...Preparing to unpack .../linux-headers-odroidc2_5.23_arm64.deb ...Unpacking linux-headers-odroidc2 (5.23) over (5.21) ...Preparing to unpack .../linux-image-odroidc2_5.23_arm64.deb .../etc/kernel/preinst.d/initramfs-cleanup: 17: /etc/kernel/preinst.d/initramfs-cleanup: linux-version: not foundUnpacking linux-image-odroidc2 (5.23) over (5.21) ...Preparing to unpack .../linux-jessie-root-odroidc2_5.23_arm64.deb ...Adding 'diversion of /etc/mpv/mpv.conf to /etc/mpv/mpv-dist.conf by linux-jessie-root-odroidc2'Unpacking linux-jessie-root-odroidc2 (5.23) over (5.21) ...Preparing to unpack .../linux-u-boot-odroidc2-default_5.23_arm64.deb ...Unpacking linux-u-boot-odroidc2-default (5.23) over (5.21) ...Preparing to unpack .../sunxi-tools_1.3-1~armbian5.23+1_arm64.deb ...Unpacking sunxi-tools (1.3-1~armbian5.23+1) over (1.3-1~armbian5.21+1) ...Processing triggers for systemd (215-17+deb8u5) ...Processing triggers for man-db (2.7.0.2-5) ...Processing triggers for initramfs-tools (0.120+deb8u2) ...ln: failed to create hard link ‘/boot/initrd.img-3.14.79-odroidc2.dpkg-bak’ => ‘/boot/initrd.img-3.14.79-odroidc2’: Operation not permittedupdate-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2Setting up armbian-firmware (5.22) ...Setting up hostapd (1:2.5~armbian5.23+1) ...Setting up linux-dtb-odroidc2 (5.23) ...Setting up linux-headers-odroidc2 (5.23) ...Compiling headers - please wait ...Setting up linux-image-odroidc2 (5.23) ...update-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2Setting up linux-jessie-root-odroidc2 (5.23) ...Setting up linux-u-boot-odroidc2-default (5.23) ...Updating u-boot on device /dev/mmcblk0Setting up sunxi-tools (1.3-1~armbian5.23+1) ...Processing triggers for initramfs-tools (0.120+deb8u2) ...ln: failed to create hard link ‘/boot/initrd.img-3.14.79-odroidc2.dpkg-bak’ => ‘/boot/initrd.img-3.14.79-odroidc2’: Operation not permittedupdate-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2 Link to comment Share on other sites More sharing options...
Igor Posted October 28, 2016 Share Posted October 28, 2016 I repeat this and found no problems. Can you show a content of your boot partition? Link to comment Share on other sites More sharing options...
MICE Posted October 28, 2016 Author Share Posted October 28, 2016 drwxr-x---+ 5 root root 4096 Oct 28 15:10 ../-rw-r--r-- 1 ice ice 6944 Oct 7 11:28 boot.bmp-rw-r--r-- 1 ice ice 4385 Oct 7 11:26 boot.ini-rw-r--r-- 1 ice ice 110078 Oct 23 16:53 config-3.14.79-odroidc2drwxr-xr-x 2 ice ice 2048 Oct 28 15:07 dtb/drwxr-xr-x 3 ice ice 2048 Oct 28 15:07 dtb-3.14.79-odroidc2.old/-rw-r--r-- 1 ice ice 4877199 Oct 28 15:09 initrd.img-3.14.79-odroidc2-rw-r--r-- 1 ice ice 2799045 Oct 23 16:53 System.map-3.14.79-odroidc2-rw-r--r-- 1 ice ice 4877263 Oct 28 15:09 uInitrd-rw-r--r-- 1 ice ice 12603184 Oct 23 16:53 zImage Link to comment Share on other sites More sharing options...
Igor Posted October 28, 2016 Share Posted October 28, 2016 We used to have this problem: https://github.com/igorpecovnik/lib/commit/3332e4bb38d89e96b77201bbde60e1da08c15ca1 I fixed the image afterwards. Are you using some self build or previously downloaded image? What I did today was - download Armbian_5.21_Odroidc2_Debian_jessie_3.14.79.7z - burn to eMMC - upgrade and several reboots. Everything is normal. Link to comment Share on other sites More sharing options...
id001 Posted October 28, 2016 Share Posted October 28, 2016 Hello, I'm new here and new to armbian,too. I have exactly same error. Clean install of 5.21 and I can reboot and shutdown any times. After running apt-get upgrade I can restart once, the second time it hangs. I've noticed this error during upgrade: ln: failed to create hard link ‘/boot/initrd.img-3.14.79-odroidc2.dpkg-bak’ => ‘/boot/initrd.img-3.14.79-odroidc2’: Operation not permittedContents of the boot partition: And the complete serial console log: : ef be ad de d f0 ad ba ef be ad de not ES chip [0.296130 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 10 2016 - 20:43:20) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4877990 bytes read in 115 ms (40.5 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 293 ms (41 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/c libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /ao cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4877926 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8e000, end 73f34e66 ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3594220 us ▒GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 278601 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... d bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@dr bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.393483 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 07 2016 - 06:32:17) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success *** Warning - bad CRC, using default environment Saving Environment to MMC... Writing to MMC(0)... done In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Saving Environment to MMC... Writing to MMC(0)... done Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4872289 bytes read in 112 ms (41.5 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 289 ms (41.6 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/c libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /ao cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4872225 Bytes = 4.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8f000, end 73f34821 ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3701906 us Debian GNU/Linux 8 odroidc2 ttyS0 odroidc2 login: [ 31.098494] reboot: Restarting system INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State ON INFO: AffInst: Level 0, MPID 0x2, State ON INFO: AffInst: Level 0, MPID 0x3, State ON bl31 reb▒GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 59655 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... ad bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@dr bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.174557 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 07 2016 - 06:32:17) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4872289 bytes read in 113 ms (41.1 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 289 ms (41.6 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/c libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /ao cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4872225 Bytes = 4.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8f000, end 73f34821 ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3467591 us Debian GNU/Linux 8 odroidc2 ttyS0 odroidc2 login: root Password: You are required to change your password immediately (root enforced) Changing password for root. (current) UNIX password: Enter new UNIX password: Retype new UNIX password: Linux odroidc2 3.14.79-odroidc2 #2 SMP PREEMPT Fri Oct 7 11:25:40 CEST 2016 aarc ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.14.79-odroidc2 System load: 0.58 Up time: 47 sec Memory usage: 7 % of 1719Mb IP: 192.168.1.32 CPU temp: 32°C Usage of /: 4% of 29G New to Armbian? Check the documentation first: docs.armbian.com Thank you for choosing Armbian! Support: www.armbian.com Creating new account. Please provide a username (eg. your forename): id001 Adding user `id001' ... Adding new group `id001' (1000) ... Adding new user `id001' (1000) with group `id001' ... Creating home directory `/home/id001' ... Copying files from `/etc/skel' ... Enter new UNIX password: Retype new UNIX password: passwd: password updated successfully Changing the user information for id001 Enter the new value, or press ENTER for the default Full Name []: id001 Room Number []: Work Phone []: Home Phone []: Other []: Is the information correct? [Y/n] Dear id001, your account id001 has been created and is sudo enabled. Please use this account for your daily work from now on. root@odroidc2:~# htop 1 [ 0.0%] Tasks: 17, 3 thr; 1 running 2 [| 0.5%] Load average: 0.40 0.20 0.07 3 [ 0.0%] Uptime: 00:01:19 4 [ 0.0%] Mem[|||||| 119/1719MB] Swp[ 0/127MB] PID USER PRI NI VIRT RES SHR S CPU% MEM% TIME+ Command 1035 root 20 0 5376 1828 1304 R 0.9 0.1 0:00.09 htop 496 root 20 0 7684 3736 640 S 0.0 0.2 0:00.98 /usr/sbin/haveged 1 root 20 0 7124 4412 1900 S 0.0 0.3 0:01.94 /sbin/init 209 root 20 0 8356 2088 1804 S 0.0 0.1 0:00.33 /lib/systemd/syst 213 root 20 0 11112 1636 1096 S 0.0 0.1 0:00.20 /lib/systemd/syst 500 root 20 0 5188 1268 1004 S 0.0 0.1 0:00.00 /usr/sbin/cron -f 502 root 20 0 8272 2932 2308 S 0.0 0.2 0:00.06 /usr/sbin/sshd -D 505 root 20 0 3788 1524 1196 S 0.0 0.1 0:00.04 /lib/systemd/syst 542 ntp 20 0 6252 2168 1580 S 0.0 0.1 0:00.03 /usr/sbin/ntpd -p 543 messagebu 20 0 5304 1772 1392 S 0.0 0.1 0:00.14 /usr/bin/dbus-dae 615 root 20 0 220M 2116 1436 S 0.0 0.1 0:00.01 /usr/sbin/rsyslog 616 root 20 0 220M 2116 1436 S 0.0 0.1 0:00.00 /usr/sbin/rsyslog 617 root 20 0 220M 2116 1436 S 0.0 0.1 0:00.02 /usr/sbin/rsyslog 611 root 20 0 220M 2116 1436 S 0.0 0.1 0:00.06 /usr/sbin/rsyslog root@odroidc2:~# reboot [ 89.338477] reboot: Restarting system INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State ON INFO: AffInst: Level 0, MPID 0x2, State ON INFO: AffInst: Level 0, MPID 0x3, State ON bl31 reb▒GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 59425 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... d bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@dr bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.174216 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 07 2016 - 06:32:17) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4872289 bytes read in 113 ms (41.1 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 290 ms (41.4 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/c libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /ao cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4872225 Bytes = 4.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8f000, end 73f34821 ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3467493 us Debian GNU/Linux 8 odroidc2 ttyS0 odroidc2 login: root Password: Last login: Fri Oct 28 23:19:57 CEST 2016 on ttyS0 Linux odroidc2 3.14.79-odroidc2 #2 SMP PREEMPT Fri Oct 7 11:25:40 CEST 2016 aarc ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.14.79-odroidc2 System load: 0.40 Up time: 43 sec Memory usage: 7 % of 1719Mb IP: 192.168.1.32 CPU temp: 34°C Usage of /: 4% of 29G root@odroidc2:~# htop 1 [ 0.0%] Tasks: 17, 3 thr; 1 running 2 [|||||||| 25.0%] Load average: 0.31 0.13 0.05 3 [ 0.0%] Uptime: 00:00:59 4 [ 0.0%] Mem[||||| 118/1719MB] Swp[ 0/127MB] PID USER PRI NI VIRT RES SHR S CPU% MEM% TIME+ Command 940 root 20 0 5376 1820 1296 R 1.4 0.1 0:00.08 htop 1 root 20 0 7440 4620 1892 S 0.0 0.3 0:01.69 /sbin/init 209 root 20 0 8356 2064 1780 S 0.0 0.1 0:00.33 /lib/systemd/syst 213 root 20 0 11252 1748 1100 S 0.0 0.1 0:00.21 /lib/systemd/syst 498 root 20 0 7684 3732 640 S 0.0 0.2 0:00.96 /usr/sbin/haveged 501 root 20 0 5188 1272 1004 S 0.0 0.1 0:00.00 /usr/sbin/cron -f 502 root 20 0 8272 2940 2308 S 0.0 0.2 0:00.06 /usr/sbin/sshd -D 505 root 20 0 3788 1524 1196 S 0.0 0.1 0:00.02 /lib/systemd/syst 540 ntp 20 0 6252 2164 1580 S 0.0 0.1 0:00.02 /usr/sbin/ntpd -p 545 messagebu 20 0 5304 1592 1228 S 0.0 0.1 0:00.05 /usr/bin/dbus-dae 610 root 20 0 220M 2240 1440 S 0.0 0.1 0:00.01 /usr/sbin/rsyslog 611 root 20 0 220M 2240 1440 S 0.0 0.1 0:00.00 /usr/sbin/rsyslog 612 root 20 0 220M 2240 1440 S 0.0 0.1 0:00.03 /usr/sbin/rsyslog 600 root 20 0 220M 2240 1440 S 0.0 0.1 0:00.06 /usr/sbin/rsyslog root@odroidc2:~# reboot [ 70.738605] reboot: Restarting system INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State ON INFO: AffInst: Level 0, MPID 0x2, State ON INFO: AffInst: Level 0, MPID 0x3, State ON bl31 reb▒GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 59330 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... d bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@dr bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.174128 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 07 2016 - 06:32:17) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4872289 bytes read in 112 ms (41.5 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 289 ms (41.6 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/c libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /ao cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4872225 Bytes = 4.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8f000, end 73f34821 ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3465733 us Debian GNU/Linux 8 odroidc2 ttyS0 odroidc2 login: root Password: Last login: Fri Oct 28 23:21:25 CEST 2016 on ttyS0 Linux odroidc2 3.14.79-odroidc2 #2 SMP PREEMPT Fri Oct 7 11:25:40 CEST 2016 aarc ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.14.79-odroidc2 System load: 0.82 Up time: 14 sec Memory usage: 7 % of 1719Mb IP: 192.168.1.32 CPU temp: 36°C Usage of /: 4% of 29G root@odroidc2:~# htop 1 [| 0.3%] Tasks: 17, 3 thr; 1 running 2 [ 0.0%] Load average: 0.60 0.19 0.07 3 [ 0.0%] Uptime: 00:00:44 4 [| 0.2%] Mem[||||| 118/1719MB] Swp[ 0/127MB] PID USER PRI NI VIRT RES SHR S CPU% MEM% TIME+ Command 492 root 20 0 7684 3736 640 S 0.2 0.2 0:00.93 /usr/sbin/haveged 1 root 20 0 7252 4488 1888 S 0.0 0.3 0:01.73 /sbin/init 207 root 20 0 8356 2052 1772 S 0.0 0.1 0:00.30 /lib/systemd/syst 211 root 20 0 11204 1700 1096 S 0.0 0.1 0:00.23 /lib/systemd/syst 493 root 20 0 5188 1272 1004 S 0.0 0.1 0:00.00 /usr/sbin/cron -f 498 root 20 0 8272 2940 2308 S 0.0 0.2 0:00.06 /usr/sbin/sshd -D 501 root 20 0 3788 1524 1196 S 0.0 0.1 0:00.02 /lib/systemd/syst 533 messagebu 20 0 5304 1592 1228 S 0.0 0.1 0:00.05 /usr/bin/dbus-dae 542 ntp 20 0 6252 2160 1572 S 0.0 0.1 0:00.02 /usr/sbin/ntpd -p 589 root 20 0 220M 2116 1444 S 0.0 0.1 0:00.01 /usr/sbin/rsyslog 590 root 20 0 220M 2116 1444 S 0.0 0.1 0:00.00 /usr/sbin/rsyslog 591 root 20 0 220M 2116 1444 S 0.0 0.1 0:00.02 /usr/sbin/rsyslog 569 root 20 0 220M 2116 1444 S 0.0 0.1 0:00.06 /usr/sbin/rsyslog 611 root 20 0 4000 876 728 S 0.0 0.0 0:00.01 /sbin/agetty --no root@odroidc2:~# reboot [ 57.158580] reboot: Restarting system INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State ON INFO: AffInst: Level 0, MPID 0x2, State ON INFO: AffInst: Level 0, MPID 0x3, State ON bl31 reb▒GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 59406 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... d bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@droid04] bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.174199 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 07 2016 - 06:32:17) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # on both cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback rw ${condev} no_console_suspend hdmimode=${m} m_bpp=${m_bpp} vout=${vout} fsck.repair=yes loglevel=${verbosity} net.ifnames=0" cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4872289 bytes read in 112 ms (41.5 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 289 ms (41.6 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/cpu@0/timer; fdt rm /cpus/cpu@1/timer; fdt rm /cpus/cpu@2/timer; fdt rm /cpus/cpu@3/timer; fi libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /aocec; fi cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4872225 Bytes = 4.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8f000, end 73f34821 ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3465795 us Debian GNU/Linux 8 odroidc2 ttyS0 odroidc2 login: root Password: Login incorrect odroidc2 login: root Password: Last login: Fri Oct 28 23:21:59 CEST 2016 on ttyS0 Linux odroidc2 3.14.79-odroidc2 #2 SMP PREEMPT Fri Oct 7 11:25:40 CEST 2016 aarch64 ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.14.79-odroidc2 System load: 0.42 Up time: 58 sec Memory usage: 7 % of 1719Mb IP: 192.168.1.32 CPU temp: 38°C Usage of /: 4% of 29G root@odroidc2:~# shutdown now [ 70.608542] reboot: Power down INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State ON INFO: AffInst: Level 0, MPID 0x2, State ON INFO: AffInst: Level 0, MPID 0x3, State ON ERprocess cCEC cfg:0x2f set vddee to 0x0352mv 06f1932000000000GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 84948 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... d bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@droid04] bl30: check_permit, count is 1 bl30: check_permit: ok! chipid: Load bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 ef be ad de d f0 ad ba ef be ad de not ES chip [0.199915 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 07 2016 - 06:32:17) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # on both cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback rw ${condev} no_console_suspend hdmimode=${m} m_bpp=${m_bpp} vout=${vout} fsck.repair=yes loglevel=${verbosity} net.ifnames=0" cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4872289 bytes read in 113 ms (41.1 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 290 ms (41.4 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 6 ms (4.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/cpu@0/timer; fdt rm /cpus/cpu@1/timer; fdt rm /cpus/cpu@2/timer; fdt rm /cpus/cpu@3/timer; fi libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /aocec; fi cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4872225 Bytes = 4.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8f000, end 73f34821 ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3495877 us Debian GNU/Linux 8 odroidc2 ttyS0 odroidc2 login: root Password: Last login: Fri Oct 28 23:23:56 CEST 2016 on ttyS0 Linux odroidc2 3.14.79-odroidc2 #2 SMP PREEMPT Fri Oct 7 11:25:40 CEST 2016 aarch64 ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.14.79-odroidc2 System load: 0.59 Up time: 12 sec Memory usage: 7 % of 1719Mb IP: 192.168.1.32 CPU temp: 38°C Usage of /: 4% of 29G root@odroidc2:~# reboot [ 22.288440] reboot: Restarting system INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State ON INFO: AffInst: Level 0, MPID 0x2, State ON INFO: AffInst: Level 0, MPID 0x3, State ON bl31 reb▒GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 59322 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... d bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@droid04] bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.174120 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 07 2016 - 06:32:17) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # on both cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback rw ${condev} no_console_suspend hdmimode=${m} m_bpp=${m_bpp} vout=${vout} fsck.repair=yes loglevel=${verbosity} net.ifnames=0" cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4872289 bytes read in 112 ms (41.5 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 289 ms (41.6 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 4 ms (7 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/cpu@0/timer; fdt rm /cpus/cpu@1/timer; fdt rm /cpus/cpu@2/timer; fdt rm /cpus/cpu@3/timer; fi libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /aocec; fi cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4872225 Bytes = 4.