NanoPi NEO custom image boot error - failed to create pty
KernelPanic
Dear Sirs and Madams!
I am working on custom minimal image for NanoPi NEO and I've managed to solve majority of problems, however, if I observe boot process via /dev/ttyUSB0, I still get these two errors:
HELLO! BOOT0 is starting!
boot0 version : 4.0.0
boot0 commit : 1b3a1b587482affdd18aba923de7fe38eb7d5ee1
fel_flag = 0x00000000
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
rtc[6] value = 0x00000000
rtc[7] value = 0x00000000
DRAM DRIVE INFO: V1.3
the chip id is 0x00000081
READ DQS LCDL = 00222223
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 576 MHz
DRAM zq value: 003b3bfb
DRAM dram para1: 10f20200
DRAM dram para2: 00000001
DRAM workmode1: 000009f4
DRAM SIZE =512 M
odt delay
dram size =512
card boot number = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2015-04-13 16:07:39
[mmc]: ***Try SD card 0***
[mmc]: SD/MMC Card: 4bit, capacity: 7386MB
[mmc]: vendor: Man 0002544d Snr 4583d869
[mmc]: product: SA08G
[mmc]: revision: 1.9
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 000e4000.
sum=168b7a54
src_sum=168b7a54
Succeed in loading uboot from sdmmc flash.
Ready to disable icache.
Jump to secend Boot.
SUNXI_NORMAL_MODE
[      0.382]e mode
U-Boot 2011.09-rc1-00000-g1b3a1b5-dirty (Dec 23 2016 - 20:03:28)
[      0.392]version: 1.1.0
[      0.395]uboot commit : 1b3a1b587482affdd18aba923de7fe38eb7d5ee1
normal mode
[      0.406]pmbus:   ready
not set main pmu id
axp_probe error
gpio value=0x20000
[      0.444]PMU: pll1 1008 Mhz,PLL6=600 Mhz
AXI=336 Mhz,AHB=200 Mhz, APB1=100 Mhz
sid read already
fel key new mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
normal mode
[      0.475]DRAM:  512 MiB
relocation Offset is: 15af2000
[box standby] read rtc = 0x0
[box_start_os] mag be start_type no use
user_gpio config
user_gpio ok
gic: normal or no secure os mode
workmode = 0
MMC:     0
[      0.555][mmc]: mmc driver ver 2015-04-13 14:50:00
[      0.560][mmc]: get sdc_phy_wipe fail.
[      0.564][mmc]: get sdc0 sdc_erase fail.
[      0.568][mmc]: get sdc_f_max fail,use default 50000000Hz
[      0.573][mmc]: get sdc_ex_dly_used fail,use default dly
[      0.579][mmc]: SUNXI SD/MMC: 0
[      0.592][mmc]: *Try SD card 0*
[      0.625][mmc]: CID 0x2544d53 0x41303847 0x194583d8 0x690106bd
[      0.630][mmc]: mmc clk 50000000
[      0.634][mmc]: SD/MMC Card: 4bit, capacity: 7386MB
[      0.638][mmc]: boot0 capacity: 0KB,boot1 capacity: 0KB
[      0.644][mmc]: ***SD/MMC 0 init OK!!!***
[      0.648][mmc]: erase_grp_size:0x1WrBlk * 0x200 = 0x200 Byte
[      0.654][mmc]: secure_feature 0x0
[      0.657][mmc]: secure_removal_type  0x0
[      0.661]sunxi flash init ok
script config pll_de to 864 Mhz
Not Found clk pll_video1 in script
script config pll_video to 297 Mhz
script config pll_periph0 to 600 Mhz
unable to find regulator vcc-hdmi-18 from [pmu1_regu] or [pmu2_regu]
enable power vcc-hdmi-18, ret=-1
DRV_DISP_Init end
[disk_read_fs] no the partition
error: open tv_vdid.fex, maybe it is not exist
error: open disp_rsl.fex, maybe it is not exist
boot_disp.auto_hpd=1
auto hpd check has 100 times!
