Look at the path of the patch and you will understand why. In the PR I have patched both 6.1 and 6.6 kernel. In 6.1 kernel, there is no sun50i-h616-orangepi-zero.dtsi and hence changes were needed in sun50i-h616-orangepi-zero2.dts. However, as 6.6 kernel has sun50i-h616-orangepi-zero.dtsi, changes were done in the same.
  • Reputation Points