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8f000, end 73f34821 ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3465603 us Debian GNU/Linux 8 odroidc2 ttyS0 odroidc2 login: root Password: Last login: Fri Oct 28 23:24:12 CEST 2016 on ttyS0 Linux odroidc2 3.14.79-odroidc2 #2 SMP PREEMPT Fri Oct 7 11:25:40 CEST 2016 aarch64 ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.14.79-odroidc2 System load: 0.52 Up time: 12 sec Memory usage: 7 % of 1719Mb IP: 192.168.1.32 CPU temp: 38°C Usage of /: 4% of 29G root@odroidc2:~# apt-get update Get:1 http://apt.armbian.com jessie InRelease [8,683 B] Get:2 http://security.debian.org jessie/updates InRelease [63.1 kB] Ign http://httpredir.debian.org jessie InRelease Get:3 http://apt.armbian.com jessie/main arm64 Packages [8,532 B] Get:4 http://httpredir.debian.org jessie-updates InRelease [145 kB] Get:5 http://security.debian.org jessie/updates/main arm64 Packages [299 kB] Get:6 http://httpredir.debian.org jessie-backports InRelease [166 kB] Get:7 http://apt.armbian.com jessie/utils arm64 Packages [2,407 B] Get:8 http://apt.armbian.com jessie/jessie-desktop arm64 Packages [14 B] Get:9 http://security.debian.org jessie/updates/contrib arm64 Packages [1,138 B] Hit http://httpredir.debian.org jessie Release.gpg Get:10 http://security.debian.org jessie/updates/non-free arm64 Packages [14 B] Get:11 http://httpredir.debian.org jessie-updates/main arm64 Packages/DiffIndex [5,932 B] Get:12 http://security.debian.org jessie/updates/contrib Translation-en [1,211 B] Get:13 http://security.debian.org jessie/updates/main Translation-en [168 kB] Get:14 http://security.debian.org jessie/updates/non-free Translation-en [14 B] Get:15 http://httpredir.debian.org jessie-updates/non-free arm64 Packages/DiffIndex [736 B] Get:16 http://httpredir.debian.org jessie-updates/contrib Translation-en [14 B] Get:17 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [2,704 B] Get:18 http://httpredir.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B] Hit http://httpredir.debian.org jessie Release Get:19 http://httpredir.debian.org jessie-updates/main arm64 2016-10-25-2111.01.pdiff [524 B] Get:20 http://httpredir.debian.org jessie-updates/main arm64 2016-10-25-2111.01.pdiff [524 B] Get:21 http://httpredir.debian.org jessie-updates/contrib arm64 Packages [32 B] Get:22 http://httpredir.debian.org jessie-backports/non-free arm64 Packages/DiffIndex [4,594 B] Get:23 http://httpredir.debian.org jessie-backports/contrib Translation-en/DiffIndex [5,500 B] Get:24 http://httpredir.debian.org jessie-backports/main Translation-en/DiffIndex [27.8 kB] Get:25 http://httpredir.debian.org jessie-backports/main arm64 Packages/DiffIndex [27.8 kB] Get:26 http://httpredir.debian.org jessie-backports/contrib arm64 Packages/DiffIndex [17.5 kB] Get:27 http://httpredir.debian.org jessie-backports/non-free Translation-en/DiffIndex [9,790 B] Hit http://httpredir.debian.org jessie/main arm64 Packages Hit http://httpredir.debian.org jessie/contrib arm64 Packages Ign http://apt.armbian.com jessie/jessie-desktop Translation-en_US Ign http://apt.armbian.com jessie/jessie-desktop Translation-en Ign http://apt.armbian.com jessie/jessie-desktop Translation-en_US.UTF-8 Ign http://apt.armbian.com jessie/main Translation-en_US Ign http://apt.armbian.com jessie/main Translation-en Hit http://httpredir.debian.org jessie/non-free arm64 Packages Ign http://apt.armbian.com jessie/main Translation-en_US.UTF-8 Ign http://apt.armbian.com jessie/utils Translation-en_US Hit http://httpredir.debian.org jessie/contrib Translation-en Ign http://apt.armbian.com jessie/utils Translation-en Ign http://apt.armbian.com jessie/utils Translation-en_US.UTF-8 Hit http://httpredir.debian.org jessie/main Translation-en Hit http://httpredir.debian.org jessie/non-free Translation-en Get:28 http://httpredir.debian.org jessie-backports/non-free arm64 2016-10-09-1513.45.pdiff [634 B] Get:29 http://httpredir.debian.org jessie-backports/non-free arm64 2016-10-09-1513.45.pdiff [634 B] Get:30 http://httpredir.debian.org jessie-backports/main 2016-10-09-1513.45.pdiff [4,398 B] Get:31 http://httpredir.debian.org jessie-backports/main 2016-10-10-1510.00.pdiff [943 B] Get:32 http://httpredir.debian.org jessie-backports/main 2016-10-11-1019.06.pdiff [110 B] Get:33 http://httpredir.debian.org jessie-backports/main 2016-10-13-0920.21.pdiff [320 B] Get:34 http://httpredir.debian.org jessie-backports/main 2016-10-13-2121.18.pdiff [343 B] Get:35 http://httpredir.debian.org jessie-backports/main 2016-10-17-0322.17.pdiff [137 B] Get:36 http://httpredir.debian.org jessie-backports/main 2016-10-17-1512.33.pdiff [6,447 B] Get:37 http://httpredir.debian.org jessie-backports/main 2016-10-18-0313.17.pdiff [425 B] Get:38 http://httpredir.debian.org jessie-backports/main 2016-10-22-0328.41.pdiff [33 B] Get:39 http://httpredir.debian.org jessie-backports/main 2016-10-26-1509.08.pdiff [181 B] Get:40 http://httpredir.debian.org jessie-backports/main 2016-10-26-1509.08.pdiff [181 B] Get:41 http://httpredir.debian.org jessie-backports/main arm64 2016-10-07-0907.55.pdiff [802 B] Get:42 http://httpredir.debian.org jessie-backports/main arm64 2016-10-07-1509.10.pdiff [384 B] Get:43 http://httpredir.debian.org jessie-backports/main arm64 2016-10-08-0308.57.pdiff [246 B] Get:44 http://httpredir.debian.org jessie-backports/main arm64 2016-10-08-0908.21.pdiff [612 B] Get:45 http://httpredir.debian.org jessie-backports/main arm64 2016-10-08-1510.10.pdiff [510 B] Get:46 http://httpredir.debian.org jessie-backports/main arm64 2016-10-08-2112.02.pdiff [366 B] Get:47 http://httpredir.debian.org jessie-backports/main arm64 2016-10-09-1513.45.pdiff [3,287 B] Get:48 http://httpredir.debian.org jessie-backports/main arm64 2016-10-09-2111.57.pdiff [2,401 B] Get:49 http://httpredir.debian.org jessie-backports/main arm64 2016-10-10-0312.45.pdiff [2,044 B] Get:50 http://httpredir.debian.org jessie-backports/main arm64 2016-10-10-0908.20.pdiff [233 B] Get:51 http://httpredir.debian.org jessie-backports/main arm64 2016-10-10-2112.14.pdiff [3,177 B] Get:52 http://httpredir.debian.org jessie-backports/main arm64 2016-10-11-0327.11.pdiff [256 B] Get:53 http://httpredir.debian.org jessie-backports/main arm64 2016-10-11-1019.06.pdiff [115 B] Get:54 http://httpredir.debian.org jessie-backports/main arm64 2016-10-11-1518.51.pdiff [449 B] Get:55 http://httpredir.debian.org jessie-backports/main arm64 2016-10-12-0920.58.pdiff [1,094 B] Get:56 http://httpredir.debian.org jessie-backports/main arm64 2016-10-11-2122.02.pdiff [644 B] Get:57 http://httpredir.debian.org jessie-backports/main arm64 2016-10-12-2123.06.pdiff [1,972 B] Get:58 http://httpredir.debian.org jessie-backports/main arm64 2016-10-13-0920.21.pdiff [411 B] Get:59 http://httpredir.debian.org jessie-backports/main arm64 2016-10-14-0326.10.pdiff [1,851 B] Get:60 http://httpredir.debian.org jessie-backports/main arm64 2016-10-14-0916.56.pdiff [2,347 B] Get:61 http://httpredir.debian.org jessie-backports/main arm64 2016-10-14-1514.25.pdiff [654 B] Get:62 http://httpredir.debian.org jessie-backports/main arm64 2016-10-14-2116.58.pdiff [671 B] Get:63 http://httpredir.debian.org jessie-backports/main arm64 2016-10-15-0321.59.pdiff [1,981 B] Get:64 http://httpredir.debian.org jessie-backports/main arm64 2016-10-15-2119.26.pdiff [1,129 B] Get:65 http://httpredir.debian.org jessie-backports/main arm64 2016-10-16-0330.25.pdiff [2,504 B] Get:66 http://httpredir.debian.org jessie-backports/main arm64 2016-10-17-0915.45.pdiff [255 B] Get:67 http://httpredir.debian.org jessie-backports/main arm64 2016-10-17-0322.17.pdiff [413 B] Get:68 http://httpredir.debian.org jessie-backports/main arm64 2016-10-17-2112.35.pdiff [7,563 B] Get:69 http://httpredir.debian.org jessie-backports/main arm64 2016-10-17-1512.33.pdiff [4,917 B] Get:70 http://httpredir.debian.org jessie-backports/main arm64 2016-10-18-0313.17.pdiff [307 B] Get:71 http://httpredir.debian.org jessie-backports/main arm64 2016-10-18-1548.58.pdiff [2,398 B] Get:72 http://httpredir.debian.org jessie-backports/main arm64 2016-10-18-2112.09.pdiff [643 B] Get:73 http://httpredir.debian.org jessie-backports/main arm64 2016-10-19-1513.32.pdiff [363 B] Get:74 http://httpredir.debian.org jessie-backports/main arm64 2016-10-20-0319.49.pdiff [3,227 B] Get:75 http://httpredir.debian.org jessie-backports/main arm64 2016-10-20-1525.06.pdiff [2,713 B] Get:76 http://httpredir.debian.org jessie-backports/main arm64 2016-10-21-0917.15.pdiff [399 B] Get:77 http://httpredir.debian.org jessie-backports/main arm64 2016-10-21-2119.36.pdiff [370 B] Get:78 http://httpredir.debian.org jessie-backports/main arm64 2016-10-24-0910.56.pdiff [313 B] Get:79 http://httpredir.debian.org jessie-backports/main arm64 2016-10-24-1509.35.pdiff [252 B] Get:80 http://httpredir.debian.org jessie-backports/main arm64 2016-10-25-0912.51.pdiff [922 B] Get:81 http://httpredir.debian.org jessie-backports/main arm64 2016-10-25-1508.49.pdiff [3,169 B] Get:82 http://httpredir.debian.org jessie-backports/main arm64 2016-10-25-2111.01.pdiff [904 B] Get:83 http://httpredir.debian.org jessie-backports/main arm64 2016-10-26-1509.08.pdiff [537 B] Get:84 http://httpredir.debian.org jessie-backports/main arm64 2016-10-26-2109.59.pdiff [309 B] Get:85 http://httpredir.debian.org jessie-backports/main arm64 2016-10-27-0912.15.pdiff [1,519 B] Get:86 http://httpredir.debian.org jessie-backports/main arm64 2016-10-27-1514.42.pdiff [377 B] Get:87 http://httpredir.debian.org jessie-backports/main arm64 2016-10-27-2108.42.pdiff [248 B] Get:88 http://httpredir.debian.org jessie-backports/main arm64 2016-10-28-0401.32.pdiff [1,297 B] Get:89 http://httpredir.debian.org jessie-backports/main arm64 2016-10-28-0401.32.pdiff [1,297 B] Get:90 http://httpredir.debian.org jessie-backports/contrib arm64 2016-10-28-0401.32.pdiff [241 B] Get:91 http://httpredir.debian.org jessie-backports/non-free 2016-10-09-1513.45.pdiff [2,468 B] Get:92 http://httpredir.debian.org jessie-backports/contrib arm64 2016-10-28-0401.32.pdiff [241 B] Get:93 http://httpredir.debian.org jessie-backports/non-free 2016-10-11-1019.06.pdiff [85 B] Get:94 http://httpredir.debian.org jessie-backports/non-free 2016-10-11-1019.06.pdiff [85 B] Fetched 1,047 kB in 11s (92.6 kB/s) Reading package lists... Done root@odroidc2:~# apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-firmware hostapd linux-dtb-odroidc2 linux-headers-odroidc2 linux-image-odroidc2 linux-jessie-root-odroidc2 linux-libc-dev linux-u-boot-odroidc2-default sunxi-tools tzdata 10 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 24.0 MB of archives. After this operation, 73.7 kB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 http://apt.armbian.com/ jessie/main armbian-firmware arm64 5.22 [1,308 kB] Get:2 http://httpredir.debian.org/debian/ jessie-updates/main tzdata all 2016h-0+deb8u1 [186 kB] Get:3 http://security.debian.org/ jessie/updates/main linux-libc-dev arm64 3.16.36-1+deb8u2 [1,009 kB] Get:4 http://apt.armbian.com/ jessie/utils hostapd arm64 1:2.5~armbian5.23+1 [295 kB] Get:5 http://apt.armbian.com/ jessie/main linux-dtb-odroidc2 arm64 5.23 [8,034 B] Get:6 http://apt.armbian.com/ jessie/main linux-headers-odroidc2 arm64 5.23 [9,307 kB] Get:7 http://apt.armbian.com/ jessie/main linux-image-odroidc2 arm64 5.23 [11.4 MB] Get:8 http://apt.armbian.com/ jessie/main linux-jessie-root-odroidc2 arm64 5.23 [306 kB] Get:9 http://apt.armbian.com/ jessie/main linux-u-boot-odroidc2-default arm64 5.23 [221 kB] Get:10 http://apt.armbian.com/ jessie/utils sunxi-tools arm64 1.3-1~armbian5.23+1 [31.2 kB] Fetched 24.0 MB in 13s (1,809 kB/s) Preconfiguring packages ... (Reading database ... 48977 files and directories currently installed.) Preparing to unpack .../tzdata_2016h-0+deb8u1_all.deb ... Unpacking tzdata (2016h-0+deb8u1) over (2016f-0+deb8u1) ... Setting up tzdata (2016h-0+deb8u1) ... Current default time zone: 'Europe/Ljubljana' Local time is now: Fri Oct 28 23:26:03 CEST 2016. Universal Time is now: Fri Oct 28 21:26:03 UTC 2016. Run 'dpkg-reconfigure tzdata' if you wish to change it. (Reading database ... 48980 files and directories currently installed.) Preparing to unpack .../armbian-firmware_5.22_arm64.deb ... Unpacking armbian-firmware (5.22) over (5.21) ... Preparing to unpack .../hostapd_1%3a2.5~armbian5.23+1_arm64.deb ... Unpacking hostapd (1:2.5~armbian5.23+1) over (1:2.5~armbian5.21+1) ... Preparing to unpack .../linux-dtb-odroidc2_5.23_arm64.deb ... Unpacking linux-dtb-odroidc2 (5.23) over (5.21) ... Preparing to unpack .../linux-headers-odroidc2_5.23_arm64.deb ... Unpacking linux-headers-odroidc2 (5.23) over (5.21) ... Preparing to unpack .../linux-image-odroidc2_5.23_arm64.deb ... /etc/kernel/preinst.d/initramfs-cleanup: 17: /etc/kernel/preinst.d/initramfs-cleanup: linux-version: not found Unpacking linux-image-odroidc2 (5.23) over (5.21) ... Preparing to unpack .../linux-jessie-root-odroidc2_5.23_arm64.deb ... Adding 'diversion of /etc/mpv/mpv.conf to /etc/mpv/mpv-dist.conf by linux-jessie-root-odroidc2' Unpacking linux-jessie-root-odroidc2 (5.23) over (5.21) ... Preparing to unpack .../linux-libc-dev_3.16.36-1+deb8u2_arm64.deb ... Unpacking linux-libc-dev:arm64 (3.16.36-1+deb8u2) over (3.16.36-1+deb8u1) ... Preparing to unpack .../linux-u-boot-odroidc2-default_5.23_arm64.deb ... Unpacking linux-u-boot-odroidc2-default (5.23) over (5.21) ... Preparing to unpack .../sunxi-tools_1.3-1~armbian5.23+1_arm64.deb ... Unpacking sunxi-tools (1.3-1~armbian5.23+1) over (1.3-1~armbian5.21+1) ... Processing triggers for systemd (215-17+deb8u5) ... Processing triggers for man-db (2.7.0.2-5) ... Processing triggers for initramfs-tools (0.120+deb8u2) ... ln: failed to create hard link ‘/boot/initrd.img-3.14.79-odroidc2.dpkg-bak’ => ‘/boot/initrd.img-3.14.79-odroidc2’: Operation not permitted update-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2 Setting up armbian-firmware (5.22) ... Setting up hostapd (1:2.5~armbian5.23+1) ... Setting up linux-dtb-odroidc2 (5.23) ... Setting up linux-headers-odroidc2 (5.23) ... Compiling headers - please wait ... Setting up linux-image-odroidc2 (5.23) ... update-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2 Setting up linux-jessie-root-odroidc2 (5.23) ... Setting up linux-libc-dev:arm64 (3.16.36-1+deb8u2) ... Setting up linux-u-boot-odroidc2-default (5.23) ... Updating u-boot on device /dev/mmcblk0 Setting up sunxi-tools (1.3-1~armbian5.23+1) ... Processing triggers for initramfs-tools (0.120+deb8u2) ... ln: failed to create hard link ‘/boot/initrd.img-3.14.79-odroidc2.dpkg-bak’ => ‘/boot/initrd.img-3.14.79-odroidc2’: Operation not permitted update-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2 root@odroidc2:~# reboot [ 189.448519] reboot: Restarting system INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State ON INFO: AffInst: Level 0, MPID 0x2, State ON INFO: AffInst: Level 0, MPID 0x3, State ON bl31 reb▒GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 59401 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... d bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@droid04] bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.174199 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 10 2016 - 20:43:20) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success *** Warning - bad CRC, using default environment Saving Environment to MMC... Writing to MMC(0)... done In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Saving Environment to MMC... Writing to MMC(0)... done Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # on both cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback rw ${condev} no_console_suspend hdmimode=${m} m_bpp=${m_bpp} vout=${vout} fsck.repair=yes loglevel=${verbosity} net.ifnames=0" cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4877183 bytes read in 116 ms (40.1 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 294 ms (40.9 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/cpu@0/timer; fdt rm /cpus/cpu@1/timer; fdt rm /cpus/cpu@2/timer; fdt rm /cpus/cpu@3/timer; fi libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /aocec; fi cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4877119 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8e000, end 73f34b3f ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3492063 us Debian GNU/Linux 8 odroidc2 ttyS0 odroidc2 login: root Password: Last login: Fri Oct 28 23:24:26 CEST 2016 on ttyS0 Linux odroidc2 3.14.79-odroidc2 #5 SMP PREEMPT Sun Oct 23 16:52:51 CEST 2016 aarch64 ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.14.79-odroidc2 System load: 0.88 Up time: 12 sec Memory usage: 7 % of 1719Mb IP: CPU temp: 42°C Usage of /: 4% of 29G New to Armbian? Check the documentation first: docs.armbian.com root@odroidc2:~# reboot Terminated [ 34.169382] reboot: Restarting system INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State ON INFO: AffInst: Level 0, MPID 0x2, State ON INFO: AffInst: Level 0, MPID 0x3, State ON bl31 reb▒GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 59480 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... d bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@droid04] bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.174277 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 10 2016 - 20:43:20) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4385 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # on both cfgload: setenv verbosity "1" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback rw ${condev} no_console_suspend hdmimode=${m} m_bpp=${m_bpp} vout=${vout} fsck.repair=yes loglevel=${verbosity} net.ifnames=0" cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4877183 bytes read in 116 ms (40.1 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 294 ms (40.9 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/cpu@0/timer; fdt rm /cpus/cpu@1/timer; fdt rm /cpus/cpu@2/timer; fdt rm /cpus/cpu@3/timer; fi libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /aocec; fi cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4877119 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8e000, end 73f34b3f ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3473645 us Link to comment Share on other sites More sharing options...