auto check no any connected, the output_type is 4
[      2.036]finally, output_type=0x4, output_mode=0x4, screen_id=0x0, disp_para=0x0
try to read logic blk 0 without env partition
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
--------fastboot partitions--------
mbr not exist
base bootcmd=run setargs_mmc boot_normal
bootcmd set setargs_mmc
key 0
cant find rcvy value
cant find fstbt value
no misc partition is found
to be run cmd=run setargs_mmc boot_normal
[      2.085][mmc]: MMC Device 2 not found
[      2.089][mmc]: Can not find mmc dev
[      2.092][mmc]: read first backup failed in fun sdmmc_secure_storage_read line 1854
sunxi_secstorage_read fail
get secure storage map err
check user data form private
the private part isn't exist
WORK_MODE_BOOT
adver not need show
sunxi_bmp_logo_display
** Unable to read "bootlogo.bmp" from mmc 0:1 **
sunxi bmp info error : unable to open logo file bootlogo.bmp
[      2.126]Hit any key to stop autoboot:  0
## Booting kernel from Legacy Image at 40007800 ...
   Image Name:   Linux-3.4.39-h3
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4736568 Bytes = 4.5 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
[      4.613][mmc]: MMC Device 2 not found
[      4.617][mmc]:  mmc  not find,so not exit
[      4.621]
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2c00081!
ion_reserve_common: ion reserve: [0x56000000, 0x60000000]!
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.39-h3 (testuser@work002) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #9 SMP PREEMPT Sun Dec 25 05:37:06 CET 2016
[    0.000000] cma: CMA: reserved 160 MiB at 56000000
[    0.000000] PERCPU: Embedded 8 pages/cpu @c0fc7000 s11840 r8192 d12736 u32768
[    0.000000] Kernel command line: console=ttyS0,115200 console=tty0 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait init=/sbin/init storage_type=1 fb_base=0x40000000
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 342160k/342160k available, 182128k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0910624   (9250 kB)
[    0.000000]       .init : 0xc0911000 - 0xc0962e40   ( 328 kB)
[    0.000000]       .data : 0xc0964000 - 0xc0a156f8   ( 710 kB)
[    0.000000]        .bss : 0xc0a15eac - 0xc0b35b48   (1152 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty0] enabled
[    0.000996] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.001064] pid_max: default: 32768 minimum: 301
[    0.001439] Mount-cache hash table entries: 512
[    0.002510] Initializing cgroup subsys cpuacct
[    0.002553] Initializing cgroup subsys memory
[    0.002624] Initializing cgroup subsys devices
[    0.002656] Initializing cgroup subsys freezer
[    0.002685] Initializing cgroup subsys blkio
[    0.002728] Initializing cgroup subsys perf_event
[    0.002808] CPU: Testing write buffer coherency: ok
[    0.002885] ftrace: allocating 24837 entries in 73 pages
[    0.040323] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.040371] [sunxi_smp_prepare_cpus] enter
[    0.040428] Setting up static identity map for 0x40663670 - 0x406636c8
[    0.041476] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.041611] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.041611] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.050225] Brought up 4 CPUs
[    0.050307] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.051054] devtmpfs: initialized
[    0.054009] wakeup src cnt is : 2.
[    0.054107] sunxi pm init
[    0.054257] pinctrl core: initialized pinctrl subsystem
[    0.064426] NET: Registered protocol family 16
[    0.065333] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.065333] script_sysfs_init success
[    0.065333] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.065333] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.065333] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.065333] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.065333] script config pll_video to 297 Mhz
[    0.065333] script config pll_de to 864 Mhz
[    0.065333] script config pll_ve to 402 Mhz
[    0.073438] bio: create slab <bio-0> at 0
[    0.073438] [ARISC] :sunxi-arisc driver v1.04
[    0.088634] [ARISC] :arisc version: [v0.1.58]
[    0.175990] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.176118] pwm module init!
[    0.181681] SCSI subsystem initialized
[    0.181681] usbcore: registered new interface driver usbfs
[    0.181681] usbcore: registered new interface driver hub
[    0.181681] usbcore: registered new device driver usb
[    0.181681] Linux media interface: v0.10
[    0.181681] Linux video capture interface: v2.00
[    0.181681] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.181681] Bluetooth: Core ver 2.16
[    0.181681] NET: Registered protocol family 31
[    0.181681] Bluetooth: HCI device and connection manager initialized
[    0.181681] Bluetooth: HCI socket layer initialized
[    0.181681] Bluetooth: L2CAP socket layer initialized
[    0.181681] Bluetooth: SCO socket layer initialized
[    0.181681] Switching to clocksource arch_sys_counter
[    0.203579] FS-Cache: Loaded
[    0.203920] CacheFiles: Loaded
[    0.215748] NET: Registered protocol family 2
[    0.216064] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.216646] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.216936] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.217197] TCP: Hash tables configured (established 16384 bind 16384)
[    0.217226] TCP: reno registered
[    0.217249] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.217290] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.217597] NET: Registered protocol family 1
[    0.217998] RPC: Registered named UNIX socket transport module.
