sovking Posted November 17, 2016 Share Posted November 17, 2016 I've an OrangePI PC. I would like install, enable and start watchdog. I installed watchdog using apt-get install watchdog. But install seems to require some tweaks. I tried to googling but until now nothing works. Any hints ? Thanks! Link to comment Share on other sites More sharing options...
gnasch Posted November 17, 2016 Share Posted November 17, 2016 try: echo 1 > /dev/watchdog, then see what happens. if there is a reaction, the kernel module works. then check /etc/default/watchdog int top there should be a process watchdog, killing it would produce a process wd_keepalive, killing that should reboot. best, gnasch Link to comment Share on other sites More sharing options...
sovking Posted November 17, 2016 Author Share Posted November 17, 2016 If I try echo 1 > /dev/watchdog after some second the machine reboot. Looking in /var/log/messages I see: Nov 17 16:17:09 localhost kernel: [ 3.249893] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0Nov 17 16:17:09 localhost kernel: [ 3.259938] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbfNov 17 16:17:09 localhost kernel: [ 3.271394] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)Nov 17 16:17:09 localhost kernel: [ 3.284826] wdt_enable, write reg 0xf1c20cb8 val 0x00000000Nov 17 16:17:09 localhost kernel: [ 3.294179] timeout_to_interv, line 167Nov 17 16:17:09 localhost kernel: [ 3.301540] interv_to_timeout, line 189Nov 17 16:17:09 localhost kernel: [ 3.308824] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec It seems watchdog module... Isn't it ? Looking at /etc/default/watchdog # Start watchdog at boot time? 0 or 1run_watchdog=1# Start wd_keepalive after stopping watchdog? 0 or 1run_wd_keepalive=1# Load module before starting watchdogwatchdog_module="none"# Specify additional watchdog options here (see manpage). (I've non manpages...) I tried even adding in that file: watchdog_options=" -F -v " without any results. I don't find any process watchdog except [watchdog], nor wd_keepalive. I'm running Armbian 5.23 (Legacy/default server). Any suggestion ? Link to comment Share on other sites More sharing options...
gnasch Posted November 18, 2016 Share Posted November 18, 2016 (edited) If it reboots after "echo" , then watchdog is present and active in kernel. i have 4 watchdog processes, one per processor. root@orangepipcplus:/etc/init.d# ps aux |grep watch root 7 0.0 0.0 0 0 ? S Nov17 0:01 [watchdog/0] root 11 0.0 0.0 0 0 ? S Nov17 0:01 [watchdog/1] root 15 0.0 0.0 0 0 ? S Nov17 0:01 [watchdog/2] root 19 0.0 0.0 0 0 ? S Nov17 0:01 [watchdog/3] root 19080 0.0 0.0 3924 760 pts/1 S+ 14:45 0:00 grep watch root@orangepipcplus:/etc/init.d# my /etc/watchdog.conf is this: #ping = 172.31.14.1 #ping = 172.26.1.255 #interface = eth0 #file = /var/log/messages #change = 1407 # Uncomment to enable test. Setting one of these values to '0' disables it. # These values will hopefully never reboot your machine during normal use # (if your machine is really hung, the loadavg will go much higher than 25) #max-load-1 = 24 #max-load-5 = 18 #max-load-15 = 12 # Note that this is the number of pages! # To get the real size, check how large the pagesize is on your machine. #min-memory = 1 #allocatable-memory = 1 #repair-binary = /usr/sbin/repair #repair-timeout = #test-binary = #test-timeout = watchdog-device = /dev/watchdog # Defaults compiled into the binary temperature-device =/sys/class/thermal/thermal_zone0/temp max-temperature = 120 # Defaults compiled into the binary #admin = root interval = 1 logtick = 60 log-dir = /var/log/watchdog # This greatly decreases the chance that watchdog won't be scheduled before # your machine is really loaded realtime = yes priority = 1 # Check if rsyslogd is still running by enabling the following line #pidfile = /var/run/rsyslogd.pid and in /etc/init.d/watchdog it looks like that: Spoiler #!