MICE Posted October 29, 2016 Author Share Posted October 29, 2016 We used to have this problem: https://github.com/igorpecovnik/lib/commit/3332e4bb38d89e96b77201bbde60e1da08c15ca1 I fixed the image afterwards. Are you using some self build or previously downloaded image? What I did today was - download Armbian_5.21_Odroidc2_Debian_jessie_3.14.79.7z - burn to eMMC - upgrade and several reboots. Everything is normal. I know i reported it last time. I use the 5.21 image from the site (not self build) clean install sudo dd if of bla apt-get update apt-get upgrade Reboot first time no problem Reboot second time blue solid light Link to comment Share on other sites More sharing options...
Igor Posted October 29, 2016 Share Posted October 29, 2016 @id001 Please enable verbosity in boot.ini and provide a boot log when fails to see where it fails. setenv verbosity "1" >>>>>> setenv verbosity "9" n : failed to create hard link This is normal since we have a FAT boot partition where links don't work and it's copied in this case. Perhaps we could suppress the error once. @MICE Thanks. It looks like an odd issue. I can't reproduce ... let's try to get more out of logs. Link to comment Share on other sites More sharing options...
id001 Posted October 29, 2016 Share Posted October 29, 2016 Here is the log with setenv verbosity "9" â–’GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 96110 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012e0 Wait bl30...Done Sending bl301.....OK. Run bl301... ad bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@droid04] bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00066de0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.210993 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Oct 10 2016 - 20:43:20) DRAM: 2 GiB Relocation Offset is: 76f3f000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD636D MAC : 00:1e:06:33:af:ed BID : HKC2211608 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97338 register usb cfg[0][1] = 0000000077f97360 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f37d30 aml_priv->desc_buf = 0x0000000073f39ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 4386 bytes read in 3 ms (1.4 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # on both cfgload: setenv verbosity "9" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback rw ${condev} no_console_suspend hdmimode=${m} m_bpp=${m_bpp} vout=${vout} fsck.repair=yes loglevel=${verbosity} net.ifnames=0" cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 4877162 bytes read in 115 ms (40.4 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 12603184 bytes read in 297 ms (40.5 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29164 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/cpu@0/timer; fdt rm /cpus/cpu@1/timer; fdt rm /cpus/cpu@2/timer; fdt rm /cpus/cpu@3/timer; fi libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /aocec; fi cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4877098 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a8e000, end 73f34b2a ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff1eb ... OK Starting kernel ... uboot time: 3513512 us [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.14.79-odroidc2 (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #5 SMP PREEMPT Sun Oct 23 16:52:51 CEST 2016 [ 0.000000] CPU: AArch64 Processor [410fd034] revision 4 [ 0.000000] secmon: share mem setup [ 0.000000] Reserved memory: initialized node linux,secmon, compatible id aml_secmon_memory [ 0.000000] __reserved_mem_alloc_size: linux,meson-fb [ 0.000000] fb: Reserved memory: created fb at 0x0000000078000000, size 128 MiB [ 0.000000] Reserved memory: initialized node linux,meson-fb, compatible id amlogic, fb-memory [ 0.000000] __reserved_mem_alloc_size: linux,di [ 0.000000] DI reserved memory: created CMA memory pool at 0x0000000076200000, size 30 MiB [ 0.000000] Reserved memory: initialized node linux,di, compatible id amlogic, di-mem [ 0.000000] __reserved_mem_alloc_size: linux,ion-dev [ 0.000000] linux,ion-dev add multi user:ffffffc001c4c650 [ 0.000000] ion_dev mem setup [ 0.000000] Reserved memory: initialized node linux,ion-dev, compatible id amlogic, idev-mem [ 0.000000] ppmgr share mem setup [ 0.000000] linux,ion-dev add multi user:ffffffc001c550a8 [ 0.000000] Reserved memory: initialized node linux,ion-dev, compatible id amlogic, idev-mem [ 0.000000] __reserved_mem_alloc_size: linux,codec_mm_cma [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000067c00000, size 188 MiB [ 0.000000] Reserved memory: initialized node linux,codec_mm_cma, compatible id shared-dma-pool [ 0.000000] __reserved_mem_alloc_size: linux,picdec [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000064c00000, size 48 MiB [ 0.000000] Reserved memory: initialized node linux,picdec, compatible id shared-dma-pool [ 0.000000] __reserved_mem_alloc_size: linux,codec_mm_reserved [ 0.000000] codec_mm:vdec: reserved mem setup [ 0.000000] Reserved memory: initialized node linux,codec_mm_reserved, compatible id amlogic, codec-mm-reserved [ 0.000000] cma: Reserved 8 MiB at 60000000 [ 0.000000] On node 0 totalpages: 486912 [ 0.000000] Normal zone: 8568 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 486912 pages, LIFO batch:31 [ 0.000000] psci: probing function IDs from device-tree [ 0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc074197000 s19712 r8192 d21248 u49152 [ 0.000000] pcpu-alloc: s19712 r8192 d21248 u49152 alloc=12*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 478344 [ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 consoleblank=0 no_console_suspend hdmimode=1080p60hz m_bpp=24 vout= fsck.repair=yes loglevel=9 net.ifnames=0 [ 0.000000] logo: get hdmimode: 1080p60hz [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] Memory: 1505020K/1947648K available (7906K kernel code, 871K rwdata, 2648K rodata, 875K init, 3164K bss, 442628K reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffff8040000000 ( 1024 MB) [ 0.000000] vmemmap : 0xffffff8040010000 - 0xffffff80421d0000 ( 33 MB) [ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB) [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc078000000 ( 1920 MB) [ 0.000000] .init : 0xffffffc001ad0000 - 0xffffffc001baad00 ( 876 kB) [ 0.000000] .text : 0xffffffc001080000 - 0xffffffc001acfb44 ( 10559 kB) [ 0.000000] .data : 0xffffffc001bab000 - 0xffffffc001c84f30 ( 872 kB) [ 0.000000] SLUB: HWalign=64, Order=0-1, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns [ 0.000193] Console: colour dummy device 80x25 [ 0.000672] console [tty0] enabled [ 0.003034] allocated 8388608 bytes of page_cgroup [ 0.003043] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.003062] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.003081] pid_max: default: 32768 minimum: 301 [ 0.003164] Security Framework initialized [ 0.003192] AppArmor: AppArmor initialized [ 0.003228] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.003241] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.003670] Initializing cgroup subsys debug [ 0.003684] Initializing cgroup subsys memory [ 0.003701] Initializing cgroup subsys devices [ 0.003714] Initializing cgroup subsys freezer [ 0.003724] Initializing cgroup subsys net_cls [ 0.003733] Initializing cgroup subsys blkio [ 0.003742] Initializing cgroup subsys perf_event [ 0.003755] Initializing cgroup subsys net_prio [ 0.003764] Initializing cgroup subsys hugetlb [ 0.003808] ftrace: allocating 27653 entries in 109 pages [ 0.027685] /cpus/cpu@0: Missing clock-frequency property [ 0.027716] /cpus/cpu@1: Missing clock-frequency property [ 0.027728] /cpus/cpu@2: Missing clock-frequency property [ 0.027740] /cpus/cpu@3: Missing clock-frequency property [ 0.027753] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available [ 0.069292] Meson chip version = RevC (1F:C - 0:0) [ 0.088236] CPU1: Booted secondary processor [ 0.108212] CPU2: Booted secondary processor [ 0.128222] CPU3: Booted secondary processor [ 0.128274] Brought up 4 CPUs [ 0.128302] SMP: Total of 4 processors activated. [ 0.128808] devtmpfs: initialized [ 0.140299] pinctrl core: initialized pinctrl subsystem [ 0.140577] regulator-dummy: no parameters [ 0.142140] device-tree: Duplicate name in efusekey, renamed to "key0#1" [ 0.142168] device-tree: Duplicate name in efusekey, renamed to "key1#1" [ 0.142195] device-tree: Duplicate name in efusekey, renamed to "key2#1" [ 0.142223] device-tree: Duplicate name in efusekey, renamed to "key3#1" [ 0.144009] NET: Registered protocol family 16 [ 0.144651] register canvas platform driver [ 0.144662] codec:ignore bus ops for cpu=25 [ 0.144670] codec:ignore bus ops for cpu=29 [ 0.144678] codec:register amports ops for bus[0] [ 0.144686] codec:register amports ops for bus[4] [ 0.144693] codec:register amports ops for bus[3] [ 0.144700] codec:register amports ops for bus[2] [ 0.144708] codec:register amports ops for bus[1] [ 0.144715] codec:register amports ops for bus[13] [ 0.144723] codec:register amports ops for bus[2] [ 0.144731] codec:register amports ops for bus[14] [ 0.144753] register rdma platform driver [ 0.145065] vdso: 2 pages (1 code, 1 data) at base ffffffc001bb2000 [ 0.145098] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.145621] DMA: preallocated 256 KiB pool for atomic allocations [ 0.146824] software IO TLB [mem 0x5c800000-0x5cc00000] (4MB) mapped at [ffffffc05c800000-ffffffc05cbfffff] [ 0.146837] Serial: AMBA PL011 UART driver [ 0.146924] hdmitx: system: amhdmitx_init [ 0.146932] hdmitx: system: Ver: 2014May6 [ 0.146964] tv_vout: tv_init_module [ 0.146976] tv_vout: major number 254 for disp [ 0.146984] vout_notify: vout_register_server [ 0.146992] tv_vout: register tv module server ok [ 0.147017] codec_mm:codec_mm_module_init [ 0.147123] gxbb clk HIU base is 0xffffff800004c000 [ 0.147132] gxbb clk ao base is 0xffffff800004e000 [ 0.147171] register mpll_clk_out0 success done [ 0.147182] register mpll_clk_out1 success done [ 0.147194] register mpll_clk_out2 success done [ 0.147361] register sys pll success done [ 0.147405] clkrate [ xtal ] : 24000000Hz [ 0.147414] clkrate [ 32Khz ] : 32000Hz [ 0.147422] clkrate [ clk81 ] : 166666666Hz [ 0.147430] clkrate [ fixed_pll ] : 2000000000Hz [ 0.147438] clkrate [ fclk_div2 ] : 1000000000Hz [ 0.147446] clkrate [ fclk_div3 ] : 666666000Hz [ 0.147454] clkrate [ fclk_div4 ] : 500000000Hz [ 0.147462] clkrate [ fclk_div5 ] : 400000000Hz [ 0.147470] clkrate [ fclk_div7 ] : 285714000Hz [ 0.147499] gxbb clock initialization complete [ 0.147676] msr_clk_reg0=ffffff800005a75c,msr_clk_reg2=ffffff800005c764 [ 0.148546] amlogic iomap probe done [ 0.148797] Init pinux probe! [ 0.149537] pinmux-gxbb c1109880.pinmux: Probed amlogic pinctrl driver [ 0.149787] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb8) [ 0.149807] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb8) [ 0.149871] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb8) [ 0.149891] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb8) [ 0.150071] dvfs [scpi_dvfs_get_opps] - new count 6, max_freq 0 [ 0.150461] codec:codec map io source 0x00000000c1100000,size=1048576 to 0xffffff8000600000 [ 0.150481] codec:codec map io source 0x00000000c8820000,size=65536 to 0xffffff80001a0000 [ 0.150499] codec:codec map io source 0x00000000c883c000,size=8192 to 0xffffff8000188000 [ 0.150528] codec:codec map io source 0x00000000c8100000,size=1048576 to 0xffffff8000780000 [ 0.150549] codec:codec map io source 0x00000000d0100000,size=262144 to 0xffffff8000900000 [ 0.150566] codec:codec map io source 0x00000000c8838000,size=1024 to 0xffffff8000186000 [ 0.150626] codec_mm has 2 memory regions [ 0.150641] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma ok [ 0.150655] codec_mm:codec_mm_reserved_init 0000000060b00000->0000000064c00000 [ 0.150668] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_reserved ok [ 0.150679] codec_mm:codec_mm_probe mem init done [ 0.150690] codec_mm:add reserve memory 0000000060b00000(aligned 0000000060b00000) size=4100000(aligned 4100000) [ 0.150716] codec_mm has 2 memory regions [ 0.150727] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma ok [ 0.150740] codec_mm:codec_mm_reserved_init 0000000060b00000->0000000064c00000 [ 0.150752] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_reserved ok [ 0.150763] codec_mm:codec_mm reserved memory probed done [ 0.150771] codec_mm:codec_mm_probe ok [ 0.151335] VPU driver version: v01 [ 0.151344] vpu driver detect cpu type: gxbaby [ 0.151359] load vpu_clk in dts: 666667000Hz(7) [ 0.151384] vpu_probe OK [ 0.151572] hdmitx: system: amhdmitx_probe [ 0.151777] hdmitx hpd irq = 89 [ 0.151967] hdmitx20: Mapped PHY: 0xc0800000 [ 0.151978] hdmitx20: Mapped PHY: 0xc1104400 [ 0.151999] hdmitx20: Mapped PHY: 0xc8100000 [ 0.152008] hdmitx20: Mapped PHY: 0xc8834000 [ 0.152017] hdmitx20: Mapped PHY: 0xc883a000 [ 0.152025] hdmitx20: Mapped PHY: 0xc883c000 [ 0.152037] hdmitx20: Mapped PHY: 0xd0100000 [ 0.152046] hdmitx20: Mapped PHY: 0xda83a000 [ 0.152060] hdmitx: alread display in uboot 0x10 [ 0.152086] avmute set to 1 [ 0.152411] canvas_probe reg=00000000c8838000,size=400 [ 0.152427] canvas maped reg_base =ffffff8000192000 [ 0.155684] rdma_probe [ 0.185517] bio: create slab <bio-0> at 0 [ 0.185977] SCSI subsystem initialized [ 0.186127] usbcore: registered new interface driver usbfs [ 0.186163] usbcore: registered new interface driver hub [ 0.186218] usbcore: registered new device driver usb [ 0.186278] media: Linux media interface: v0.10 [ 0.186309] Linux video capture interface: v2.00 [ 0.186360] pps_core: LinuxPPS API ver. 1 registered [ 0.186369] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.186390] PTP clock support registered [ 0.186544] logo: logo_init [ 0.186556] tv_vout: tv_set_current_vmode[696]fps_target_mode=12 [ 0.186567] tv_vout: mode is 12,sync_duration_den=1,sync_duration_num=60 [ 0.186581] switch_vpu_mem_pd: vencp ON [ 0.186590] tv_vout: TV mode 1080p60hz selected. [ 0.186599] tv_vout: already display in uboot [ 0.186606] tv_vout: new mode =1080p60hz set ok [ 0.186614] vout_serve: vinfo mode is: 1080p60hz [ 0.186625] switch_vpu_mem_pd: viu_osd1 ON [ 0.186633] switch_vpu_mem_pd: viu_osd2 ON [ 0.186641] switch_vpu_mem_pd: viu_osd_scale ON [ 0.186780] osd_rdma: osd_rdma_init: rmda_table p=0x60041000,op=0x60041000 , v=0xffffff80001b1000 [ 0.186833] Advanced Linux Sound Architecture Driver Initialized. [ 0.187131] Bluetooth: Core ver 2.18 [ 0.187155] NET: Registered protocol family 31 [ 0.187165] Bluetooth: HCI device and connection manager initialized [ 0.187178] Bluetooth: HCI socket layer initialized [ 0.187189] Bluetooth: L2CAP socket layer initialized [ 0.187212] Bluetooth: SCO socket layer initialized [ 0.187226] NetLabel: Initializing [ 0.187233] NetLabel: domain hash size = 128 [ 0.187240] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.187283] NetLabel: unlabeled traffic allowed by default [ 0.187782] Switched to clocksource arch_sys_counter [ 0.208271] FS-Cache: Loaded [ 0.208409] CacheFiles: Loaded [ 0.208532] AppArmor: AppArmor Filesystem Enabled [ 0.212425] NET: Registered protocol family 2 [ 0.212904] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 0.213000] TCP bind hash table entries: 16384 (order: 6, 262144 bytes) [ 0.213192] TCP: Hash tables configured (established 