oops, devs out of date? ;p
laurentppol
Well, we use stock Debian (or Ubuntu if you use our Ubuntu build) package repository and if you don't find some packages you need to add repository where those packages exits or download and install .deb file manually.
I don't want to switch my Ofiice software simply because different distribution.
So why not following the instructions the distribution of your choice provides: https://wiki.debian.org/OpenOffice
Regarding this stuff Armbian is more or less like the distro you chose (we currently support Debian Wheezy, Ubuntu Trusty, Debian Jessie and Ubuntu Xenial while fading out support for the former two). It's really just following the stuff you find on the net when googling for "$problem $distro"
What I like in Linux is a "set of LEGOs", anyone builds its own.
And for ME OO 3.3 id enough. And fast even on mC1400 + 2GB RAM
Then you are free to compile anything that you want. Current versions of Debian and Ubuntu use LibreOffice as main office software kit. And BTW OpenOffice development was discontinued 5 years ago and LibreOffice is an actively developing fork of OpenOffice.
oopsoot@orangepipcplus:/var/lib# export LANGUAGE=C
root@orangepipcplus:/var/lib# aptitude install openoffice.org
No candidate version found for openoffice.org
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Edited by zador.blood.stained
Fixed broken quote box
its "Debian depending" or world depending OO migrated to LO? Or It's just a fork?
Worse:
aptitude update;
got "nothing"
"root@orangepipcplus:/var/lib# export LANGUAGE=C
Need to get 0 B of archives. After unpacking 0 B will be used."
whats next?
Import change/compile programs on ARM>? howto?
➜  ~  % LANG=en_US apt-cache search '^libreoffice$'
libreoffice - office productivity suite (metapackage)
➜  ~  % LANG=en_US apt-cache search '^libreoffice-writer$'
libreoffice-writer - office productivity suite -- word processor
As @martinayotte said, since Debian Wheezy (2 stable releases ago) LibreOffice replaced OpenOffice in the Debian repositories.
As Zador said, last OpenOffice release was 5 years ago, ALL distros shifted to LibreOffice since then ...
From https://en.wikipedia.org/wiki/OpenOffice.org
1034px-StarOffice_major_derivatives.svg.
EDIT : Here is a piece of the History :
TDF released the fork LibreOffice in January 2011,[53] which most Linux distributions soon moved to.[54][55][56][57] In April 2011, Oracle stopped development of OpenOffice.org[11] and fired the remaining StarDivision development team.[34][58] Its reasons for doing so were not disclosed; some speculate that it was due to the loss of mindshare with much of the community moving to LibreOffice[59] while others suggest it was a commercial decision.[34]
