Guys, i'm new.   I enabled the sata module in armbian-config then i did  sudo dd bs=1M if=/path/your/armbian.img of=/dev/sda status=progress && sudo sync   overlays=opi5-sata is in mnt/boot/armbianEnv.txt   Without the sd, the orangepi boots in initramfs.   I've added a screenshot with the shell output on hdmi.   I can boot from SD but that's not what i need.   Any thoughts whats going on?