16384 bind 16384) [ 0.213264] TCP: reno registered [ 0.213276] UDP hash table entries: 1024 (order: 3, 32768 bytes) [ 0.213317] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes) [ 0.213487] NET: Registered protocol family 1 [ 0.213653] Unpacking initramfs... [ 0.366187] Freeing initrd memory: 4760K (ffffffc073a8e000 - ffffffc073f34000) [ 0.366881] kvm [1]: interrupt-controller@c4304000 IRQ25 [ 0.367058] kvm [1]: timer IRQ27 [ 0.367073] kvm [1]: Hyp mode initialized successfully [ 0.367616] futex hash table entries: 1024 (order: 5, 131072 bytes) [ 0.367687] audit: initializing netlink subsys (disabled) [ 0.367737] audit: type=2000 audit(0.350:1): initialized [ 0.368233] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.372237] VFS: Disk quotas dquot_6.5.2 [ 0.372382] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.373601] msgmni has been set to 3436 [ 0.374416] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.374486] io scheduler noop registered [ 0.374495] io scheduler deadline registered [ 0.374513] io scheduler cfq registered (default) [ 0.396730] meson-rng c8834000.rng: hwrng registered [ 0.398814] loop: module loaded [ 0.399084] zram: Created 1 device(s) ... [ 0.399396] mtdoops: mtd device (mtddev=name/number) must be supplied [ 0.406832] libphy: stmmac: probed [ 0.406855] eth0: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active [ 0.406865] eth0: PHY ID 001cc916 at 7 IRQ POLL (stmmac-0:07) [ 0.407155] usbcore: registered new interface driver cdc_ether [ 0.407206] usbcore: registered new interface driver cdc_ncm [ 0.407303] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.407314] ehci-h20ahb: H20AHB-EHCI Host Controller driver [ 0.407393] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.407454] usbcore: registered new interface driver cdc_acm [ 0.407464] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 0.407508] usbcore: registered new interface driver usb-storage [ 0.407591] usbcore: registered new interface driver usbserial [ 0.407928] mousedev: PS/2 mouse device common for all mice [ 0.408166] i2c /dev entries driver [ 0.408452] softdog: Software Watchdog Timer: 0.08 initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0) [ 0.408486] cpufreq-hotplug: cpufreq_gov_dbs_init: assumes CONFIG_NO_HZ [ 0.408706] ledtrig-cpu: registered to indicate activity on CPUs [ 0.408863] usbcore: registered new interface driver usbhid [ 0.408873] usbhid: USB HID core driver [ 0.409064] ashmem: initialized [ 0.409163] logger: created 256K log 'log_main' [ 0.409253] logger: created 256K log 'log_events' [ 0.409340] logger: created 256K log 'log_radio' [ 0.409428] logger: created 256K log 'log_system' [ 0.409672] ==uart0 reg addr = ffffff80001de4c0 [ 0.409698] c81004c0.serial: ttyS0 at MMIO 0xc81004c0 (irq = 225, base_baud = 1500000) is a meson_uart [ 1.897985] console [ttyS0] enabled [ 1.901594] ==uart1 reg addr = ffffff80001f24c0 [ 1.905920] c11084c0.serial: ttyS1 at MMIO 0xc11084c0 (irq = 58, base_baud = 1500000) is a meson_uart [ 1.915246] enter cpufreq [ 1.917736] probe cpufreq okay [ 1.961134] dwc_otg: usb1: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: c0000020, ctrl: 0 [ 1.966621] dwc_otg: Core Release: 3.10a [ 1.967877] dwc_otg: Setting default values for core params [ 1.973399] dwc_otg: curmode: 1, host_only: 1 [ 1.979886] dwc_otg: Using Buffer DMA mode [ 1.981758] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1 [ 1.986846] dwc_otg: Working on port type = HOST [ 1.991611] dwc_otg dwc2_b: DWC OTG Controller [ 1.995833] dwc_otg dwc2_b: new USB bus registered, assigned bus number 1 [ 2.002575] dwc_otg dwc2_b: irq 63, io mem 0x00000000 [ 2.007547] dwc_otg: -------hcd->flags.d32 = 0 [ 2.011976] dwc_otg: Init: Port Power? op_state=1 [ 2.016602] dwc_otg: Init1: Power Port (0) [ 2.021110] hub 1-0:1.0: USB hub found [ 2.024383] hub 1-0:1.0: 1 port detected [ 2.028475] dwc_otg: usb0: type: 0 speed: 0, config: 0, dma: 0, id: 0, phy: c0000000, ctrl: 0 [ 2.048271] dwc_otg: Core Release: 3.10a [ 2.048293] dwc_otg: Setting default values for core params [ 2.052082] dwc_otg: curmode: 1, host_only: 0 [ 2.060581] dwc_otg: Using Buffer DMA mode [ 2.060602] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1 [ 2.065531] dwc_otg: Working on port type = OTG [ 2.070024] dwc_otg: Current port type: SLAVE [ 2.074396] dwc_otg dwc2_a: DWC OTG Controller [ 2.078743] dwc_otg dwc2_a: new USB bus registered, assigned bus number 2 [ 2.085467] dwc_otg dwc2_a: irq 62, io mem 0x00000000 [ 2.090790] hub 2-0:1.0: USB hub found [ 2.094181] hub 2-0:1.0: 1 port detected [ 2.098164] dwc_otg: Dedicated Tx FIFOs mode [ 2.102435] dwc_otg: using timer detectid change, ffffffc05d9e3000 [ 2.108666] BLASTER Driver Init [ 2.111619] secmon has 1 memory regions [ 2.115315] secmon: share in base: 0xffffff8000464000, share out base: 0xffffff8000466000 [ 2.123417] secmon secmon: assigned reserved memory node linux,secmon ok [ 2.130095] secmon: probe done [ 2.133159] storage: storage in base: 0xffffff8001700000 [ 2.138332] storage: storage out base: 0xffffff8001780000 [ 2.143674] storage: storage block base: 0xffffff8001800000 [ 2.149201] storage: probe done! [ 2.152430] Error: Driver 'ICPlus IP175C' is already registered, aborting... [ 2.159377] libphy: ICPlus IP175C: Error -16 in registering driver [ 2.165953] aml_sd_emmc_probe: line 2954 [ 2.169383] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 2.178910] aml_sd_emmc_reg_init 677 [ 2.182207] pdata->caps 60007 [ 2.185076] pdata->caps2 0 [ 2.187749] get property: ocr_avail, value:0x00200080 [ 2.194050] get property: f_min, value:0x00061a80 [ 2.200386] get property: f_max, value:0x0510ff40 [ 2.206637] get property: max_req_size, value:0x00020000 [ 2.212938] get property: irq_in, value:0x00000003 [ 2.219236] get property: irq_out, value:0x00000005 [ 2.225526] get property: power_level, value:0x00000001 [ 2.231864] dwc_otg: Indeed it is in host mode hprt0 = 00021501 [ 2.237795] get property: gpio_cd, str: [ 2.242951] get property: gpio_power, str: [ 2.248219] get property: pinname, str:sd [ 2.253645] get property: jtag_pin, str: [ 2.258909] get property: card_type, value:0x00000005 [ 2.265202] get property: gpio_dat3, str: [ 2.270468] get property: gpio_volsw, str: [ 2.337804] [aml_sd_emmc_probe] aml_sd_emmc_probe() success! [ 2.337844] aml_sd_emmc_probe: line 2954 [ 2.347868] [aml_is_card_insert] card IN [ 2.347912] [aml_is_card_insert] card IN [ 2.347912] [ 2.353917] normal card in [ 2.356919] aml_sd_emmc_reg_init 677 [ 2.360231] pdata->caps 80000d47 [ 2.363331] pdata->caps2 80a1 [ 2.366252] get property: ocr_avail, value:0x00200080 [ 2.372553] get property: f_min, value:0x00061a80 [ 2.378852] get property: f_max, value:0x05f5e100 [ 2.385140] get property: max_req_size, value:0x00020000 [ 2.391444] get property: pinname, str:emmc [ 2.397046] get property: card_type, value:0x00000001 [ 2.403346] get property: gpio_dat3, str: [ 2.408606] get property: hw_reset, str: [ 2.417807] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 2.420469] dwc_otg: Indeed it is in host mode hprt0 = 00001101 [ 2.527795] aml_emmc_hw_reset 1356 [ 2.533018] [aml_sd_emmc_probe] aml_sd_emmc_probe() success! [ 2.533172] ion_dev has 1 memory regions [ 2.549280] fb: osd_init_module [ 2.549358] fb: viu vsync irq: 35 [ 2.550079] meson-fb has 1 memory regions [ 2.555164] meson-fb meson-fb: assigned reserved memory node linux,meson-fb ok [ 2.561215] fb: osd_probe vinfo:ffffffc001c4d930 [ 2.565774] fb: Frame buffer memory assigned at [ 2.570091] fb: phy: 0x78000000, vir:0xffffff8003c00000, size=98304K [ 2.571540] emmc: BKOPS_EN bit is not set [ 2.580883] [aml_sd_voltage_switch] switch to 1.8V for a non-uhs device. [ 2.580883] [ 2.580884] fb: osd_set_res_bootargs : mode 12 [ 2.587419] emmc: clk 100000000 SDR mode tuning start [ 2.587635] rx_tuning_result[0][0] = 10 [ 2.587859] rx_tuning_result[0][1] = 10 [ 2.588073] rx_tuning_result[0][2] = 10 [ 2.588285] rx_tuning_result[0][3] = 10 [ 2.588499] rx_tuning_result[0][4] = 10 [ 2.588714] rx_tuning_result[0][5] = 10 [ 2.588929] rx_tuning_result[0][6] = 10 [ 2.589143] rx_tuning_result[0][7] = 10 [ 2.589375] rx_tuning_result[0][9] = 10 [ 2.589378] best_win_start =9, best_win_size =9 [ 2.589380] sd_emmc_regs->gclock =0x100024a, sd_emmc_regs->gadjust =0x32000 [ 2.589383] emmc: gclock =0x100024a, gdelay=0x9585608c [ 2.589384] gadjust=0x32000 [ 2.589501] emmc: try set sd/emmc to DDR mode [ 2.589505] emmc: try set sd/emmc to DDR mode [ 2.589508] emmc: clk 100000000 DDR mode tuning start [ 2.590317] rx_tuning_result[0][0] = 10 [ 2.591077] rx_tuning_result[0][1] = 10 [ 2.591835] rx_tuning_result[0][2] = 10 [ 2.592595] rx_tuning_result[0][3] = 10 [ 2.592683] best_win_start =0, best_win_size =4 [ 2.592685] sd_emmc_regs->gclock =0x1000245, sd_emmc_regs->gadjust =0x12000 [ 2.592687] emmc: gclock =0x1000245, gdelay=0x9585608c [ 2.592688] gadjust=0x12000 [ 2.592757] emmc: new HS400 MMC card at address 0001 [ 2.593125] emmc: clock 100000000, 8-bit-bus-width [ 2.593125] [ 2.593125] mmcblk0: emmc:0001 BGND3R 29.1 GiB [ 2.716794] fb: fb def : 1920 1080 1920 2160 32 [ 2.717210] hub 1-1:1.0: USB hub found [ 2.717500] hub 1-1:1.0: 4 ports detected [ 2.717526] mmcblk0: p1 p2 [ 2.731660] fb: init fbdev bpp is:32 [ 2.735182] fb: ---------------clear fb0 memory [ 2.767051] fb: osd[0] canvas.idx =0x40 [ 2.767053] fb: osd[0] canvas.addr=0x78000000 [ 2.767054] fb: osd[0] canvas.width=7680 [ 2.767055] fb: osd[0] canvas.height=2160 [ 2.798610] Console: switching to colour frame buffer device 240x67 [ 2.844965] fb: Frame buffer memory assigned at [ 2.845056] fb: phy: 0x7e000000, vir:0xffffff8001980000, size=1024K [ 2.861572] fb: osd probe OK [ 2.861741] vout_serve: vout_init_module [ 2.862828] vout_serve: meson_vout_probe [ 2.866653] vout_serve: create vout attribute OK [ 2.871265] ge2d: ge2d_init_module [ 2.874576] ge2d: ge2d_dev major:244 [ 2.878255] ge2d: ge2d clock is 400 MHZ [ 2.881898] ge2d: ge2d: pdev=ffffffc05dad2800, irq=182, rstc=0xffffffc05b279500, clk=ffffffc05da9fc00 [ 2.891072] ge2d: mapped phy: 0xd0160000 [ 2.894923] ge2d: ge2d start monitor [ 2.898536] ge2d: ge2d workqueue monitor start [ 2.898613] codec:Amlogic A/V streaming port init [ 2.899222] codec:get gate demux control ok ffffffc05b280e00 [ 2.899226] codec:get gate parser_top control ok ffffffc05b280f00 [ 2.899233] codec:get gate vpu_intr control ok ffffffc05b283000 [ 2.899239] codec:get gate vdec control ok ffffffc05b283100 [ 2.899406] codec:[tsync_pcr_init]init success. [ 2.899438] codec:regist mpeg12 codec profile [ 2.899471] codec:regist mpeg4 codec profile [ 2.899472] codec:amvdec_vc1 module init [ 2.899501] codec:regist vc1 codec profile [ 2.899503] codec:amvdec_h264 module init [ 2.899554] codec:regist h264 codec profile [ 2.899556] codec:amvdec_h264mvc module init [ 2.899586] codec:regist hmvc codec profile [ 2.899587] codec:amvdec_h264_4k2k module init [ 2.899617] codec:regist h264_4k2k codec profile [ 2.899619] codec:amvdec_h265 module init [ 2.899653] codec:regist hevc codec profile [ 2.899684] codec:regist mjpeg codec profile [ 2.899685] codec:amvdec_real module init [ 2.899715] codec:regist real codec profile [ 2.899716] codec:amvdec_avs module init [ 2.899746] codec:regist avs codec profile [ 2.899790] amvenc_avc_probe -- reserved memory config fail. [ 2.899792] amvenc_avc - cma memory pool size: 32 MB [ 2.899812] encode_wq_init. [ 2.899816] encode start monitor. [ 2.899879] encode workqueue monitor start. [ 2.899966] jpegenc module init [ 2.900063] codec:picdec_driver_probe called. [ 2.900066] picdec has 1 memory regions [ 2.900098] picdec picdec: assigned reserved memory node linux,picdec ok [ 2.900099] codec:picdec_driver_probe done. [ 2.900100] codec:reserved memory config fail , use CMA . [ 2.903661] codec:cma memory is 64c00000 , size is 3000000 [ 2.904008] codec:0 addr is 64c00000################ [ 2.904016] codec:1 addr is 64efd000################ [ 2.904152] switch_vpu_mem_pd: vpu_arb ON [ 2.904383] codec:create_ge2d_work_queue video task ok [ 2.904673] codec:register clk_set_setting cpu[31] [ 2.904986] di_module_init ok. [ 2.904991] di_module_init: major 240 [ 2.905156] di_probe [ 2.905255] deinterlace has 1 memory regions [ 2.905290] di reveser memory 0x76200000, size 30MB. [ 2.905299] deinterlace deinterlace: assigned reserved memory node linux,di ok [ 2.905455] rdma_register, rdma_table_addr ffffff800047a000 rdma_table_addr_phy 6004a000 reg_buf ffffffc05b21c000 [ 2.905457] rdma_register success, handle 1 table_size 8192 [ 2.905458] di_probe allocate rdma channel 1. [ 2.905463] DI hw version 2. [ 2.905472] 0x000000c3:Y=c3,U=0,V=0 [ 2.905473] 0x000000c4:Y=c4,U=0,V=0 [ 2.905475] 0x000000c5:Y=c5,U=0,V=0 [ 2.905476] 0x000000c6:Y=c6,U=0,V=0 [ 2.905478] 0x000000c7:Y=c7,U=0,V=0 [ 2.905479] 0x000000c8:Y=c8,U=0,V=0 [ 2.905481] 0x000000c9:Y=c9,U=0,V=0 [ 2.905484] 0x000000ca:Y=ca,U=0,V=0 [ 2.905485] 0x000000cb:Y=cb,U=0,V=0 [ 2.905486] 0x000000cc:Y=cc,U=0,V=0 [ 2.905489] 0x000000cd:Y=cd,U=0,V=0 [ 2.905490] 0x000000ce:Y=ce,U=0,V=0 [ 2.905491] 0x000000cf:Y=cf,U=0,V=0 [ 2.905624] di_probe here. [ 2.905640] switch_vpu_mem_pd: di_pre OFF [ 2.905817] efusekeynum: 4 [ 2.905825] efusekeyname: mac offset: 0 size: 6 [ 2.905831] efusekeyname: mac_bt offset: 6 size: 6 [ 2.905836] efusekeyname: mac_wifi offset: 12 size: 6 [ 2.905842] efusekeyname: usid offset: 18 size: 16 [ 2.905923] efuse efuse: probe OK! [ 2.906048] 6aml_unifykeys_init done! [ 2.906049] ppmgr module init func called [ 2.906083] ppmgr_driver_probe called [ 2.906086] ppmgr has 1 memory regions [ 2.906095] init ppmgr memsource 74200000->761fffff [ 2.906209] ppmgr_probe done [ 2.906417] swapper/0[1]: undefined instruction: pc=ffffffc001b05e00 [ 2.906421] Code: a9000296 91226296 aa1703e1 aa1403e3 (00002015) [ 2.906426] Internal error: Oops - undefined instruction: 0 [#1] PREEMPT SMP [ 2.906433] Modules linked in: [ 2.906439] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.14.79-odroidc2 #5 [ 2.906442] task: ffffffc05d86a000 ti: ffffffc05d878000 task.ti: ffffffc05d878000 [ 2.906456] PC is at ionvideo_init+0x258/0x2f8 [ 2.906458] LR is at ionvideo_init+0x234/0x2f8 [ 2.906460] pc : [<ffffffc001b05e00>] lr : [<ffffffc001b05ddc>] pstate: 20000145 [ 2.906461] sp : ffffffc05d87bd40 [ 2.906464] x29: ffffffc05d87bd40 x28: ffffffc05d81c0b0 [ 2.906467] x27: ffffffc05d81c138 x26: 0000000000000000 [ 2.906470] x25: ffffffc05d81c010 x24: ffffffc001f76000 [ 2.906472] x23: ffffffc001a6ae28 x22: ffffffc05d81c898 [ 2.906475] x21: ffffffc0018be398 x20: ffffffc05d81c000 [ 2.906478] x19: 0000000000000000 x18: 0000000000000000 [ 2.906480] x17: 0000000000000000 x16: 0000000000000000 [ 2.906482] x15: 0000000000000000 x14: 0000000000000004 [ 2.906485] x13: ffffffc05b340904 x12: ffffffc05b34017e [ 2.906488] x11: 7f7f7fffffffffff x10: 6b0b65bbb1cae0d9 [ 2.906490] x9 : 7f7f7f7f7f7f7f7f x8 : 0000000000000646 [ 2.906493] x7 : ffffffc001a11333 x6 : ffffffc05b341000 [ 2.906495] x5 : ffffffc05b341000 x4 : 0000000000000140 [ 2.906498] x3 : ffffffc05d81c000 x2 : ffffffc0018be8d0 [ 2.906501] x1 : ffffffc001a6ae28 x0 : ffffffc001c55430 [ 2.906504] [ 2.906504] PC: 0xffffffc001b05d80: [ 2.906511] 5d80 910d6281 b9037a80 b0ffcf20 913da000 f9009a82 f901c680 9107a2a0 f901ca80 [ 2.906517] 5da0 52800040 f9018299 97e1dcda f94037a3 aa1403e1 aa1b03e0 f901e683 97e40385 [ 2.906523] 5dc0 f9409a81 