/bin/sh #/etc/init.d/watchdog: start watchdog daemon. ### BEGIN INIT INFO # Provides: watchdog # Short-Description: Start software watchdog daemon # Required-Start: $all # Required-Stop: $all # Should-Start: # Should-Stop: # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 ### END INIT INFO PATH=/bin:/usr/bin:/sbin:/usr/sbin test -x /usr/sbin/watchdog || exit 0 # For configuration of the init script use the file # /etc/default/watchdog, do not edit this init script. # Set run_watchdog to 1 to start watchdog or 0 to disable it. run_watchdog=0 # Specify additional watchdog options here (see manpage). watchdog_options="" # Specify module to load watchdog_module="none" # Set run_wd_keepalive to 1 to start wd_keepalive after stopping watchdog or 0 # to disable it. Running it is the default. run_wd_keepalive=1 [ -e /etc/default/watchdog ] && . /etc/default/watchdog NAME=watchdog KEEPALIVE_NAME=wd_keepalive DAEMON=/usr/sbin/watchdog KEEPALIVE_DAEMON=/usr/sbin/wd_keepalive STOP_RETRY_SCHEDULE='TERM/10/forever/KILL/1' # Get lsb functions . /lib/lsb/init-functions case "$1" in start) if [ $run_watchdog = 1 ] then # do we have to load a module? [ "${watchdog_module:-none}" != "none" ] && /sbin/modprobe $watchdog_module # make sure that wd_keepalive is stopped log_begin_msg "Stopping watchdog keepalive daemon..." start-stop-daemon --stop --quiet --oknodo --retry $STOP_RETRY_SCHEDULE \ --pidfile /var/run/$KEEPALIVE_NAME.pid log_end_msg $? # also remove the sendsigs omit file rm -f /run/sendsigs.omit.d/$KEEPALIVE_NAME.pid # Unconditionally start watchdog daemon because we want to run it even # if wd_keepalive wasn't running log_begin_msg "Starting watchdog daemon..." start-stop-daemon --start --quiet --pidfile /var/run/$NAME.pid \ --exec $DAEMON -- $watchdog_options log_end_msg $? fi ;; stop) if [ $run_watchdog = 1 ] then log_begin_msg "Stopping watchdog daemon..." start-stop-daemon --stop --quiet --retry $STOP_RETRY_SCHEDULE \ --pidfile /var/run/$NAME.pid log_end_msg $? if [ $run_wd_keepalive = 1 ] then # make sure that wd_keepalive is started if instructed to do so log_begin_msg "Starting watchdog keepalive daemon..." start-stop-daemon --start --quiet --pidfile /var/run/$KEEPALIVE_NAME.pid \ --exec $KEEPALIVE_DAEMON -- $watchdog_options log_end_msg $? # and tell sendsigs to ignore it ln -s /var/run/$KEEPALIVE_NAME.pid /run/sendsigs.omit.d/$KEEPALIVE_NAME.pid fi fi ;; restart) $0 force-reload ;; force-reload) if [ $run_watchdog = 0 ]; then exit 0; fi log_daemon_msg "Restarting $NAME" log_progress_msg "Stopping $NAME daemon..." start-stop-daemon --stop --pidfile /var/run/$NAME.pid --quiet \ --retry $STOP_RETRY_SCHEDULE || log_end_msg $? log_progress_msg "Starting $NAME daemon..." start-stop-daemon --start --quiet --pidfile /var/run/$NAME.pid \ --exec $DAEMON -- $watchdog_options log_end_msg $? ;; status) status_of_proc "$DAEMON" watchdog ;; *) echo "Usage: /etc/init.d/watchdog {start|stop|restart|force-reload|status}" exit 1 esac exit 0 Hope this helps Edited December 4, 2017 by Tido added spoiler Link to comment Share on other sites More sharing options...
dottgonzo Posted November 21, 2016 Share Posted November 21, 2016 There is an hardware watchdog module also on orange pi lite, one and zero? Link to comment Share on other sites More sharing options...
gnasch Posted November 21, 2016 Share Posted November 21, 2016 the watchdog is integrated in H3 SOC, I have no idea about H2+. best, gnasch Link to comment Share on other sites More sharing options...
