dwhacks Posted November 3, 2016 Share Posted November 3, 2016 Well a little info, I've been using my orangepi one with an SDR dongle to track airplanes with flightradar24 for the last few months. My intentions were to use a POE adapter and run the board outside near the antenna at one point. I have now received the final parts and went to move it today. It has been running flawlessly for a month with my POE adapter off of a switch near my PC in my shop. I now plan on connecting it to the main switch on my LAN. So previously my setup was: Router -> switch -> long ethernet to shop -> swtich -> orangepione now I want to run it: Router -> switch -> long ethernet to outside -> orangepione But for some reason this doesn't work, it doesn't connect to the LAN unless it is behind both switches. After booting it says: phy: gmac0-0:00 - link is up full/100 phy: gmac0-0:00 - link is down And repeats this every couple seconds. But if I unplug the ethernet cable and add the second switch between then it connects just fine. My laptop connects fine behind either setups so it cant be the cables. Any ideas? are there settings in armbian that could be giving me these issues? 1 Link to comment Share on other sites More sharing options...
pzw Posted November 3, 2016 Share Posted November 3, 2016 Is your cable not too long? Ethernet cable length cannot exceed 100m in total! If it's longer you need an active device in between... Link to comment Share on other sites More sharing options...
dwhacks Posted November 3, 2016 Author Share Posted November 3, 2016 I thought it might be that at first, but it does the same thing if I use a 5" cable. I have only ever used my orangepi in my shop and at first I had the 2 ethernet ports on my shop computer bridged so I could plug it into that to get internet, but then I wanted to go on vacation and wanted to turn off my computer but leave the orangepi running so I put a cheap switch there instead. Now that Im trying to run it directly from the main switch on my LAN it work connect. Every other device on my lan connects fine through this switch and I've tried different cables and different ports. Link to comment Share on other sites More sharing options...
pzw Posted November 3, 2016 Share Posted November 3, 2016 In that case check if the cable is wired correctly. Should be straight through ... Also check if the connector is crimped properly... Link to comment Share on other sites More sharing options...
dwhacks Posted November 3, 2016 Author Share Posted November 3, 2016 I have tried 5 different cables, and all of them work with my laptop but not with the orangepi UNLESS there is an additional switch added between. Maybe it has something to do with my router but every other device works as it should. Link to comment Share on other sites More sharing options...
dwhacks Posted November 3, 2016 Author Share Posted November 3, 2016 My cables are wired 568b Link to comment Share on other sites More sharing options...
pzw Posted November 3, 2016 Share Posted November 3, 2016 Try "sudo ethtool -s eth0 speed 100 duplex full autoneg off" ... 1 Link to comment Share on other sites More sharing options...
dwhacks Posted November 4, 2016 Author Share Posted November 4, 2016 Thanks pzw, that worked. Now how to make this persistant and make sure it will always work? Also, what does this tell us that was wrong? Link to comment Share on other sites More sharing options...
pzw Posted November 4, 2016 Share Posted November 4, 2016 Good news . Your switch and opi one don't negotiate the link correctly. That sometimes happens. I think you can use the h3consumption tool to make it persistent. (I don't have access to an opi at the moment...) Link to comment Share on other sites More sharing options...
dwhacks Posted November 5, 2016 Author Share Posted November 5, 2016 Well the only way that has worked so far is to create a script in init.d #!/bin/sh ETHTOOL="/sbin/ethtool" DEV="eth0" SPEED="100 duplex full" AUTONEG="off" case "$1" in start) echo -n "Setting eth0 speed 100 duplex full autoneg off..."; $ETHTOOL -s $DEV speed $SPEED autoneg $AUTONEG; echo " done.";; stop) ;; esac exit 0 Is there a better way to do it? I tried adding the command with pre-up or post-up to /etc/network/interfaces but that didn't work at all. Thanks for all the help this far! Link to comment Share on other sites More sharing options...
dwhacks Posted November 5, 2016 Author Share Posted November 5, 2016 Another strange thing is; using speedtest-cli I get really slow downloads (~0.33 Mbit/s) but my uploads are as expected (2-3 Mbit/s). Could that be a crappy SD card even if its "saving" the file to /dev/null ? Link to comment Share on other sites More sharing options...
emorysmith Posted January 16, 2017 Share Posted January 16, 2017 My OPPC+ wouldn't boot unless connected to our U-Verse router. No boot through HP Procurve 2626 switch.I changed the OP's port on the switch from "100fdpx" to "Auto 100" and within seconds, the OP was booting. Kind of the opposite problem to yours but it worked. Link to comment Share on other sites More sharing options...
emorysmith Posted January 16, 2017 Share Posted January 16, 2017 BTW, I am running dump1090, etc. on a RasPi. Thinking about using my OPPC+ with two RTL dongles. Where did you get the OP software?Since it requires compiling, would the RasPi source work? Thanks! Link to comment Share on other sites More sharing options...
dwhacks Posted January 16, 2017 Author Share Posted January 16, 2017 Wow, funny thing is, that's the same switch I have! I dont seem to have the option for auto100. I only have "auto" and "auto10" also 10HDx, 100HDx, 10FDx, and 100FDx. As for the ABS-D tracker I followed these two guides: https://primalcortex.wordpress.com/2016/05/13/orange-pi-pc-armbian-and-sdr/ and https://www.hackster.io/BuddyC/c-h-i-p-radar-0da2d1 1 Link to comment Share on other sites More sharing options...