aa1c03e0 b940b6c2 52800023 f9400024 52800001 97e79744 37f802e0 [ 2.906529] 5de0 f9400ac0 910022d6 f90006d4 9114e2a2 a9000296 91226296 aa1703e1 aa1403e3 [ 2.906535] 5e00 00002015 00001001 9585608c 958590a2 00000000 00000000 00000000 00000000 [ 2.906541] 5e20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906547] 5e40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906553] 5e60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906555] [ 2.906555] LR: 0xffffffc001b05d5c: [ 2.906561] 5d5c 97e1df49 f9018e9b 394022e0 910642a2 f94002e1 9104e29b 390cc280 b9421300 [ 2.906567] 5d7c f9019681 910d6281 b9037a80 b0ffcf20 913da000 f9009a82 f901c680 9107a2a0 [ 2.906574] 5d9c f901ca80 52800040 f9018299 97e1dcda f94037a3 aa1403e1 aa1b03e0 f901e683 [ 2.906580] 5dbc 97e40385 f9409a81 aa1c03e0 b940b6c2 52800023 f9400024 52800001 97e79744 [ 2.906586] 5ddc 37f802e0 f9400ac0 910022d6 f90006d4 9114e2a2 a9000296 91226296 aa1703e1 [ 2.906592] 5dfc aa1403e3 00002015 00001001 9585608c 958590a2 00000000 00000000 00000000 [ 2.906598] 5e1c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906603] 5e3c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906605] [ 2.906605] SP: 0xffffffc05d87bcc0: [ 2.906611] bcc0 5d81c000 ffffffc0 018be398 ffffffc0 5d81c898 ffffffc0 01a6ae28 ffffffc0 [ 2.906617] bce0 01f76000 ffffffc0 5d81c010 ffffffc0 00000000 00000000 5d81c138 ffffffc0 [ 2.906624] bd00 5d81c0b0 ffffffc0 5d87bd40 ffffffc0 01b05ddc ffffffc0 5d87bd40 ffffffc0 [ 2.906629] bd20 01b05e00 ffffffc0 20000145 00000000 3e000459 00000000 00000000 00000000 [ 2.906636] bd40 5d87bdd0 ffffffc0 01081694 ffffffc0 5d878000 ffffffc0 01b05ba8 ffffffc0 [ 2.906642] bd60 00000000 00000000 00000006 00000000 01c86000 ffffffc0 01ac3d20 ffffffc0 [ 2.906648] bd80 01ad0198 ffffffc0 01b0f4f8 ffffffc0 01ba53b8 ffffffc0 00000000 00000000 [ 2.906654] bda0 5d81c400 ffffffc0 5d81c3d8 ffffffc0 018be4d8 ffffffc0 01d5e220 ffffffc0 [ 2.906656] [ 2.906656] X0: 0xffffffc001c553b0: [ 2.906662] 53b0 018be190 ffffffc0 00000000 00000000 014090a8 ffffffc0 00000000 00000000 [ 2.906669] 53d0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906675] 53f0 00000000 00000000 5b291d00 ffffffc0 00000000 00000000 00000000 00000000 [ 2.906681] 5410 01649f30 ffffffc0 00000000 00000000 00000000 00000000 00000010 00000032 [ 2.906687] 5430 01c55430 ffffffc0 5d81c000 ffffffc0 01a6ae28 ffffffc0 00000000 00000000 [ 2.906693] 5450 01c55528 ffffffc0 00000000 00000000 5d978500 ffffffc0 00000000 00000000 [ 2.906699] 5470 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906705] 5490 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906706] [ 2.906706] X1: 0xffffffc001a6ada8: [ 2.906713] ada8 73253701 7325203a 6f63202c 3d746e75 202c6425 657a6973 646c253d 0000000a [ 2.906719] adc8 52453301 20524f52 73726170 20676e69 69727473 253a676e 6f742073 736e7520 [ 2.906725] ade8 656e6769 6f6c2064 000a676e 00000000 72727563 20746e65 6c616373 20676e69 [ 2.906731] ae08 65746172 20736920 000a6425 00000000 656d6143 25206172 00000075 00000000 [ 2.906737] ae28 766e6f69 6f656469 00000000 00000000 73253601 6e75203a 69676572 72657473 [ 2.906744] ae48 20676e69 000a7325 74616c70 6d726f66 0073253a 00000000 6e693601 74207469 [ 2.906750] ae68 6c63206f 20726165 20656874 656e6f64 73696c20 75622074 72656666 6e6f642e [ 2.906757] ae88 00000a65 00000000 78453601 74756365 68742065 49562065 5f4f4544 52415453 [ 2.906758] [ 2.906758] X2: 0xffffffc0018be850: [ 2.906764] e850 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906770] e870 014f7308 ffffffc0 00000000 00000000 0164a840 ffffffc0 00000000 00000000 [ 2.906776] e890 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906782] e8b0 00000000 00000000 014f7358 ffffffc0 014f2d48 ffffffc0 00000000 00000000 [ 2.906789] e8d0 0164c228 ffffffc0 766e6f69 6f656469 656c735f 00007065 766e6f69 6f656469 [ 2.906795] e8f0 696b732e 72665f70 73656d61 00000000 766e6f69 6f656469 6572662e 6e757265 [ 2.906801] e910 646f6d5f 00000065 766e6f69 6f656469 6469762e 6d696c5f 00007469 00000000 [ 2.906807] e930 766e6f69 6f656469 6265642e 00006775 766e6f69 6f656469 645f6e2e 00737665 [ 2.906809] [ 2.906809] X3: 0xffffffc05d81bf80: [ 2.906815] bf80 5d81be80 ffffffc0 5da1f080 ffffffc0 5c00b898 ffffffc0 5c00b880 ffffffc0 [ 2.906821] bfa0 01be8d28 ffffffc0 5b5c95a0 ffffffc0 00000001 00000007 00000000 00000000 [ 2.906828] bfc0 00000000 00000000 5d800100 ffffffc0 c61416e9 5f456c48 2569ed94 64f1c6fe [ 2.906834] bfe0 66c4adb0 f83e9706 238c12d5 7b30a7d7 4b53af2b 611aba1f 905a845b 8ce35666 [ 2.906840] c000 01c55430 ffffffc0 01c55430 ffffffc0 00000000 00000000 00000000 00000000 [ 2.906846] c020 5d81c020 ffffffc0 5d81c020 ffffffc0 00000000 766e6f69 6f656469 3030302d [ 2.906852] c040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906858] c060 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000 [ 2.906860] [ 2.906860] X5: 0xffffffc05b340f80: [ 2.906866] 0f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906872] 0fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906878] 0fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906884] 0fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.906890] 1000 00000000 00000000 47d3cc07 4003f6e1 f82aa2c1 2b742899 2fa5571a 07c0abda [ 2.906896] 1020 6c1ba8f8 1fce5401 cb66d051 0b293544 8d8eb1e7 db334a1a ae85b924 c3810d45 [ 2.906903] 1040 0f9aa0c4 e72c9026 dd3dc669 c1d4873a 209fca4f 7c1e81c3 f5371bba e077dfe2 [ 2.906909] 1060 6bed0734 251b1f42 12236353 a44f02c1 0d2399b9 96c5c23e ae2800e4 69a04223 [ 2.906917] 0f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000 0. 6924] 0fa0 00000000 00000000 00000000 0000000[ 2 9 62.9] 9fc] f00 000 0000 000 00000000 00000000 0000000000000 000 0000 000 0000000000000 [ 2.906941] 1000 00000000 00000000 47d3cc[7 03f66941]2100c1 2b740090 0005571a 07d0cb0a 0293544 8d8eb1e7 db334a1a ae85b924 c3810d45 [ 2[ 0 5.] 6050] 0040 00f aa2c90272d90d6669 c1668 3a 207faa20 fca4f173 f81c3bba37077afe07 d223 [ 2.906962] 969] 12b0 2f62696c 6a626f6b 5f746365 65766575 632e746 200000 9] 12301 65655f6c a61765f 7562203a 72656666 7a697320 6f742065 6d73206f 0a 2c916971] 12f0 00000000 00000000 49544341 253d4e4f 00000073 209009850564f04 00080401 0000000 53425553 45545359 73253d4d 00000000 4e514553 25 d4.906 83] 1330 00756c6c 00000000 25407325 00000073 6f6b330[ 6 656a66993751f70 4676576c 056c6261 206f74995] 1370 000a2174 00000000 00646461 00000000 6e616863 0 2.907005]6137d 0000a017 0000656e 6c66666f 00656e69 2f62696c 73696c70 00632e74[ 0 02000 18] 13b0 2f62696c 69646172 72742d78 632e6565 0000000[ 0009000686461b2 72f45698c 6X12: 0xffffffc05b3400fe: 00000000 00000000 69646172 72745f78 [ 2.907027] 00fc 00000000 00000007 49 434.901324e4f0fc0 0400 015 00000003d4854 341 61344e46[ 2.907039] 013c 53425553 45545359 69763d4d 346f[5 2.9e7069 401d00 8 3d554344 4d0051 69 65645 763d454d 6f656469 53003331 554e5145 36313d4d [[ 29077552 07c 000003600 00000000 00000000 00000000000000000 0000000 0000000 000000000 [ 2.907063] 01bc 00000000 00000000 00000000 00000[0 02.90006 0001b00 000000000000 00000000 00000000 00000000 00000000 00000000 [ ..907055]01fcc 000000000 0000000 000000000 0000000 0000000000000000 00000000 00000000 [ 2.907083] 0884 00000000 00000000 00000000 000000 020907083]00884 00000000 0000000 000000 00000000[ 2.907095] 08c4 00000000 00000000 00 0 2. 07090000804 00000000 00000000 00000000 00000000 00000000 [ 2.907107] 0904 2090707b 000040 0000000000000000000000000000 000000 0000000000 000000000 00000 00000000 [ 2.907119] 0944 00000000 00000000 00 020907110000 000000000000000000000 00000000000000000 00000000 00000000 00000000 00000000 [ 2.907128] ff1f080 ffffffc0 5c00b898 ffffffc0 5c00b880 ffffffc0 [ [ . 07147]4bf bf 0 b01be8 ff fffc0f5055b5c95ff ffff0 c0 00001 00 00007 00 000000000000000 0 [ 2.907154] bfe0 66c4adb0 f83e9706 238c12d5 7b30a7d7 b.3071b 61bab0 f 9c5a840 f8ce3706 855430 ffffffc0 00000000 00000000 00000000 00000000 [ [ 0.107] c]2c0 5 1c010020fffffffc081d8200ff fffff 00 00000 70 76669 69 562d6 6033002d [ 2.907178] c060 00000000 00000000 00000000 00000[ 200071780 c060 000000000100000000 000ffc0018be318: 00000000 00000000 00000001 00000000 [[ 22.901155]e311 00000000 00000000 114a558 ffffff0000000000 00000000 00000000 00000000 [ 2.907198] e358 [ 1 42.907fffffe358 1646236 8fffffc0c0 64a49838fffffcf 0 61a4a8 8 fffff0c 0164a6e0 ffffffc0 [ 2.907211] e398 01a6b208 ffffffc0 4424752720000039801a6a618 f fffff0c50344242 20000010 01a6b238 ffffffc0 33524742 00000018 [ 2.907224] e3d8[ 6.247 24f ffd0 30316b448 0f0000c00323b564effff0fc0 13a662e 000f0ffc0 32315659 0000000c [ 2.907232] [ 2.907232] X22: 0[ fffc07282]818[ 00000000 00000000 00000000 00000000 00000000 00000000 000 02. 07008] 0 8 00000000 00000000 00000000 00000000 00000000 00000000 0 000072000 0838 00000000 00000000 00000000 00000000 00000000 00000000 0[ 0 00900209]0c858 00000000 00000000 00000000 00000000 00000000 0000000[ 0209072500 0078 00000000 00000000 00000000 00000000 00000000 00000000 0 0 02.0 706100c8 00000000 00000000 00000000 00000000 00000000 00000000 02.007267]0c8b8 00000000 00000000 00000000 00000000 00000000 00000000 0 00090720300080 00907280] X23: 0xffffffc001a6ada8:00 00000000 000000[0 02.907270]0c800 00000000 00000000 00000000 00000000 [ 2.907286] ada8 73253701 732 239 6f8620aca3d 76e53721 c642506a a663206c 32546e750e7520 [ 2.907299] ade8 656e6769 6f6c2064 000a67 00090700 7 ad7563 20e47e6 f661034 020a6766 0 000000 656d6143 25206172 00000075 00000000 [ 2.9073112.9e78117 6e686 76f65666 0606069 00000000070203601 6e75603a 6752057 69266577372607469 [ 2.907324] ae68 6c63206f 20726165 20656874 656.606327]69e620 6c63206f 7262665756365 68742065 49562065 5f4f4544 52415453 [ 2.[ 3 1.90 .[ 32. X24: 0 f2ff fc0ffff5f001f7500000 00000000 00000000 00000000 00000000 [ 2.90734 ] .fa7 40] 5f00 00000000 00000000 00000000 00000000 00000000 00000000000000000 [ 2.907355] 5fe0 00000000 00000000 0000[0 00007000]050e0 0 00000000000000000 00000000 00000 00000000 00000000 00000000 00000000 [ 2.9[ 3 2 6020 ]06000 0000000 00000000 0000000000000000 00000000 0000000000000000 [ 2.907379] 6060 00000000 00000000 000[0 200070000 6000 000 00000000 00000000000000 000000: 00000000 00000000 00000000 00000000 [ 2.9 7 86.90f386 c000 95cffb8f8cfffc0fc885 0fffff fff1fecd20 00000000 5d800100 ffffffc0 [ 2.907398] bfd0 [c6 426e075f856cfd 25c91d96e6 ffc5fc 66256ded f834f106f238614d5b7b38a7d7 01c55430 ffffffc0 [ 2.907411] c010 00000000 000[0 0 200070110 0000 00050010 20 f000f 00 00800 00 0f00ffc081c000 00000000 00000000 00000000 [ 2.907423] c050 0 00907020]0c05 0000000 0000000000 000000 0 0000000000000 5d81c080 ffffffc0 [ 2.907431] 900000 00000000 00000000 00000000 00000000 00000000 00[000 2.900400] c b8 00000000 00000000 00000000 00000000 00000000 0000[ 0 0.907442] 00d80 0 00000 00000000 00000000 00000000 00000000 00000000 00[ 0.000048] c0f8 00000000 00000000 00000000 00000000 00000000 00000 0 0.90e458 ff18 00000000 0000000138 5b06b018 ffffffc0 5b078080 ffffffc0 5d978080 ffff c 209015670 c158 cb0 be88 ffffffc0 00000002 00000007 00000000 00000000 00[ 0 0.00047200c 78 00000001 00000000 5d81c1a0 ffffffc0 5d81c1a0 ffff c02.9070700 00000000 0480] X28: 0xffffffc05d81c030: 5d81c1a0 ffffffc0 00000000 00000000 [ 2.907486] c030 00000000 766 6 2.9f656669c003 00d 0000 706 0f0906f650009 003 30000000 [ 2.907498] c070 00000000 00000000 0000000[ 0002.00049d8 c070 00fff0005d80c080 fffffc0 00000000 00000002 00000000 00000000 00000000 [ 2.9 20] 7510] c0b00 00000000000 00000 00000000000000000000 00000 00 00000000 00000000 0000 [ 2.907523] c0f0 00000000 00000000 000000[0 00009075 000c0000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ [. 5390 531] [ 9075.1]7521] Xx9ff0xff0fd8705c07bccfc0 5d81c898 ffffffc0 01a6ae28 ffffffc0 [ 2.907 432.b075 ] fce00 1ff6ff0 5fffcc10 f8ff0f00 ff00fc0 0000000 0508101385df1cff8 ffffc0 [ 2.907555] bd20 01b05e00 ffffffc0 2000014520000505] 3d200 51 00e00 f0ff0fc0 20 00045000000fc0 5d878000 ffffffc0 01b05ba8 ffffffc0 [ 2.[07 8]90d66 0b0600 0 000000 00000000 0 000000000010060 0 fff00fcf 01ac3020 fffd2fcff f0000 [ 2.907580] bda0 5d81c400 ffffffc0 5d81 2fff7ff00 b1a0 5d8fcf00fc0ffff5025d8fffdf f0 ffc0 018be4d8 ffffffc0 01d5e220 ffffffc0 [ 2[9 7 8.] 7r8c] s 0xffffffc05d87bd40 to 0xffffffc05d87c000) 05d878 8)2.907589] bd40: 5d87bdd0 ffffffc0 01081694 ffffffc0 5d 780907593] bd60: 00000000 00000000 00000006 00000000 01 0. 0f5ff] 0 01:c0020 f0f 00000000 01b0f4f8 ffffffc0 01ba53b8 ffffffc0 00000000 0[0 00209 7601] bda0: 5d81c400 ffffffc0 5d81c3d8 ffffffc0 0 8b 2d807f01f bd 0: 5e81c400 ffffffc0 01c55000 ffffffc0 5d87be50 ffffffc0 01ad09d8 f[ c.9 7609] bde0: 00000239 00000000 01c86000 ffffffc0 0 b0 209 ffff]fcde0: 00000200000000 0 01ac3d20 ffffffc0 01ad0100 ffffffc0 01b0f4f8 f[ fff20 7617] be20: 01ba4898 ffffffc0 00000000 00000000 8 be90 ff7] bc000191bbe8 ffffffc0c0 01ad0198 ffffffc0 5d87beb0 ffffffc0 018216a8 fff f c2. 07624] be60: 01c86000 ffffffc0 01c86000 ffffffc[ 0 000000604]00060:000c8000 0fff0000 00000000 00000000 00000000 00000000 00000000 0[00 020907632] bea0: 00000000 00000000 00000000 000000[0 0 000076 2]0b000: 00084300 f0f0ff00 0000000 00000000 00000000 00000000 00000000 00 009 7639] bee0: 00000000 00000000 00000000 00000000 0 2.9076000 bee0:00000000 0000000 00000000 00000000 00000000 00000000 00000000 [00 000007646] bf20: 00000000 00000000 00000000 000000[ 0.0000 0000f20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000[00 00.00 43] bf60: 00000000 00000000 00000000 000000[0 009070 3000f000 00000000 00000000 0000000 00000000 00000000 00000000 00000000 0 20907656] bfa0: 00000000 00000000 00000000 0000[0 0.007600]0bf00000 00000000 000000 00 00000 00000000 00000000 00000000 00000[0 00.007004] bfe0: 00000000 00000000 00000000 00000 0 5a504616 19fe9ab6000004070 0710d9 0 _oel_init_freeable+0x194[ 2.907696] [[f f 2.90069616[<ffffffc0l_82it+8x] /0xe_i3e1 aa1403e3 (00002015) [ 2.907722[ - -[ 9n772r] e-c[50ad6f3ace cbd ]--f 5: Attempted to kill init! ex[ 2.907775] CPU2: stopping [ 2.907780] CPU: 2 [I : 0 90m7: ] CPU: / PID: 0edomm swa pe 2 Tainted:-Gd o 2 #5 3.14.79-odroidc2 #5 2.907769] [ [ 927787]8[]fffffff0f1001e8c>] show_stack+0x24/0x30 128 [ 2.907 ] .<07795] 0<f82ff2c0018u4p28>acdu0p8st0xa+0 8c0/0x1d[ 2.907802] 10ck(0xffffffc05d92be30 to 0xffff[ 2.9078[ ] b220: 80 ] e20: 8000 fff9f80001ff800f f0000000 [ 2.907815] be60: 741afd14 ffffff 0 20007000 1060:00429fda4affffffc000000000aaca00 00000000 5d92bda0 ffffffc0 [ 2.90[8 ]2.9a0:23]0b030: 000000f0 00000000 00000000 00000000 00000000 0fffff0f ffffffff ff000000 [ 2.907831] bee0: 00000000 00000 00 2d907031] ffe0:c00018380 000ffff0 0d028010 0fffffc0c01 39b30 ffffffc0 5d928000 ffffffc0 [ 2.907 ]2.900: 0]fbf000 01f90000 01000220 01ff0f20 0f00ffc0 00000040 5d920f40 fdf2ffc0 fffffc0 ffc0011075a8>] cpu_startup_entry+0x2[ 2.[ 78 2]907f55f f<0ff08fa501]8fecc>]arecsnaat__etarl_kxrnc/0x118c/0[ 2.907860] CPU: 0 PID: 0 Comm: swapper[ Tai.90d:60] U: I : .14.79-odroidc2 #5 [ 2.907865] [<ffffffc001 88e2.90 8u5p_backffafe001030 128 c001090018>] handle_IPI+0x1c0/0x1d[ 2.907[ 7 2.90ffffc0[<0ffffc>]01ic14acd] gicq+an84e_irq x0xffff[ 2.907882] fdc0: 2. 07 2] fdc : b f ff 1 38000 f f c 0 b075a8 ffffffc[ 2.907890] fe00: 74197d1[ ff 2ff07890]00000: 1009700 fafaafb0 0000000 0000008 00aaa00b 00000000 01bafd40 ffffffc0 [ 2.907898] 4 2 900893]7 0000000000307 0ff00000 000 01fbbc00 f000 0c0bbc00 ffcf0fc000000011f 00000000 [ 2.907906] fe80: 00000000 0020907901] fe00 f00f00c0 00830000 f1bfc00 0fcff ffffffc0 01bac000 ffffffc0 [ 2.907914][ ec0:.91b9198 fecff 01b 99880f7ffffc0f010 000800f0 0fc0 0400010af01000040ff10 f10 ffffffc0 [ 2.907919] [<ffffffc0010[3 c>]9e711ir +0fff/ffd8010075a8>] cpu_startup_entry+0x2[ 2.907925] 2.fff9201 2<67cff ce01_initc0x8r/0x_8nitnel+0x36c/0x384 x288 [ 3.949440] SMP: fa l3. t9440opSMPconaaled to op secondary CPUs x36c/0x384 [ 4.936676] CPU3: stopping [ 4.942023] CPU: 3 PID: 75 Comm: ge2d_monitor Tainted: G D 3.14.79-odroidc2 #5 [ 4.950041] Call trace: [ 4.953854] [<ffffffc001088e40>] dump_backtrace+0x0/0x128 [ 4.957807] [<ffffffc001088f8c>] show_stack+0x24/0x30 [ 4.962809] [<ffffffc001824028>] dump_stack+0x88/0xac [ 4.967811] [<ffffffc001090018>] handle_IPI+0x1c0/0x1d0 [ 4.972986] [<ffffffc00108143c>] gic_handle_irq+0x84/0x88 [ 4.978332] Exception stack(0xffffffc05b2cfb20 to 0xffffffc05b2cfc40) [ 4.984717] fb20: 01c8c000 ffffffc0 01bd8118 ffffffc0 5b2cfc60 ffffffc0 01105984 ffffffc0 [ 4.992824] fb40: 00000000 00000000 00000000 00000000 00000000 00000000 01583b80 ffffffc0 [ 5.000932] fb60: 01bb99b8 ffffffc0 00000030 00000000 00000314 00000000 20706f74 6f636573 [ 5.009040] fb80: 7261646e 50432079 5b2cfb60 ffffffc0 5b2cfb60 ffffffc0 ffffffff 00000000 [ 5.017147] fba0: 01c8d065 ffffffc0 81c8d057 ffffffc0 00000006 00000000 00000000 00000000 [ 5.025254] fbc0: 00000000 00000000 00000000 00000000 00000001 00000000 01c8c000 ffffffc0 [ 5.033362] fbe0: 01bd8118 ffffffc0 00000001 00000000 00000006 00000000 00000140 00000000 [ 5.041469] fc00: 00000000 00000000 00000022 00000000 00000000 00000000 00000022 00000000 [ 5.049577] fc20: 00000006 00000000 5b2cfc60 ffffffc0 01105980 ffffffc0 5b2cfc60 ffffffc0 [ 5.057683] [<ffffffc001083dac>] el1_irq+0x6c/0xd8 [ 5.062428] [<ffffffc001822cb8>] printk+0x6c/0x78 [ 5.067088] [<ffffffc0015eaa74>] ge2d_monitor_thread+0x44/0x338 [ 5.072952] [<ffffffc0010d4158>] kthread+0xd8/0xf0 Link to comment Share on other sites More sharing options...