tkaiser Posted November 21, 2016 Share Posted November 21, 2016 I have no idea about H2+ H2+ is just a crippled H3 (no GbE MAC exposed, no 4K HDMI support): root@orangepizero:~# echo 1 > /dev/watchdog root@orangepizero:~# Write failed: Broken pipe macbookpro-tk:~ tk$ slogin orangepizero.local tk@orangepizero.local's password: ___ ____ _ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) |__ /___ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | / // _ \ '__/ _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | / /| __/ | | (_) | \___/|_| \__,_|_| |_|\__, |\___| |_| |_| /____\___|_| \___/ |___/ Welcome to ARMBIAN Ubuntu 16.04.1 LTS 3.4.113-sun8i System load: 0.34 Up time: 2 min Memory usage: 13 % of 241Mb IP: 192.168.83.153 CPU temp: 30°C Usage of /: 9% of 15G [ 10 updates to install: apt-get upgrade ] Last login: Thu Nov 17 06:20:41 2016 from 192.168.83.91 Link to comment Share on other sites More sharing options...
dottgonzo Posted November 21, 2016 Share Posted November 21, 2016 so every board got it and i can start to work with the hw one. What are the differences between the software watchdog and the hardware one, in addiction to the stability of the hw one? I've enabled only the software one in my project for compatibility, but i've never tested the hw watchdog, and don't know if it is compliant (for example in my app during the initial boot the watchdog first start with a certain configuration, then my application stop it, change the configuration, and then restart it), as i readed (but never tried) i can't stop the hw watchdog. Link to comment Share on other sites More sharing options...
olivluca Posted September 24, 2017 Share Posted September 24, 2017 I have a different problem: I'm trying to ping /dev/watchdog directly, without using the watchdog package. The problem is that the watchdog resets the board (opi pc, legacy kernel) even if I keep writing to /dev/watchdog. If I write the magic char 'V' to /dev/watchdog before the timeout expires then it doesn't reset (and that's ok). This is the test python script I'm using, I'm using chr(0) because that's what the sample program does, but anything (except 'V' for obvious reasons) should work: import time f=open('/dev/watchdog','w') try: while True: time.sleep(1) print '.' f.write(chr(0)) except KeyboardInterrupt: print 'end' f.write('V') f.close() Link to comment Share on other sites More sharing options...
olivluca Posted September 24, 2017 Share Posted September 24, 2017 Strangely enough the IOCTL interface works (strange because, looking at the source of sunxi_wdt in theory either writing to the device or using the ioctl should trigger the same function watchdog_kick) import time import fcntl f=open('/dev/watchdog','w') try: while True: time.sleep(1) print '.' fcntl.ioctl(f,0x80045705) #WDIOC_KEEPALIVE except KeyboardInterrupt: print 'end' f.write('V') f.close() Link to comment Share on other sites More sharing options...
Nuno Goncalves Posted December 3, 2017 Share Posted December 3, 2017 I've just tested the watchdog on Orange Pi Zero (H2+) with Linus 4.15-rc1 and it works fine: sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=1) (I have compiled Linux with the nowayout option). If I open /dev/watchdog it starts, and if don't open it/write whithin 16s it reboots the board. Is there a way to permanently enable the watchdog, from power-on, or at least from u-boot? Also is there a way to adjust the timeout to a larger value? Thanks! Link to comment Share on other sites More sharing options...
Nuno Goncalves Posted December 3, 2017 Share Posted December 3, 2017 Actually from the H3 datasheet I can see that 16s is the maximum allowed. I guess my question is only if there is any support on u-boot mainline to start the watchdog. Link to comment Share on other sites More sharing options...
Petrunin Alex Posted February 1, 2018 Share Posted February 1, 2018 Hi - easiest way i found 1) In /etc/systemd/system.conf set\uncomment (max seconds on H3 you can see in g_timeout in 'dmesg | grep "sunxi_wdt_probe"'. On H2 'dmesg | grep "watchdog"'. Its ok to set to 16 - it try to send "pings" every half of seted timer) RuntimeWatchdogSec=16 ShutdownWatchdogSec=10min 2) reboot, after it check output of "sudo lsof | grep /dev/watchdog" - if it say about systemd - all work 3) (DONT RUN THIS ON PRODUCTION SERVERS) test with fork-bomb with and without P.S. - work ok on H2\H3 1 Link to comment Share on other sites More sharing options...
