orrevs Posted December 19, 2016 Share Posted December 19, 2016 Is there a way to make armbian find my modem auto? I am runningOrange Pi One with Armbian 5.20 Debian Jesse And Orange Pi PC with Armbian 5.20 Debian JesseMy issue is that it finds the flash memory in my modem but not the modem itself i have to manually set it to modem via this commandusb_modeswitch -v 12d1 -p 1f01 -M '55534243123456780000000000000011062000000101000100000000000000' Now the OS see it as a modem and i can run command dhclient -v eth1And it will load up the eth1 and it will work fine. Issue is i have to do those steps after reboot.On my Rasberry device i run Raspberrian and it does all those steps per automatic its plug and play.Am not very good with linux, but are there some kind of driver or similar i can install so it can work more like plug and play?Also BIG thanks for armbian its really nice! Thank you for making this! 1 Link to comment Share on other sites More sharing options...
reverend_t Posted December 28, 2016 Share Posted December 28, 2016 I'm using the Huawei E3372. I found that all my modem problems disappeared once I installed the latest version of usb-modeswitch from the Jessie Backports repo. https://backports.debian.org/Instructions/ Link to comment Share on other sites More sharing options...
winit_a Posted January 2, 2017 Share Posted January 2, 2017 work on this 1. http://blog.asiantuntijakaveri.fi/2015/07/convert-huawei-e3372h-153-from.html I using E3372h send gps to server (ambulance) if used wvdial system will freeze when car runing 2. dial with pppd work https://wiki.debian.org/Modem/3G Link to comment Share on other sites More sharing options...
dikov Posted March 6, 2017 Share Posted March 6, 2017 I have Vodaphone stick K3765 and it got switched by the usb_modeswitch from usb_modeswitch: switch device 12d1:1520 on 001/002 to usb_modeswitch: switched to 12d1:1465 on 001/003 but the no further steps are executed and no serialUSB devices created. Mar 6 07:08:53 localhost systemd-udevd[2553]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/soc.0/1c1a000.ehci0-controller/usb1/1-1 1 2': No such file or directory Mar 6 07:08:53 localhost systemd[1]: Created slice system-usb_modeswitch.slice. Mar 6 07:08:53 localhost systemd[1]: Starting USB_ModeSwitch_1-1:1.0... Mar 6 07:08:54 localhost usb_modeswitch: switch device 12d1:1520 on 001/002 Mar 6 07:08:54 localhost kernel: [ 79.003924] ehci_irq: highspeed device disconnect Mar 6 07:08:54 localhost kernel: [ 79.004038] usb 1-1: USB disconnect, device number 2 Mar 6 07:08:59 localhost kernel: [ 83.734301] ehci_irq: highspeed device connect Mar 6 07:08:59 localhost rsyslogd-2007: action 'action 9' suspended, next retry is Mon Mar 6 07:09:29 2017 [v8.16.0 try http://www.rsyslog.com/e/2007 ] Mar 6 07:08:59 localhost kernel: [ 83.957593] usb 1-1: new high-speed USB device number 3 using sunxi-ehci Mar 6 07:08:59 localhost kernel: [ 84.113247] usb-storage 1-1:1.5: USB Mass Storage device detected Mar 6 07:08:59 localhost kernel: [ 84.113751] scsi1 : usb-storage 1-1:1.5 Mar 6 07:08:59 localhost kernel: [ 84.114538] usb-storage 1-1:1.6: USB Mass Storage device detected Mar 6 07:08:59 localhost kernel: [ 84.114779] scsi2 : usb-storage 1-1:1.6 Mar 6 07:08:59 localhost systemd-udevd[2614]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/soc.0/1c1a000.ehci0-controller/usb1/1-1 1 3': No such file or directory Mar 6 07:08:59 localhost kernel: [ 84.184939] cdc_ether 1-1:1.1 wwan0: register 'cdc_ether' at usb-sunxi-ehci-1, Mobile Broadband Network Device, 02:50:f3:00:00:00 Mar 6 07:08:59 localhost kernel: [ 84.185073] usbcore: registered new interface driver cdc_ether Mar 6 07:08:59 localhost NetworkManager[613]: <info> [1488784139.6140] devices added (path: /sys/devices/soc.0/1c1a000.ehci0-controller/usb1/1-1/1-1:1.1/net/wwan0, iface: wwan0) Mar 6 07:08:59 localhost NetworkManager[613]: <info> [1488784139.6141] device added (path: /sys/devices/soc.0/1c1a000.ehci0-controller/usb1/1-1/1-1:1.1/net/wwan0, iface: wwan0): no ifupdown configuration found. Mar 6 07:09:00 localhost root: usb_modeswitch: switched to 12d1:1465 on 001/003 Mar 6 07:09:00 localhost kernel: [ 85.091313] scsi 1:0:0:0: CD-ROM Vodafone CD ROM (Huawei) 2.31 PQ: 0 ANSI: 2 Mar 6 07:09:00 localhost kernel: [ 85.095968] sr0: scsi-1 drive Mar 6 07:09:00 localhost kernel: [ 85.095984] cdrom: Uniform CD-ROM driver Revision: 3.20 Mar 6 07:09:00 localhost kernel: [ 85.096486] sr 1:0:0:0: Attached scsi CD-ROM sr0 Mar 6 07:09:00 localhost kernel: [ 85.103634] scsi 2:0:0:0: Direct-Access Vodafone Storage (Huawei) 2.31 PQ: 0 ANSI: 2 Mar 6 07:09:00 localhost kernel: [ 85.110160] sd 2:0:0:0: [sda] Attached SCSI removable disk Mar 6 07:09:00 localhost systemd[1]: Started USB_ModeSwitch_1-1:1.0. Mar 6 07:09:02 localhost ModemManager[590]: <info> Couldn't find support for device at '/sys/devices/soc.0/1c1a000.ehci0-controller/usb1/1-1': not supported by any plugin Any ideas? Link to comment Share on other sites More sharing options...
dikov Posted March 7, 2017 Share Posted March 7, 2017 Whatever I try with the modem Huawei K3765 same result: It got switched to the modem mode, but ttyUSB nodes are not created. When same modem Huawei K3765 is inserted into Mint or Ubuntu it gor switched and recognized by Networkmanager. In all cases I have installed usb_modeswitch and ModemManager. So it seems something is not right on kernel. Link to comment Share on other sites More sharing options...
Thomas131 Posted July 9, 2018 Share Posted July 9, 2018 Hello! I have the same Problem on the Huawei E3531. I attached dmesg after attaching on a normal Linux Mint-PC and my Pine64. Thanks in advance! Thomas linux_mint_dmesg.txt pine64_dmesg.txt Link to comment Share on other sites More sharing options...
