18 18
masteripper
Armbian for Amlogic S802/S812
Update test image kernel 4.11 and deb packages from it (yandex and Mega). This way I have a start on Tronsmart MXIII Plus with SD card (when using the dtb file miii-plus). Is only works through the console UART. Network is not working.
Share this post
Link to post
Share on other sites
Run sdcard  Armbian_5.27_S812_Ubuntu_xenial_4.11.0+_server_20170515.
Hdmi does not work.
$ sudo dpkg -i linux-image-dev-vegas812_5.27_armhf.deb
dpkg-deb: error: 'linux-image-dev-vegas812_5.27_armhf.deb' is not a debian format archive
dpkg: error processing archive linux-image-dev-vegas812_5.27_armhf.deb (--install):
 subprocess dpkg-deb --control returned error exit status 2
Errors were encountered while processing: linux-image-dev-vegas812_5.27_armhf.deb
$ sudo dpkg -i linux-headers-dev-vegas812_5.27_armhf.deb
dpkg-deb: error: 'linux-headers-dev-vegas812_5.27_armhf.deb' is not a debian format archive
dpkg: error processing archive linux-headers-dev-vegas812_5.27_armhf.deb (--install):
Errors were encountered while processing:  linux-headers-dev-vegas812_5.27_armhf.deb
$ sudo dpkg -i linux-dtb-dev-vegas812_5.27_armhf.deb
dpkg-deb: error: 'linux-dtb-dev-vegas812_5.27_armhf.deb' is not a debian format archive
dpkg: error processing archive linux-dtb-dev-vegas812_5.27_armhf.deb (--install):
Errors were encountered while processing: linux-dtb-dev-vegas812_5.27_armhf.deb
Share this post
Link to post
This one can run High Quality USB 2.0 to Ethernet 10 / 100Mbps Network LAN RJ45 Adapter ?
Share this post
Link to post
i add this lines to my dts file
        pwmleds {
                compatible = "pwm-leds";
                power {
                        label = "m8s:blue:power";
                        pwms = <pwm_ef 1 7812500 0>;
                        max-brightness = <255>;
                        active-low;
                        linux,default-trigger = "default-on";
        pwm_ef {
                status = "okay";
                pinctrl-0 = <pwm_e_pins>, <pwm_f_ao_pins>;
                pinctrl-names = "default";
                clocks = <clkc CLKID_FCLK_DIV3>, <clkc CLKID_FCLK_DIV4>;
                clock-names = "clkin0", "clkin1";
but i got still sytax error in the DTC
please can you add the led funktion to the meason8s2 n200.dtb for me ?
m8s.dtb
m8s.dts
Share this post
Link to post
 i test your kernel , m8s.dtb , work  i can log in
start time about 2-3min
but 2 error
first at usb only my printer show not the canon scanner at the other usb port ,
second at shutdown the blue led still on dont switch to red
Kernel test 4.11 from 15.05 m8s.dtb .log
Share this post
Link to post
Hdmi does not work.
As it should be. This is a test image , there is no support for many elements.
What kind of kernel you write ?
And USB LED is not working completely.
Share this post
Link to post
balbes150
(Reading database ... 52241 files and directories currently installed.)
Preparing to unpack linux-image-dev-vegas812_5.27_armhf.deb ...
Unpacking linux-image-dev-vegas812 (5.27) over (5.27) ...
 unable to make backup link of './boot/vmlinuz-4.11.0+' before installing new version: Operation not permitted
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Share this post
Link to post
On 22.5.2017 at 4:43 PM, balbes150 said:
Updated image Mate and server kernel 3.10 (20170522). Added dtb m8s.
i test today but i have  problems to optain a ip addr from dhclient ,
i connect to my wlan ( iwconfig told me all fine) than i start dhclient and nothing ( i start and restart ntp deamon  but this time  no effect) .
Share this post
Link to post
46 minutes ago, balbes150 said:
I can't check for WiFi in s812. You should try to use other dtb and see how to work with them.
i have use m8s.dtb , n200_2gb.dtb and the one from the my backup .all with same result .
my steps
i have flash sdcard
change modules to 8723bs and blacklist in modprobe.d dhd
change interfaces set lan to static and wlan to hotlpug and dhcp
than iwlist for wlan ( find my one )
check ntp is running
iwconfig setup my ssid and key
iwconfig ( check of wlan connection) and than dhclient (but dont do anything , have to ctrl+c )
test with wpa_supplicant but same result .
do you have a changelog of the new image 3.10.99
Share this post
Link to post
Hdmi does not work (
Lan does not work (
Wifi is working.
My dtb file. With others does not work.
meson4.dtb
Share this post
Link to post
24 minutes ago, balbes150 said:
What does "change module" ? You copy the system other files ?
no
lsmod show 8723bs is the modul for my wlan
i change ( nano /etc/modules) from dhd to 8723bs and change (nano /etc/modprobe.d/blacklist.conf) insert blacklist dhd
than my wifi work
Share this post
Link to post
Added dtb m8s
also thank you for add led but i use the dtb for my running rom but still no led trigger at sys/class/leds , did i need a modul or something more ?
Share this post
Link to post
As the monitor is connected, via an adapter or directly to HDMI ?
What kind of wired network 100, or 1000 ?
Try to reset the bindings on the router.
You need to find the right settings (change the source, to collect the utility of the DTC , test the work).
https://github.com/150balbes/Amlogic_s8xx-kernel/blob/S812/arch/arm/boot/dts/meson8m2_n200_m8s.dts#L568
Share this post
Link to post
i done this with new image but no luck
its maybe like this problem https://bugs.launchpad.net/ubuntu/+source/network-manager/+bug/267891
i have also "ifup wlan0" like 20 time dhcp discovery 255.255.255.255 and than close
you mean find gpio pins ?
Share this post
Link to post
2 hours ago, balbes150 said:
wire network has earned!!!
HDMI is connected to the TV.  Does not work(((
On "Armbian_5.24_Vegas812_Ubuntu_xenial_3.10.99_desktop_20170113" hdmi worked perfectly !!!!
Share this post
Link to post
18 18