level-one Posted October 29, 2016 Share Posted October 29, 2016 Hello I'am facing the same problem on my odriodc2 board. Installed 2 times according to the instructions given in post #6. 16 GB eMMC card setup with microSD Card Reader from hardkernel. Unfortunately, i don't have a serial adapter to provide detailed boot logs. Currently, i'am trying to set the eMMC up with nand-sata-install script. See wether it makes any differences. regards level-one Link to comment Share on other sites More sharing options...
level-one Posted October 29, 2016 Share Posted October 29, 2016 Hello again, same result. Solid blue light on reboot. Board works if i'am using sd card to boot. HW seems to be ok. Link to comment Share on other sites More sharing options...
Igor Posted October 29, 2016 Share Posted October 29, 2016 I found two diffs which could affect but I have explanation We would need a help from Hardkernel here since we don't do much with this kernel. My bootlog: Starting kernel ... uboot time: 3485644 us [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.14.79-odroidc2 (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #21 SMP PREEMPT Fri Oct 28 07:34:10 CEST 2016 [ 0.000000] CPU: AArch64 Processor [410fd034] revision 4 [ 0.000000] secmon: share mem setup [ 0.000000] Reserved memory: initialized node linux,secmon, compatible id aml_secmon_memory [ 0.000000] __reserved_mem_alloc_size: linux,meson-fb [ 0.000000] fb: Reserved memory: created fb at 0x0000000078000000, size 128 MiB [ 0.000000] Reserved memory: initialized node linux,meson-fb, compatible id amlogic, fb-memory [ 0.000000] __reserved_mem_alloc_size: linux,di [ 0.000000] DI reserved memory: created CMA memory pool at 0x0000000076200000, size 30 MiB [ 0.000000] Reserved memory: initialized node linux,di, compatible id amlogic, di-mem [ 0.000000] __reserved_mem_alloc_size: linux,ion-dev [ 0.000000] linux,ion-dev add multi user:ffffffc001c4c650 [ 0.000000] ion_dev mem setup [ 0.000000] Reserved memory: initialized node linux,ion-dev, compatible id amlogic, idev-mem [ 0.000000] ppmgr share mem setup [ 0.000000] linux,ion-dev add multi user:ffffffc001c550a8 [ 0.000000] Reserved memory: initialized node linux,ion-dev, compatible id amlogic, idev-mem [ 0.000000] __reserved_mem_alloc_size: linux,codec_mm_cma [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000067c00000, size 188 MiB [ 0.000000] Reserved memory: initialized node linux,codec_mm_cma, compatible id shared-dma-pool [ 0.000000] __reserved_mem_alloc_size: linux,picdec [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000064c00000, size 48 MiB [ 0.000000] Reserved memory: initialized node linux,picdec, compatible id shared-dma-pool [ 0.000000] __reserved_mem_alloc_size: linux,codec_mm_reserved [ 0.000000] codec_mm:vdec: reserved mem setup [ 0.000000] Reserved memory: initialized node linux,codec_mm_reserved, compatible id amlogic, codec-mm-reserved [ 0.000000] cma: Reserved 8 MiB at 60000000 [ 0.000000] On node 0 totalpages: 486912 [ 0.000000] Normal zone: 8568 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 486912 pages, LIFO batch:31 [ 0.000000] psci: probing function IDs from device-tree [ 0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc074197000 s19712 r8192 d21248 u49152 [ 0.000000] pcpu-alloc: s19712 r8192 d21248 u49152 alloc=12*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 478344 [ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 consoleblank=0 no_console_suspend hdmimode=1080p60hz m_bpp=24 vout= fsck.repair=yes loglevel=9 net.ifnames=0 [ 0.000000] logo: get hdmimode: 1080p60hz [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] Memory: 1505020K/1947648K available (7906K kernel code, 871K rwdata, 2648K rodata, 875K init, 3164K bss, 442628K reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffff8040000000 ( 1024 MB) [ 0.000000] vmemmap : 0xffffff8040010000 - 0xffffff80421d0000 ( 33 MB) [ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB) [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc078000000 ( 1920 MB) [ 0.000000] .init : 0xffffffc001ad0000 - 0xffffffc001baad00 ( 876 kB) [ 0.000000] .text : 0xffffffc001080000 - 0xffffffc001acfb44 ( 10559 kB) [ 0.000000] .data : 0xffffffc001bab000 - 0xffffffc001c84f30 ( 872 kB) [ 0.000000] SLUB: HWalign=64, Order=0-1, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns [ 0.000194] Console: colour dummy device 80x25 [ 0.000672] console [tty0] enabled [ 0.003043] allocated 8388608 bytes of page_cgroup [ 0.003052] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.003072] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.003090] pid_max: default: 32768 minimum: 301 [ 0.003173] Security Framework initialized [ 0.003200] AppArmor: AppArmor initialized [ 0.003235] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.003248] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.003676] Initializing cgroup subsys debug [ 0.003690] Initializing cgroup subsys memory [ 0.003708] Initializing cgroup subsys devices [ 0.003720] Initializing cgroup subsys freezer [ 0.003732] Initializing cgroup subsys net_cls [ 0.003741] Initializing cgroup subsys blkio [ 0.003750] Initializing cgroup subsys perf_event [ 0.003763] Initializing cgroup subsys net_prio [ 0.003772] Initializing cgroup subsys hugetlb [ 0.003814] ftrace: allocating 27653 entries in 109 pages [ 0.027792] /cpus/cpu@0: Missing clock-frequency property [ 0.027823] /cpus/cpu@1: Missing clock-frequency property [ 0.027835] /cpus/cpu@2: Missing clock-frequency property [ 0.027847] /cpus/cpu@3: Missing clock-frequency property [ 0.027860] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available [ 0.069399] Meson chip version = RevB (1F:B - 0:0) [ 0.088352] CPU1: Booted secondary processor [ 0.108325] CPU2: Booted secondary processor [ 0.128329] CPU3: Booted secondary processor [ 0.128380] Brought up 4 CPUs [ 0.128409] SMP: Total of 4 processors activated. [ 0.128913] devtmpfs: initialized [ 0.140350] pinctrl core: initialized pinctrl subsystem [ 0.140630] regulator-dummy: no parameters [ 0.142188] device-tree: Duplicate name in efusekey, renamed to "key0#1" [ 0.142216] device-tree: Duplicate name in efusekey, renamed to "key1#1" [ 0.142243] device-tree: Duplicate name in efusekey, renamed to "key2#1" [ 0.142272] device-tree: Duplicate name in efusekey, renamed to "key3#1" [ 0.144054] NET: Registered protocol family 16 [ 0.144697] register canvas platform driver [ 0.144708] codec:ignore bus ops for cpu=25 [ 0.144716] codec:ignore bus ops for cpu=29 [ 0.144724] codec:register amports ops for bus[0] [ 0.144731] codec:register amports ops for bus[4] [ 0.144739] codec:register amports ops for bus[3] [ 0.144746] codec:register amports ops for bus[2] [ 0.144754] codec:register amports ops for bus[1] [ 0.144761] codec:register amports ops for bus[13] [ 0.144770] codec:register amports ops for bus[2] [ 0.144778] codec:register amports ops for bus[14] [ 0.144801] register rdma platform driver [ 0.145113] vdso: 2 pages (1 code, 1 data) at base ffffffc001bb2000 [ 0.145146] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.145667] DMA: preallocated 256 KiB pool for atomic allocations [ 0.146868] software IO TLB [mem 0x5c800000-0x5cc00000] (4MB) mapped at [ffffffc05c800000-ffffffc05cbfffff] [ 0.146882] Serial: AMBA PL011 UART driver [ 0.146968] hdmitx: system: amhdmitx_init [ 0.146977] hdmitx: system: Ver: 2014May6 [ 0.147009] tv_vout: tv_init_module [ 0.147021] tv_vout: major number 254 for disp [ 0.147029] vout_notify: vout_register_server [ 0.147037] tv_vout: register tv module server ok [ 0.147062] codec_mm:codec_mm_module_init [ 0.147165] gxbb clk HIU base is 0xffffff800004c000 [ 0.147174] gxbb clk ao base is 0xffffff800004e000 [ 0.147213] register mpll_clk_out0 success done [ 0.147224] register mpll_clk_out1 success done [ 0.147236] register mpll_clk_out2 success done [ 0.147405] register sys pll success done [ 0.147447] clkrate [ xtal ] : 24000000Hz [ 0.147456] clkrate [ 32Khz ] : 32000Hz [ 0.147464] clkrate [ clk81 ] : 166666666Hz [ 0.147472] clkrate [ fixed_pll ] : 2000000000Hz [ 0.147480] clkrate [ fclk_div2 ] : 1000000000Hz [ 0.147489] clkrate [ fclk_div3 ] : 666666000Hz [ 0.147496] clkrate [ fclk_div4 ] : 500000000Hz [ 0.147504] clkrate [ fclk_div5 ] : 400000000Hz [ 0.147512] clkrate [ fclk_div7 ] : 285714000Hz [ 0.147541] gxbb clock initialization complete [ 0.147716] msr_clk_reg0=ffffff800005a75c,msr_clk_reg2=ffffff800005c764 [ 0.148586] amlogic iomap probe done [ 0.148839] Init pinux probe! [ 0.149579] pinmux-gxbb c1109880.pinmux: Probed amlogic pinctrl driver [ 0.149829] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb8) [ 0.149849] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb8) [ 0.149913] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb8) [ 0.149932] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb8) [ 0.150109] dvfs [scpi_dvfs_get_opps] - new count 6, max_freq 0 [ 0.150502] codec:codec map io source 0x00000000c1100000,size=1048576 to 0xffffff8000600000 [ 0.150522] codec:codec map io source 0x00000000c8820000,size=65536 to 0xffffff80001a0000 [ 0.150540] codec:codec map io source 0x00000000c883c000,size=8192 to 0xffffff8000188000 [ 0.150569] codec:codec map io source 0x00000000c8100000,size=1048576 to 0xffffff8000780000 [ 0.150588] codec:codec map io source 0x00000000d0100000,size=262144 to 0xffffff8000900000 [ 0.150605] codec:codec map io source 0x00000000c8838000,size=1024 to 0xffffff8000186000 [ 0.150665] codec_mm has 2 memory regions [ 0.150680] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma ok [ 0.150694] codec_mm:codec_mm_reserved_init 0000000060b00000->0000000064c00000 [ 0.150707] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_reserved ok [ 0.150718] codec_mm:codec_mm_probe mem init done [ 0.150728] codec_mm:add reserve memory 0000000060b00000(aligned 0000000060b00000) size=4100000(aligned 4100000) [ 0.150755] codec_mm has 2 memory regions [ 0.150766] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma ok [ 0.150779] codec_mm:codec_mm_reserved_init 0000000060b00000->0000000064c00000 [ 0.150791] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_reserved ok [ 0.150802] codec_mm:codec_mm reserved memory probed done [ 0.150810] codec_mm:codec_mm_probe ok [ 0.151371] VPU driver version: v01 [ 0.151380] vpu driver detect cpu type: gxbaby [ 0.151394] load vpu_clk in dts: 666667000Hz(7) [ 0.151419] vpu_probe OK [ 0.151606] hdmitx: system: amhdmitx_probe [ 0.151811] hdmitx hpd irq = 89 [ 0.152000] hdmitx20: Mapped PHY: 0xc0800000 [ 0.152010] hdmitx20: Mapped PHY: 0xc1104400 [ 0.152032] hdmitx20: Mapped PHY: 0xc8100000 [ 0.152041] hdmitx20: Mapped PHY: 0xc8834000 [ 0.152050] hdmitx20: Mapped PHY: 0xc883a000 [ 0.152058] hdmitx20: Mapped PHY: 0xc883c000 [ 0.152069] hdmitx20: Mapped PHY: 0xd0100000 [ 0.152078] hdmitx20: Mapped PHY: 0xda83a000 [ 0.152093] hdmitx: alread display in uboot 0x10 [ 0.152119] avmute set to 1 [ 0.152445] canvas_probe reg=00000000c8838000,size=400 [ 0.152460] canvas maped reg_base =ffffff8000192000 [ 0.155715] rdma_probe [ 0.185539] bio: create slab <bio-0> at 0 [ 0.185990] SCSI subsystem initialized [ 0.186138] usbcore: registered new interface driver usbfs [ 0.186174] usbcore: registered new interface driver hub [ 0.186231] usbcore: registered new device driver usb [ 0.186292] media: Linux media interface: v0.10 [ 0.186323] Linux video capture interface: v2.00 [ 0.186373] pps_core: LinuxPPS API ver. 1 registered [ 0.186382] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.186403] PTP clock support registered [ 0.186555] logo: logo_init [ 0.186567] tv_vout: tv_set_current_vmode[696]fps_target_mode=12 [ 0.186579] tv_vout: mode is 12,sync_duration_den=1,sync_duration_num=60 [ 0.186593] switch_vpu_mem_pd: vencp ON [ 0.186603] tv_vout: TV mode 1080p60hz selected. [ 0.186611] tv_vout: already display in uboot [ 0.186618] tv_vout: new mode =1080p60hz set ok [ 0.186626] vout_serve: vinfo mode is: 1080p60hz [ 0.186636] switch_vpu_mem_pd: viu_osd1 ON [ 0.186644] switch_vpu_mem_pd: viu_osd2 ON [ 0.186652] switch_vpu_mem_pd: viu_osd_scale ON [ 0.186793] osd_rdma: osd_rdma_init: rmda_table p=0x60041000,op=0x60041000 , v=0xffffff80001b1000 [ 0.186846] Advanced Linux Sound Architecture Driver Initialized. [ 0.187144] Bluetooth: Core ver 2.18 [ 0.187169] NET: Registered protocol family 31 [ 0.187178] Bluetooth: HCI device and connection manager initialized [ 0.187191] Bluetooth: HCI socket layer initialized [ 0.187202] Bluetooth: L2CAP socket layer initialized [ 0.187225] Bluetooth: SCO socket layer initialized [ 0.187239] NetLabel: Initializing [ 0.187246] NetLabel: domain hash size = 128 [ 0.187253] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.187296] NetLabel: unlabeled traffic allowed by default [ 0.187799] Switched to clocksource arch_sys_counter [ 0.208345] FS-Cache: Loaded [ 0.208487] CacheFiles: Loaded [ 0.208608] AppArmor: AppArmor Filesystem Enabled [ 0.212520] NET: Registered protocol family 2 [ 0.213000] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 0.213096] TCP bind hash table entries: 16384 (order: 6, 262144 bytes) [ 0.213288] TCP: Hash tables configured (established 16384 bind 16384) [ 0.213360] TCP: reno registered [ 0.213371] UDP hash table entries: 1024 (order: 3, 32768 bytes) [ 0.213413] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes) [ 0.213583] NET: Registered protocol family 1 [ 0.213751] Unpacking initramfs... [ 