[    0.218031] RPC: Registered udp transport module.
[    0.218052] RPC: Registered tcp transport module.
[    0.218074] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.218664] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.218799] sunxi_reg_init enter
[    0.219482] audit: initializing netlink socket (disabled)
[    0.219543] type=2000 audit(0.210:1): initialized
[    0.222020] NTFS driver 2.1.30 [Flags: R/W].
[    0.222337] fuse init (API version 7.18)
[    0.222704] msgmni has been set to 988
[    0.224141] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.224197] io scheduler noop registered
[    0.224218] io scheduler deadline registered
[    0.224290] io scheduler cfq registered (default)
[    0.224766] [DISP]disp_module_init
[    0.225089] cmdline,init_disp=
[    0.225132] cmdline,disp=
[    0.235328] [DISP] Fb_map_kernel_logo,line:939:this is not a bmp picture
[    0.250541] Console: switching to colour frame buffer device 160x45
[    0.266915] [DISP]disp_module_init finish
[    0.267262] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.267442] sw_uart_get_devinfo()1503 - uart1 has no uart_regulator.
[    0.267617] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[    0.267790] sw_uart_get_devinfo()1503 - uart3 has no uart_regulator.
[    0.268543] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.268713] sw_uart_pm()890 - uart0 clk is already enable
[    0.268868] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.376733] console [ttyS0] enabled
[    1.310478] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    1.448733] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    1.460128] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[    1.472032] [drm] Initialized drm 1.1.0 20060810
[    1.485687] loop: module loaded
[    1.493791] sunxi_spi_chan_cfg()1383 - [spi-0] has no spi_regulator.
[    1.505335] sunxi_spi_chan_cfg()1383 - [spi-1] has no spi_regulator.
[    1.517389] spi spi0: master is unqueued, this is deprecated
[    1.528397] tun: Universal TUN/TAP device driver, 1.6
[    1.538353] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.550532] PPP generic driver version 2.4.2
[    1.559774] PPP BSD Compression module registered
[    1.569280] PPP Deflate Compression module registered
[    1.580030] PPP MPPE Compression module registered
[    1.589604] NET: Registered protocol family 24
[    1.598762] PPTP driver version 0.8.5
[    1.607246] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.638932] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.652340] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.665889] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.690050] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.701640] hub 1-0:1.0: USB hub found
[    1.710104] hub 1-0:1.0: 1 port detected
[    1.739102] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.752404] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    1.765732] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    1.790034] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    1.801555] hub 2-0:1.0: USB hub found
[    1.809963] hub 2-0:1.0: 1 port detected
[    1.839037] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.852408] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    1.865798] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    1.890044] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    1.901646] hub 3-0:1.0: USB hub found
[    1.910317] hub 3-0:1.0: 1 port detected
[    1.939371] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.952767] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    1.966139] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    1.990039] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    2.001685] hub 4-0:1.0: USB hub found
[    2.010515] hub 4-0:1.0: 1 port detected
[    2.019762] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.051280] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.064440] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    2.077447] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    2.144574] hub 5-0:1.0: USB hub found
[    2.153308] hub 5-0:1.0: 1 port detected
[    2.182608] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.195828] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    2.208971] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    2.284561] hub 6-0:1.0: USB hub found
[    2.293434] hub 6-0:1.0: 1 port detected
[    2.322774] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.336046] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    2.349215] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    2.424579] hub 7-0:1.0: USB hub found
[    2.433430] hub 7-0:1.0: 1 port detected
[    2.462785] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.476090] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    2.489325] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    2.564570] hub 8-0:1.0: USB hub found
[    2.573458] hub 8-0:1.0: 1 port detected
[    2.582823] Initializing USB Mass Storage driver...
[    2.593074] usbcore: registered new interface driver usb-storage
[    2.604387] USB Mass Storage support registered.