Igor_K Posted February 11, 2018 Share Posted February 11, 2018 There is no need for reboot, systemctl daemon-reexec just works Link to comment Share on other sites More sharing options...
cabled Posted January 14, 2019 Share Posted January 14, 2019 Hi gents, Was attempting to fiddle with the H3 watchdog on a system running the legacy 3.4.113 kernel. The sunxi_wdt driver is not compiled by default and I was wondering if it might be possible to use this as a LKM with /dev/watchdog? Have managed to get it compiled as a .ko but trying to load it with insmod returns a generic "insmod: ERROR: could not insert module sunxi_wdt.ko: Invalid parameters" Is it even possible to use a LKM for this? and if so, how would I redirect /dev/watchdog from softdog to this? Thanks Link to comment Share on other sites More sharing options...
jstefanop Posted January 16, 2019 Share Posted January 16, 2019 So it looks like by default only softdog.ko is installed, not the hw version that is present on the H2/3. How would we enable to hardware watchdog? Link to comment Share on other sites More sharing options...
jstefanop Posted January 16, 2019 Share Posted January 16, 2019 Have the same question...running mainline kernel though and it does not seem like wdt driver is installed there as well... Link to comment Share on other sites More sharing options...
Tido Posted January 16, 2019 Share Posted January 16, 2019 On 1/15/2019 at 12:14 AM, cabled said: to fiddle with the H3 watchdog Hi, try the searchbox in the right hand corner with: watchdog Link to comment Share on other sites More sharing options...
Tido Posted January 16, 2019 Share Posted January 16, 2019 1 hour ago, jstefanop said: How would we enable to hardware watchdog? https://forum.armbian.com/topic/6295-how-can-i-set-the-watchdog-timeout-of-h2h3-to-16-seconds/ https://forum.armbian.com/topic/7460-boot-parameter-for-watchdog-on-orange-pi-pc/ Just use searchbox, right hand corner Link to comment Share on other sites More sharing options...
jstefanop Posted January 16, 2019 Share Posted January 16, 2019 32 minutes ago, Tido said: https://forum.armbian.com/topic/6295-how-can-i-set-the-watchdog-timeout-of-h2h3-to-16-seconds/ https://forum.armbian.com/topic/7460-boot-parameter-for-watchdog-on-orange-pi-pc/ Just use searchbox, right hand corner Thanks, already saw those threads otherwise I wouldn't be asking this question. Those have nothing to do with how to install the hardware watchdog driver on the mainline kernel (or to enable it if it does come with the kernel). Link to comment Share on other sites More sharing options...
rufik Posted January 17, 2019 Share Posted January 17, 2019 All you need is just to install watchdog service and set some parameter in armbianenv.txt file - I can't recall it right now, I'll try to search my notes later and post the solution. Link to comment Share on other sites More sharing options...
Tido Posted January 17, 2019 Share Posted January 17, 2019 12 hours ago, jstefanop said: saw those threads it is not enough wit looking at it... On 12/3/2017 at 12:15 PM, Nuno Goncalves said: with Linus 4.15-rc1 and it works fine: Link to comment Share on other sites More sharing options...
jstefanop Posted January 17, 2019 Share Posted January 17, 2019 5 hours ago, Tido said: it is not enough wit looking at it... How is some guy that compiled a custom kernel with it helpful? If I knew how to do that I would have already done it. Im trying to figure out how I would go about installing it on the mainline kernel. From what I can tell the option is already turned on in the mainline source compiler options, so it might be a matter of enabling it via ArmbianEnv.txt or through some other mechanism I dont know about. This is why I am asking the question since Im sure more experienced amrbian users would know the answer. Link to comment Share on other sites More sharing options...
jstefanop Posted January 17, 2019 Share Posted January 17, 2019 9 hours ago, rufik said: All you need is just to install watchdog service and set some parameter in armbianenv.txt file - I can't recall it right now, I'll try to search my notes later and post the solution. Thanks! Let me know if you find it. I dont see the .ko installed in the mainline system anywhere though so I still think the source needs to be compiled and installed into the kernel. I am also running kernel version 4.14 Armbian 5.60 (Ubuntu 16.04.4) if that matters. Link to comment Share on other sites More sharing options...
jstefanop Posted January 20, 2019 Share Posted January 20, 2019 FYI If anyone has some experience around this or knows how to enable this from mainline armbian build im more than willing to pay for someone's time. Link to comment Share on other sites More sharing options...
