Network not coming up
ytn
I created a Jessie image for BananaPi with the latest / next kernel, and when booting the image, it get's stuck on "A start job is running for LSB: Raise network interfaces". It never seems to complete raising the interface, and since there is no time limit, this goes on forever.
Creating a Wheezy image seems to work fine (also using latest / next kernel).
Any suggestions on how I can get the Jessie image up and running?
Thanks.
I made my own kernel with the configuration of Kernel-4.1.2, this works also. I found out that the dvbsky-driver should be compiled as module, not like in Igor's configuration für Kernel-4.2.2. When I boot up with a connected dvbsky the kernel crashes totally.
But with the older configuration I still have the problem with the clocksource (" clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 21718868714 ns" for example)
My bananapi works now with self-compiled kernel-4.2.3
