How to boot from my Android TV Box?
Adan
Nothing, I tried with a 64 GB SD Card and the result is; the TV box detects the storage, but it asks me to format it to use it.
I tried with Balena Etcher and Rufus but the result is the same. I guess its not possible to install Armbian in a GIGA TV BOX 890 HD.
Ill try another attempt with an 32 GB SD Card, but I think the TV BOX has some kind of anti software protection or something like that.
@SteeMan Thank you so much for your help!!
I finally succeded installing Armbian for my TV box.
I just open ADB and used "shell" command
Then I used "reboot update" and it started armbian.
The only problem I have now is the resolution, everything seems too small because im using a TV instead of a monitor.
Can I change the resolution?
Anyways
*If you are reading this and have the same problem I had*
Dont use the update application, use shell command in ADB
And then, "reboot update"
Edited by Adan