rufik Posted January 21, 2019 Share Posted January 21, 2019 To make watchdog performing hard reset you need to add this param to /boot/armbianEnv.txt : extraarg=sunxi_wdt.nowayout=1 But I can't really recall if some quotation should be used (like extraarg="sunxi_wdt.nowayout=1") or not. Just try it yourself. This argument is required if you want your watchdog to perform hard reset SBC. And of course just install watchdog package using apt-get. Link to comment Share on other sites More sharing options...
jstefanop Posted January 23, 2019 Share Posted January 23, 2019 On 1/21/2019 at 5:37 AM, rufik said: To make watchdog performing hard reset you need to add this param to /boot/armbianEnv.txt : extraarg=sunxi_wdt.nowayout=1 But I can't really recall if some quotation should be used (like extraarg="sunxi_wdt.nowayout=1") or not. Just try it yourself. This argument is required if you want your watchdog to perform hard reset SBC. And of course just install watchdog package using apt-get. Awesome thanks! Looks like this worked. Kernel loads: sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0) What does the nowayout option do? Even though I have it set to "1" in ArmbianEnv kernel still seems to load 0. There are also two watchdog file (/dev/watchdog and /dev/watchdog0) Im assuming one is for the software and the other for the hardware...anyone know which is which? Link to comment Share on other sites More sharing options...
rufik Posted January 23, 2019 Share Posted January 23, 2019 https://www.kernel.org/doc/Documentation/watchdog/watchdog-api.txt When the device is closed, the watchdog is disabled, unless the "Magic Close" feature is supported (see below). This is not always such a good idea, since if there is a bug in the watchdog daemon and it crashes the system will not reboot. Because of this, some of the drivers support the configuration option "Disable watchdog shutdown on close", CONFIG_WATCHDOG_NOWAYOUT. If it is set to Y when compiling the kernel, there is no way of disabling the watchdog once it has been started. So, if the watchdog daemon crashes, the system will reboot after the timeout has passed. Watchdog devices also usually support the nowayout module parameter so that this option can be controlled at runtime. So it's required to set it up. Try some quoting. Maybe this should be the last line in armbianenv.txt file? I can't remember exactly but there was some issue about it... Link to comment Share on other sites More sharing options...
jstefanop Posted January 24, 2019 Share Posted January 24, 2019 Ok so some further research it looks like the sunxi hardware watchdog IS installed and compiled directly into the kernel....I was looking for the sunxi_wtd.ko module and thought just the software watchdog was installed. That option only disables the Magic Close feature, so it has nothing to do with enabling the hardware watchdog. I need that feature anyway since there are instances where we disable the internal controller software and dont want the system to reboot in that case. Link to comment Share on other sites More sharing options...
rufik Posted May 10, 2019 Share Posted May 10, 2019 Is anyone using watchdog on OrangePi H3 family? I've tried to set it up on OPI 2 (almost the same as OPI PC but with wifi) and I'm getting some trouble with watchdog service startup: cannot set scheduler (errno = 1 = 'Operation not permitted') May 10 09:29:23 opi2 systemd[1]: Starting watchdog daemon... May 10 09:29:23 opi2 watchdog[12308]: String 'watchdog-device' found as '/dev/watchdog' May 10 09:29:23 opi2 watchdog[12308]: String 'admin' found as 'root' May 10 09:29:23 opi2 watchdog[12310]: starting daemon (5.15): May 10 09:29:23 opi2 watchdog[12310]: int=7s realtime=yes sync=no load=0,0,0 soft=no [cut!] May 10 09:29:23 opi2 watchdog[12310]: watchdog now set to 16 seconds May 10 09:29:23 opi2 watchdog[12310]: hardware watchdog identity: sunxi-wdt May 10 09:29:23 opi2 watchdog[12310]: cannot set scheduler (errno = 1 = 'Operation not permitted') May 10 09:29:23 opi2 systemd[1]: Started watchdog daemon. I'm using latest armbian: Welcome to ARMBIAN 5.85 stable Ubuntu 18.04.2 LTS 4.19.38-sunxi It looks like problem with realtime schduling: https://www.freedesktop.org/wiki/Software/systemd/MyServiceCantGetRealtime and I've tried to add Delegate=cpu option to watchdog.service file but still no-go. Anyone was facing this issue? Link to comment Share on other sites More sharing options...