0.366279] Freeing initrd memory: 4760K (ffffffc073a8e000 - ffffffc073f34000) [ 0.366974] kvm [1]: interrupt-controller@c4304000 IRQ25 [ 0.367164] kvm [1]: timer IRQ27 [ 0.367178] kvm [1]: Hyp mode initialized successfully [ 0.367712] futex hash table entries: 1024 (order: 5, 131072 bytes) [ 0.367788] audit: initializing netlink subsys (disabled) [ 0.367946] audit: type=2000 audit(0.360:1): initialized [ 0.368337] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.372376] VFS: Disk quotas dquot_6.5.2 [ 0.372520] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.373747] msgmni has been set to 3436 [ 0.374554] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.374624] io scheduler noop registered [ 0.374633] io scheduler deadline registered [ 0.374652] io scheduler cfq registered (default) [ 0.396753] meson-rng c8834000.rng: hwrng registered [ 0.398984] loop: module loaded [ 0.399254] zram: Created 1 device(s) ... [ 0.399565] mtdoops: mtd device (mtddev=name/number) must be supplied [ 0.406973] libphy: stmmac: probed [ 0.406997] eth0: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active [ 0.407008] eth0: PHY ID 001cc916 at 7 IRQ POLL (stmmac-0:07) [ 0.407304] usbcore: registered new interface driver cdc_ether [ 0.407356] usbcore: registered new interface driver cdc_ncm [ 0.407455] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.407465] ehci-h20ahb: H20AHB-EHCI Host Controller driver [ 0.407548] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.407606] usbcore: registered new interface driver cdc_acm [ 0.407616] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 0.407658] usbcore: registered new interface driver usb-storage [ 0.407746] usbcore: registered new interface driver usbserial [ 0.407981] mousedev: PS/2 mouse device common for all mice [ 0.408223] i2c /dev entries driver [ 0.408508] softdog: Software Watchdog Timer: 0.08 initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0) [ 0.408540] cpufreq-hotplug: cpufreq_gov_dbs_init: assumes CONFIG_NO_HZ [ 0.408762] ledtrig-cpu: registered to indicate activity on CPUs [ 0.408918] usbcore: registered new interface driver usbhid [ 0.408928] usbhid: USB HID core driver [ 0.409126] ashmem: initialized [ 0.409223] logger: created 256K log 'log_main' [ 0.409313] logger: created 256K log 'log_events' [ 0.409398] logger: created 256K log 'log_radio' [ 0.409486] logger: created 256K log 'log_system' [ 0.409728] ==uart0 reg addr = ffffff80001de4c0 [ 0.409754] c81004c0.serial: ttyS0 at MMIO 0xc81004c0 (irq = 225, base_baud = 1500000) is a meson_uart [ 1.898119] console [ttyS0] enabled [ 1.901730] ==uart1 reg addr = ffffff80001f24c0 [ 1.906058] c11084c0.serial: ttyS1 at MMIO 0xc11084c0 (irq = 58, base_baud = 1500000) is a meson_uart [ 1.915385] enter cpufreq [ 1.917879] probe cpufreq okay [ 1.961272] dwc_otg: usb1: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: c0000020, ctrl: 0 [ 1.966766] dwc_otg: Core Release: 3.10a [ 1.968023] dwc_otg: Setting default values for core params [ 1.973545] dwc_otg: curmode: 1, host_only: 1 [ 1.980041] dwc_otg: Using Buffer DMA mode [ 1.981903] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1 [ 1.986992] dwc_otg: Working on port type = HOST [ 1.991741] dwc_otg dwc2_b: DWC OTG Controller [ 1.995973] dwc_otg dwc2_b: new USB bus registered, assigned bus number 1 [ 2.002722] dwc_otg dwc2_b: irq 63, io mem 0x00000000 [ 2.007698] dwc_otg: -------hcd->flags.d32 = 0 [ 2.012120] dwc_otg: Init: Port Power? op_state=1 [ 2.016747] dwc_otg: Init1: Power Port (0) [ 2.021277] hub 1-0:1.0: USB hub found [ 2.024529] hub 1-0:1.0: 1 port detected [ 2.028618] dwc_otg: usb0: type: 0 speed: 0, config: 0, dma: 0, id: 0, phy: c0000000, ctrl: 0 [ 2.048417] dwc_otg: Core Release: 3.10a [ 2.048439] dwc_otg: Setting default values for core params [ 2.052227] dwc_otg: curmode: 1, host_only: 0 [ 2.060725] dwc_otg: Using Buffer DMA mode [ 2.060747] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1 [ 2.065677] dwc_otg: Working on port type = OTG [ 2.070167] dwc_otg: Current port type: SLAVE [ 2.074542] dwc_otg dwc2_a: DWC OTG Controller [ 2.078888] dwc_otg dwc2_a: new USB bus registered, assigned bus number 2 [ 2.085613] dwc_otg dwc2_a: irq 62, io mem 0x00000000 [ 2.090937] hub 2-0:1.0: USB hub found [ 2.094327] hub 2-0:1.0: 1 port detected [ 2.098307] dwc_otg: Dedicated Tx FIFOs mode [ 2.102583] dwc_otg: using timer detectid change, ffffffc05d9e3000 [ 2.108812] BLASTER Driver Init [ 2.111765] secmon has 1 memory regions [ 2.115461] secmon: share in base: 0xffffff8000464000, share out base: 0xffffff8000466000 [ 2.123564] secmon secmon: assigned reserved memory node linux,secmon ok [ 2.130242] secmon: probe done [ 2.133304] storage: storage in base: 0xffffff8001700000 [ 2.138478] storage: storage out base: 0xffffff8001780000 [ 2.143819] storage: storage block base: 0xffffff8001800000 [ 2.149346] storage: probe done! [ 2.152576] Error: Driver 'ICPlus IP175C' is already registered, aborting... [ 2.159523] libphy: ICPlus IP175C: Error -16 in registering driver [ 2.166111] aml_sd_emmc_probe: line 2954 [ 2.169528] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 2.179055] aml_sd_emmc_reg_init 677 [ 2.182353] pdata->caps 60007 [ 2.185221] pdata->caps2 0 [ 2.187901] get property: ocr_avail, value:0x00200080 [ 2.194190] get property: f_min, value:0x00061a80 [ 2.200532] get property: f_max, value:0x0510ff40 [ 2.206783] get property: max_req_size, value:0x00020000 [ 2.213084] get property: irq_in, value:0x00000003 [ 2.219382] get property: irq_out, value:0x00000005 [ 2.225672] get property: power_level, value:0x00000001 [ 2.232009] dwc_otg: Indeed it is in host mode hprt0 = 00021501 [ 2.247805] get property: gpio_cd, str: [ 2.247834] get property: gpio_power, str: [ 2.252736] get property: pinname, str:sd [ 2.258176] get property: jtag_pin, str: [ 2.263432] get property: card_type, value:0x00000005 [ 2.269745] get property: gpio_dat3, str: [ 2.274991] get property: gpio_volsw, str: [ 2.337924] [aml_sd_emmc_probe] aml_sd_emmc_probe() success! [ 2.337963] aml_sd_emmc_probe: line 2954 [ 2.357880] [aml_is_card_insert] card OUT [ 2.357918] [aml_is_card_insert] card OUT [ 2.357918] [ 2.378125] aml_sd_emmc_reg_init 677 [ 2.378233] pdata->caps 80000d47 [ 2.379265] pdata->caps2 80a1 [ 2.382191] get property: ocr_avail, value:0x00200080 [ 2.388491] get property: f_min, value:0x00061a80 [ 2.394782] get property: f_max, value:0x05f5e100 [ 2.401083] get property: max_req_size, value:0x00020000 [ 2.407377] get property: pinname, str:emmc [ 2.412988] get property: card_type, value:0x00000001 [ 2.419286] get property: gpio_dat3, str: [ 2.424539] get property: hw_reset, str: [ 2.437826] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 2.438846] dwc_otg: Indeed it is in host mode hprt0 = 00001101 [ 2.487809] aml_emmc_hw_reset 1356 [ 2.487811] [aml_sd_emmc_probe] aml_sd_emmc_probe() success! [ 2.487962] ion_dev has 1 memory regions [ 2.500059] fb: osd_init_module [ 2.500135] fb: viu vsync irq: 35 [ 2.501478] meson-fb has 1 memory regions [ 2.506592] meson-fb meson-fb: assigned reserved memory node linux,meson-fb ok [ 2.512605] fb: osd_probe vinfo:ffffffc001c4d930 [ 2.517157] fb: Frame buffer memory assigned at [ 2.521477] fb: phy: 0x78000000, vir:0xffffff8003c00000, size=98304K [ 2.528359] fb: osd_set_res_bootargs : mode 12 [ 2.532742] fb: fb def : 1920 1080 1920 2160 32 [ 2.537170] fb: init fbdev bpp is:32 [ 2.540768] fb: ---------------clear fb0 memory [ 2.556010] emmc: BKOPS_EN bit is not set [ 2.557909] [aml_sd_voltage_switch] switch to 1.8V for a non-uhs device. [ 2.573418] fb: osd[0] canvas.idx =0x40 [ 2.573419] fb: osd[0] canvas.addr=0x78000000 [ 2.573421] fb: osd[0] canvas.width=7680 [ 2.573422] fb: osd[0] canvas.height=2160 [ 2.576257] emmc: clk 100000000 SDR mode tuning start [ 2.576462] rx_tuning_result[0][0] = 10 [ 2.576667] rx_tuning_result[0][1] = 10 [ 2.576869] rx_tuning_result[0][2] = 10 [ 2.577070] rx_tuning_result[0][3] = 10 [ 2.577274] rx_tuning_result[0][4] = 10 [ 2.577477] rx_tuning_result[0][5] = 10 [ 2.577680] rx_tuning_result[0][6] = 10 [ 2.577888] rx_tuning_result[0][7] = 10 [ 2.578111] rx_tuning_result[0][9] = 10 [ 2.578113] best_win_start =9, best_win_size =9 [ 2.578115] sd_emmc_regs->gclock =0x100024a, sd_emmc_regs->gadjust =0x32000 [ 2.578117] emmc: gclock =0x100024a, gdelay=0x72547276 [ 2.578118] gadjust=0x32000 [ 2.578232] emmc: try set sd/emmc to DDR mode [ 2.578235] emmc: try set sd/emmc to DDR mode [ 2.578238] emmc: clk 100000000 DDR mode tuning start [ 2.579184] rx_tuning_result[0][0] = 10 [ 2.580079] rx_tuning_result[0][1] = 10 [ 2.580975] rx_tuning_result[0][2] = 10 [ 2.581175] best_win_start =0, best_win_size =3 [ 2.581177] sd_emmc_regs->gclock =0x1000245, sd_emmc_regs->gadjust =0x12000 [ 2.581179] emmc: gclock =0x1000245, gdelay=0x72547276 [ 2.581180] gadjust=0x12000 [ 2.581247] emmc: new HS400 MMC card at address 0001 [ 2.581249] emmc: clock 100000000, 8-bit-bus-width [ 2.581249] [ 2.581553] mmcblk0: emmc:0001 8GND3R 7.28 GiB [ 2.581987] mmcblk0: p1 p2 [ 2.606613] Console: switching to colour frame buffer device 240x67 [ 2.758480] hub 1-1:1.0: USB hub found [ 2.768314] hub 1-1:1.0: 4 ports detected [ 2.769629] fb: Frame buffer memory assigned at [ 2.769630] fb: phy: 0x7e000000, vir:0xffffff8001980000, size=1024K [ 2.786215] fb: osd probe OK [ 2.786382] vout_serve: vout_init_module [ 2.790107] vout_serve: meson_vout_probe [ 2.793929] vout_serve: create vout attribute OK [ 2.798539] ge2d: ge2d_init_module [ 2.801961] ge2d: ge2d_dev major:244 [ 2.805546] ge2d: ge2d clock is 400 MHZ [ 2.809189] ge2d: ge2d: pdev=ffffffc05dad2800, irq=182, rstc=0xffffffc05b23f700, clk=ffffffc05da9fc00 [ 2.818358] ge2d: mapped phy: 0xd0160000 [ 2.822205] ge2d: ge2d start monitor [ 2.825813] ge2d: ge2d workqueue monitor start [ 2.825897] codec:Amlogic A/V streaming port init [ 2.826483] codec:get gate demux control ok ffffffc05b245e80 [ 2.826486] codec:get gate parser_top control ok ffffffc05b245f80 [ 2.826493] codec:get gate vpu_intr control ok ffffffc05b247080 [ 2.826498] codec:get gate vdec control ok ffffffc05b247180 [ 2.826660] codec:[tsync_pcr_init]init success. [ 2.826694] codec:regist mpeg12 codec profile [ 2.826726] codec:regist mpeg4 codec profile [ 2.826727] codec:amvdec_vc1 module init [ 2.826757] codec:regist vc1 codec profile [ 2.826758] codec:amvdec_h264 module init [ 2.826807] codec:regist h264 codec profile [ 2.826809] codec:amvdec_h264mvc module init [ 2.826839] codec:regist hmvc codec profile [ 2.826840] codec:amvdec_h264_4k2k module init [ 2.826870] codec:regist h264_4k2k codec profile [ 2.826872] codec:amvdec_h265 module init [ 2.826902] codec:regist hevc codec profile [ 2.826935] codec:regist mjpeg codec profile [ 2.826936] codec:amvdec_real module init [ 2.826966] codec:regist real codec profile [ 2.826967] codec:amvdec_avs module init [ 2.827000] codec:regist avs codec profile [ 2.827037] amvenc_avc_probe -- reserved memory config fail. [ 2.827039] amvenc_avc - cma memory pool size: 32 MB [ 2.827053] encode_wq_init. [ 2.827056] encode start monitor. [ 2.827117] encode workqueue monitor start. [ 2.827210] jpegenc module init [ 2.827304] codec:picdec_driver_probe called. [ 2.827306] picdec has 1 memory regions [ 2.827325] picdec picdec: assigned reserved memory node linux,picdec ok [ 2.827326] codec:picdec_driver_probe done. [ 2.827327] codec:reserved memory config fail , use CMA . [ 2.829505] codec:cma memory is 64c00000 , size is 3000000 [ 2.829848] codec:0 addr is 64c00000################ [ 2.829856] codec:1 addr is 64efd000################ [ 2.830000] switch_vpu_mem_pd: vpu_arb ON [ 2.830207] codec:create_ge2d_work_queue video task ok [ 2.830453] codec:register clk_set_setting cpu[31] [ 2.830652] di_module_init ok. [ 2.830656] di_module_init: major 240 [ 2.830775] di_probe [ 2.830848] deinterlace has 1 memory regions [ 2.830869] di reveser memory 0x76200000, size 30MB. [ 2.830875] deinterlace deinterlace: assigned reserved memory node linux,di ok [ 2.830975] rdma_register, rdma_table_addr ffffff800047a000 rdma_table_addr_phy 6004a000 reg_buf ffffffc05b28c000 [ 2.830977] rdma_register success, handle 1 table_size 8192 [ 2.830979] di_probe allocate rdma channel 1. [ 2.830982] DI hw version 2. [ 2.830990] 0x000000c3:Y=c3,U=0,V=0 [ 2.830991] 0x000000c4:Y=c4,U=0,V=0 [ 2.830993] 0x000000c5:Y=c5,U=0,V=0 [ 2.830994] 0x000000c6:Y=c6,U=0,V=0 [ 2.830995] 0x000000c7:Y=c7,U=0,V=0 [ 2.830997] 0x000000c8:Y=c8,U=0,V=0 [ 2.830998] 0x000000c9:Y=c9,U=0,V=0 [ 2.831001] 0x000000ca:Y=ca,U=0,V=0 [ 2.831002] 0x000000cb:Y=cb,U=0,V=0 [ 2.831004] 0x000000cc:Y=cc,U=0,V=0 [ 2.831006] 0x000000cd:Y=cd,U=0,V=0 [ 2.831007] 0x000000ce:Y=ce,U=0,V=0 [ 2.831009] 0x000000cf:Y=cf,U=0,V=0 [ 2.831135] di_probe here. [ 2.831147] switch_vpu_mem_pd: di_pre OFF [ 2.831290] efusekeynum: 4 [ 2.831297] efusekeyname: mac offset: 0 size: 6 [ 2.831302] efusekeyname: mac_bt offset: 6 size: 6 [ 2.831307] efusekeyname: mac_wifi offset: 12 size: 6 [ 2.831311] efusekeyname: usid offset: 18 size: 16 [ 2.831386] efuse efuse: probe OK! [ 2.831503] 6aml_unifykeys_init done! [ 2.831504] ppmgr module init func called [ 2.831536] ppmgr_driver_probe called [ 2.831539] ppmgr has 1 memory regions [ 2.831546] init ppmgr memsource 74200000->761fffff [ 2.831656] ppmgr_probe done [ 2.831840] ionvideo-000: V4L2 device registered as video13 [ 2.831846] [dsp]register dsp to char divece(257) [ 2.832091] amaudio: driver amaudio succuess! [ 2.832094] amlvideo_init called [ 2.832095] amlvideo_create_instance called [ 2.832097] v4l2_dev.name=:amlvideo-000 [ 2.832150] amlvideo-000: V4L2 device registered as video10 [ 2.832151] [ 2.832151] [ 2.832151] VECM init [ 2.832151] [ 2.832406] saradc c1108680.saradc: initialized by BL30 [ 2.832408] saradc c1108680.saradc: calibration start: [ 2.832455] saradc c1108680.saradc: nominal=0, value=8 [ 2.832501] saradc c1108680.saradc: nominal=256, value=254 [ 2.832547] saradc c1108680.saradc: nominal=512, value=510 [ 2.832592] saradc c1108680.saradc: nominal=768, value=766 [ 2.832638] saradc c1108680.saradc: nominal=1023, value=1021 [ 2.832640] saradc c1108680.saradc: calibration end: coef=4096 [ 2.832679] remote: Driver init [ 2.833005] aml-thermal aml-sensor@0: min state:500000 400 1 2 [ 2.833170] aml-thermal aml-sensor@0: not found gpucore node [ 2.833176] aml-thermal aml-sensor@0: gpu coef:437, pp:3 [ 2.838215] aml-thermal aml-sensor@0: cdev1 set upper to 3 [ 2.838218] aml-thermal aml-sensor@0: cdev2 set upper to 3 [ 2.838221] aml-thermal aml-sensor@0: cdev0 set upper to 3 [ 2.841238] input: cec_input as /devices/virtual/input/input0 [ 2.841414] cectx c810023c.aocec: aml_cec_probe(): can't find hdmirx [ 2.842242] 6-------------------------------------------------------- [ 2.842244] 6odroid_sysfs_init(321) : Sleep Enable !! [ 2.842245] 6-------------------------------------------------------- [ 2.842370] input: vt-input as /devices/virtual/input/input1 [ 2.842426] 6Virtual-Key input driver registered!! [ 2.842819] adbattery: android dummy battery driver loaded [ 2.843150] enter aml_soc_platform_pcm2bt_probe [ 2.843365] divider=16,frac=33920000,SDMval=4523 [ 2.843464] enter aml_pcm_dai_probe [ 2.843493] [aml-spdif-dai]enter aml_dai_spdif_init [ 2.843542] aml_spdif_probe [ 2.843630] enter spdif_dit_probe [ 2.844207] odroid_hdmi_snd odroid_hdmi: dit-hifi <-> I2S mapping ok [ 2.844749] GACT probability on [ 2.844753] Mirror/redirect action on [ 2.844754] u32 classifier [ 2.844755] Performance counters on [ 2.844756] input device check on [ 2.844757] Actions configured [ 2.844855] TCP: cubic registered [ 2.845217] NET: Registered protocol family 10 [ 2.845938] mip6: Mobile IPv6 [ 2.845941] sit: IPv6 over IPv4 tunneling driver [ 2.846592] NET: Registered protocol family 17 [ 2.846607] NET: Registered protocol family 15 [ 2.846639] Bridge firewalling registered [ 2.846710] Bluetooth: RFCOMM TTY layer initialized [ 2.846722] Bluetooth: RFCOMM socket layer initialized [ 2.846738] Bluetooth: RFCOMM ver 1.11 [ 2.846743] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.846744] Bluetooth: BNEP filters: protocol multicast [ 2.846750] Bluetooth: BNEP socket layer initialized [ 2.846751] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.846757] Bluetooth: HIDP socket layer initialized [ 2.846773] NET: Registered protocol family 35 [ 2.846900] Key type dns_resolver registered [ 2.847259] Registering SWP/SWPB emulation handler [ 2.847500] registered taskstats version 1 [ 2.847553] AppArmor: AppArmor sha1 policy hashing enabled [ 2.847576] regulator-dummy: disabling [ 2.847664] drivers/rtc/hctosys.c: unable to open rtc device (rtc0) [ 2.848584] 6enter meson_pm_probe! [ 2.848651] meson_pm_probe done [ 2.848837] ALSA device list: [ 2.848839] #0: ODROID-HDMI [ 3.495258] Freeing unused kernel memory: 872K (ffffffc001ad0000 - ffffffc001baa000) [ 3.525939] systemd-udevd[103]: starting version 215 [ 3.530463] random: systemd-udevd: uninitialized urandom read (16 bytes read, 100 bits of entropy available) [ 3.687132] random: nonblocking pool is initialized [ 3.917897] raid6: int64x1 518 MB/s [ 4.087883] raid6: int64x2 830 MB/s [ 4.257815] raid6: int64x4 1310 MB/s [ 4.427841] raid6: int64x8 1403 MB/s [ 4.486216] switch_vpu_mem_pd: viu_vd1 OFF [ 4.490040] switch_vpu_mem_pd: afbc_dec OFF [ 4.493817] switch_vpu_mem_pd: di_post OFF [ 4.497579] switch_vpu_mem_pd: viu_vd2 OFF [ 4.597837] raid6: neonx1 910 MB/s [ 4.767814] raid6: neonx2 1462 MB/s [ 4.937798] raid6: neonx4 1901 MB/s [ 5.107828] raid6: neonx8 1989 MB/s [ 5.111548] raid6: using algorithm neonx8 (1989 MB/s) [ 5.115262] raid6: using intx1 recovery algorithm [ 5.119782] xor: measuring software checksum speed [ 5.217799] 8regs : 2846.000 MB/sec [ 5.317798] 8regs_prefetch: 2612.000 MB/sec [ 5.417797] 32regs : 3467.200 MB/sec [ 5.517797] 32regs_prefetch: 2940.800 MB/sec [ 5.521344] xor: using function: 32regs (3467.200 MB/sec) [ 5.535550] bio: create slab <bio-1> at 1 [ 5.539792] Btrfs loaded [ 5.543426] BTRFS: selftest: Running btrfs free space cache tests [ 5.547453] BTRFS: selftest: Running extent only tests [ 5.552601] BTRFS: selftest: Running bitmap only tests [ 5.557643] BTRFS: selftest: Running bitmap and extent tests [ 5.563272] BTRFS: selftest: Free space cache tests finished [ 5.568859] BTRFS: selftest: Running extent buffer operation tests [ 5.574793] BTRFS: selftest: Running btrfs_split_item tests [ 5.581748] BTRFS: selftest: Running find delalloc tests [ 5.830047] BTRFS: selftest: Running btrfs_get_extent tests [ 5.833797] BTRFS: selftest: Running hole first btrfs_get_extent test [ 6.071280] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback [ 6.211678] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 6.223763] systemd[1]: Detected architecture 'arm64'. [ 6.250560] systemd[1]: Inserted module 'autofs4' [ 6.255721] systemd[1]: Set hostname to <odroidc2>. [ 6.403316] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. [ 6.418275] systemd[1]: Expecting device dev-ttyS0.device... [ 6.427781] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 6.434497] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.441859] systemd[1]: Starting Remote File Systems (Pre). [ 6.452203] systemd[1]: Reached target Remote File Systems (Pre). [ 6.457385] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point. [ 6.471231] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 6.479773] systemd[1]: Starting Encrypted Volumes. [ 6.489431] systemd[1]: Reached target Encrypted Volumes. [ 6.494133] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 6.501890] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 6.509654] systemd[1]: Starting Paths. [ 6.519152] systemd[1]: Reached target Paths. [ 6.523853] systemd[1]: Expecting device dev-mmcblk0p1.device... [ 6.533910] systemd[1]: Starting Root Slice. [ 6.543793] systemd[1]: Created slice Root Slice. [ 6.548697] systemd[1]: Starting User and Session Slice. [ 6.558831] systemd[1]: Created slice User and Session Slice. [ 6.563928] systemd[1]: Starting Delayed Shutdown Socket. [ 6.574663] systemd[1]: Listening on Delayed Shutdown Socket. [ 6.579883] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 6.591890] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 6.598451] systemd[1]: Starting Journal Socket (/dev/log). [ 6.609505] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.615086] systemd[1]: Starting udev Control Socket. [ 6.625949] systemd[1]: Listening on udev Control Socket. [ 6.631317] systemd[1]: Starting udev Kernel Socket. [ 6.642269] systemd[1]: Listening on udev Kernel Socket. [ 6.647735] systemd[1]: Starting Journal Socket. [ 6.658890] systemd[1]: Listening on Journal Socket. [ 6.664434] systemd[1]: Starting System Slice. [ 6.675703] systemd[1]: Created slice System Slice. [ 6.681270] systemd[1]: Started File System Check on Root Device. [ 6.687192] systemd[1]: Starting system-systemd\x2dfsck.slice. [ 6.698858] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 6.704973] systemd[1]: Starting system-getty.slice. [ 6.716244] systemd[1]: Created slice system-getty.slice. [ 6.721738] systemd[1]: Starting system-serial\x2dgetty.slice. [ 6.732992] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 6.739099] systemd[1]: Starting Increase datagram queue length... [ 6.751954] systemd[1]: Starting Restore / save the current clock... [ 6.766108] systemd[1]: Mounting Huge Pages File System... [ 6.778778] systemd[1]: Mounting POSIX Message Queue File System... [ 6.794330] systemd[1]: Starting Load Kernel Modules... [ 6.808662] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 6.824916] fuse init (API version 7.22) [ 6.825076] systemd[1]: Starting udev Coldplug all Devices... [ 6.842920] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) [ 6.843452] systemd[1]: Mounting Debug File System... [ 6.862982] systemd[1]: Started Set Up Additional Binary Formats. [ 6.868866] systemd[1]: Starting LSB: Set keymap... [ 6.880652] systemd[1]: Starting Slices. [ 6.891332] systemd[1]: Reached target Slices. [ 6.902829] systemd[1]: Mounted Debug File System. [ 6.913259] systemd[1]: Mounted POSIX Message Queue File System. [ 6.924002] systemd[1]: Mounted Huge Pages File System. [ 6.935084] systemd[1]: Started Increase datagram queue length. [ 6.946917] systemd[1]: Started Restore / save the current clock. [ 6.959152] systemd[1]: Started Load Kernel Modules. [ 6.970631] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 6.987249] systemd[1]: Started LSB: Set keymap. [ 6.994929] systemd[1]: Time has been changed [ 7.029950] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.043494] systemd[1]: Mounting Configuration File System... [ 7.055945] systemd[1]: Starting Apply Kernel Variables... [ 7.068917] systemd[1]: Mounting FUSE Control File System... [ 7.081563] systemd[1]: Starting Syslog Socket. [ 7.092936] systemd[1]: Listening on Syslog Socket. [ 7.098346] systemd[1]: Starting Journal Service... [ 7.116189] systemd[1]: Started Journal Service. [ 7.184514] systemd-udevd[205]: starting version 215 [ 7.353503] Driver for 1-wire Dallas network protocol. [ 7.525252] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.619138] ionvideo open [ 7.784520] Adding 131068k swap on /var/swap. Priority:-1 extents:2 across:139260k SS [ 7.817839] ionvideo_stop_generating!!!! [ 7.817862] ionvideo release [ 7.921558] systemd-journald[204]: Received request to flush runtime journal from PID 1 [ 8.309850] vout_serve: vmode set to 1080p60hz [ 8.309850] [ 8.309861] vout_serve: don't set the same mode as current. [ 8.328343] fb: osd[1] canvas.idx =0x43 [ 8.328345] fb: osd[1] canvas.addr=0x7e000000 [ 8.328347] fb: osd[1] canvas.width=128 [ 8.328348] fb: osd[1] canvas.height=32 [ 8.354734] vout_serve: vmode set to 1080p60hz [ 8.354734] [ 8.354744] vout_serve: don't set the same mode as current. [ 8.417197] Registered IR keymap rc-empty [ 8.417367] input: meson-ir as /devices/platform/c8100580.meson-ir/rc/rc0/input2 [ 8.418553] rc0: meson-ir as /devices/platform/c8100580.meson-ir/rc/rc0 [ 8.423217] IR NEC protocol handler initialized [ 8.443330] IR RC6 protocol handler initialized [ 8.445460] IR RC5(x) protocol handler initialized [ 8.445480] IR JVC protocol handler initialized [ 8.445906] IR Sony protocol handler initialized [ 8.447516] IR SANYO protocol handler initialized [ 8.450980] meson-ir c8100580.meson-ir: AO_RTI_PIN_MUX : 0x19801 [ 8.450987] meson-ir c8100580.meson-ir: receiver initialized [ 8.452231] lirc_dev: IR Remote Control driver registered, major 235 [ 8.453983] rc rc0: lirc_dev: driver ir-lirc-codec (meson-ir) registered at minor = 0 [ 8.453986] IR LIRC bridge handler initialized [ 8.454856] input: MCE IR Keyboard/Mouse (meson-ir) as /devices/virtual/input/input3 [ 8.455064] IR MCE Keyboard/mouse protocol handler initialized Debian GNU/Linux 8 odroidc2 ttyS0 Meson chip version = RevB (1F:B - 0:0) [aml_is_card_insert] card OUT [aml_is_card_insert] card OUT aml_sd_emmc_reg_init 677 Yours: Meson chip version = RevC (1F:C - 0:0) [aml_is_card_insert] card IN [aml_is_card_insert] card IN normal card in aml_sd_emmc_reg_init 677 Crash where mine do this: ionvideo-000: V4L2 device registered as video13 [dsp]register dsp to char divece(257) amaudio: driver amaudio succuess! amlvideo_init called amlvideo_create_instance called v4l2_dev.name=:amlvideo-000 amlvideo-000: V4L2 device registered as video10 Link to comment Share on other sites More sharing options...
MICE Posted November 9, 2016 Author Share Posted November 9, 2016 are there updates on the Hardkernel front? Link to comment Share on other sites More sharing options...
smn Posted November 14, 2016 Share Posted November 14, 2016 I am experiencing exactly the same issue with my C2, booting form eMMC, upgrading and rebooting twice. I have completely disabled the video system in boot.ini since you indicated above it might be connected to the video system. The problem still persists. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted November 14, 2016 Share Posted November 14, 2016 I have found this: https://github.com/offensive-security/kali-arm-build-scripts/issues/76 Describes essentially the same problem, no solution yet. Meanwhile it would be interesting how do single partition beta images work. Please test beta image from here: http://image.armbian.com/betaimages/ Link to comment Share on other sites More sharing options...
smn Posted November 14, 2016 Share Posted November 14, 2016 I will try so tonight and will report. Link to comment Share on other sites More sharing options...
smn Posted November 14, 2016 Share Posted November 14, 2016 I have downloaded the beat image for Odroid C2, burned it onto the eMMC module using Etcher and booted the device. Everything seems to work fine, apt-get update / upgrade do not show any updates besides some unimportant libraries. Rebooting twice, three times, ... works all fine. Can you draw any conclusion from this? Will there be an updated headless Debian Jessie image any time soon? Link to comment Share on other sites More sharing options...
andrwmorph Posted November 18, 2016 Share Posted November 18, 2016 I've been able to get it to work by installing the linux-firmware-image-odroidc2 package after an apt-get upgrade. Link to comment Share on other sites More sharing options...
smn Posted November 18, 2016 Share Posted November 18, 2016 Hm, this does not work for me. What I did: Fresh install of Jessie Server, 5.21 image boot apt-get update, sudo apt-get upgrade apt-get install linux-firmware-image-odroidc2 reboot -> everything allright reboot -> blue light, stuck at boot Link to comment Share on other sites More sharing options...
Igor Posted November 19, 2016 Share Posted November 19, 2016 Hm, this does not work for me. What I did: Fresh install of Jessie Server, 5.21 image boot apt-get update, sudo apt-get upgrade apt-get install linux-firmware-image-odroidc2 reboot -> everything allright reboot -> blue light, stuck at boot Yes, this is known to break on some boards withing eMMC. Please try images from beta section since they are done differently. Link to comment Share on other sites More sharing options...
smn Posted November 19, 2016 Share Posted November 19, 2016 Hi Igor, as stated above, beta image works fine (the 5.24 Xenial Image). I'd love to run a headless Debian Jessie, but there is no image yet. Do you have an estimate on when you will be able to release it? Best, Simon Link to comment Share on other sites More sharing options...
Igor Posted November 19, 2016 Share Posted November 19, 2016 I'll try replace those images within next couple of hours and post a note here when done. Link to comment Share on other sites More sharing options...
andrwmorph Posted November 19, 2016 Share Posted November 19, 2016 Hm, this does not work for me. What I did: Fresh install of Jessie Server, 5.21 image boot apt-get update, sudo apt-get upgrade apt-get install linux-firmware-image-odroidc2 reboot -> everything allright reboot -> blue light, stuck at boot Hmm sorry about that. It must have been that combined with something else I did because one of my boards is working and the others ran into this same issue. Edit: I putzed around a bit more and found that running apt-get install --reinstall linux-dtb-odroidc2 linux-firmware-image-odroidc2 linux-headers-odroidc2 linux-image-odroidc2 linux-jessie-root-odroidc2 linux-u-boot-odroidc2-default after the upgrade seems to get it working. It is probably best to wait for Igor to fix things though Link to comment Share on other sites More sharing options...
smn Posted November 20, 2016 Share Posted November 20, 2016 I'll try replace those images within next couple of hours and post a note here when done. Okay, great, thank you so much! Link to comment Share on other sites More sharing options...
smn Posted November 23, 2016 Share Posted November 23, 2016 @andrwmorph indeed, reinstalling all packages resolves the problem for me. Thanks for sharing! @Igor: any news with the packages? Do you expect any problems if I now install 5.21 from the Debian Jessie image, upgrade with above method, and later on update to 5.24 once you have it released? Link to comment Share on other sites More sharing options...
Igor Posted November 24, 2016 Share Posted November 24, 2016 It looks like the problem is related with partition resizing. In this case, better start with a new image ... when it will be updated, or build from sources. It's fixed there. Link to comment Share on other sites More sharing options...
smn Posted November 28, 2016 Share Posted November 28, 2016 Hi Igor, thanks for the answer, then I'll wait for the new images. /Simon Link to comment Share on other sites More sharing options...