[    2.614237] usbcore: registered new interface driver ums-alauda
[    2.625555] usbcore: registered new interface driver ums-cypress
[    2.636955] usbcore: registered new interface driver ums-datafab
[    2.648220] usbcore: registered new interface driver ums_eneub6250
[    2.659597] usbcore: registered new interface driver ums-freecom
[    2.670724] usbcore: registered new interface driver ums-isd200
[    2.681770] usbcore: registered new interface driver ums-jumpshot
[    2.692886] usbcore: registered new interface driver ums-karma
[    2.703695] usbcore: registered new interface driver ums-onetouch
[    2.714693] usbcore: registered new interface driver ums-realtek
[    2.725491] usbcore: registered new interface driver ums-sddr09
[    2.736116] usbcore: registered new interface driver ums-sddr55
[    2.746706] usbcore: registered new interface driver ums-usbat
[    2.757179] usbcore: registered new interface driver usbserial
[    2.767517] usbserial: USB Serial Driver core
[    2.776172] usbcore: registered new interface driver option
[    2.786184] USB Serial support registered for GSM modem (1-port)
[    2.797311] file system registered
[    2.806559] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    2.818136] android_usb gadget: Number of LUNs=3
[    2.827163]  lun0: LUN: removable file: (no medium)
[    2.836455]  lun1: LUN: removable file: (no medium)
[    2.845612]  lun2: LUN: removable file: (no medium)
[    2.855037] android_usb gadget: android_usb ready
[    2.864797] mousedev: PS/2 mouse device common for all mice
[    2.875687] ls_fetch_sysconfig_para: ls_unused.
[    2.884819] [RTC] WARNING: Rtc time will be wrong!!
[    2.893888] [RTC] WARNING: use *internal OSC* as clock source
[    2.904172] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    2.915259] i2c /dev entries driver
[    2.923179] IR RC5(x) protocol handler initialized
[    2.946164] tscdev_init: tsc driver is disabled
[    2.955398] Driver for 1-wire Dallas network protocol.
[    2.964872] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    2.975787] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    2.987390] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    3.002493] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    3.012555] timeout_to_interv, line 167
[    3.020638] interv_to_timeout, line 189
[    3.028656] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    3.041847] device-mapper: uevent: version 1.0.3
[    3.051209] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    3.064736] Bluetooth: HCI UART driver ver 2.2
[    3.073733] Bluetooth: HCI H4 protocol initialized
[    3.083055] Bluetooth: HCI BCSP protocol initialized
[    3.092523] Bluetooth: HCILL protocol initialized
[    3.101732] Bluetooth: HCIATH3K protocol initialized
[    3.111395] Bluetooth: MSM Sleep Mode Driver Ver 1.2
[    3.121046] Bluetooth: init no bt used in configuration
[    3.121052]
[    3.136836] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    3.152870] no red_led, ignore it!
[    3.163113] usbcore: registered new interface driver usbhid
[    3.173851] usbhid: USB HID core driver
[    3.184005] script_get_item audio_pa_ctrl not found
[    3.197597] asoc: sndcodec <-> sunxi-codec mapping ok
[    3.213087] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    3.223269] mmc0: new high speed SDHC card at address 1234
[    3.235040] mmcblk0: mmc0:1234 SA08G 7.21 GiB
[    3.236190] oprofile: using arm/armv7-ca7
[    3.254118] u32 classifier
[    3.255572]  mmcblk0: p1 p2
[    3.269650]     Actions configured
[    3.278035] Netfilter messages via NETLINK v0.30.
[    3.287961] nf_conntrack version 0.5.0 (7906 buckets, 31624 max)
[    3.299763] ctnetlink v0.93: registering with nfnetlink.
[    3.310511] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.323174] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.334982] xt_time: kernel timezone is -0000
[    3.344901] IPv4 over IPv4 tunneling driver
[    3.354937] gre: GRE over IPv4 demultiplexor driver
[    3.365265] ip_gre: GRE over IPv4 tunneling driver
[    3.375396] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.385587] arp_tables: (C) 2002 David S. Miller
[    3.394822] TCP: cubic registered
[    3.402518] Initializing XFRM netlink socket
[    3.411471] NET: Registered protocol family 10
[    3.421543] Mobile IPv6
[    3.428244] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.438359] IPv6 over IPv4 tunneling driver
[    3.447867] NET: Registered protocol family 17
[    3.456657] NET: Registered protocol family 15
[    3.465535] Bluetooth: RFCOMM TTY layer initialized
[    3.474746] Bluetooth: RFCOMM socket layer initialized
[    3.484148] Bluetooth: RFCOMM ver 1.11
[    3.491899] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.501359] Bluetooth: BNEP filters: protocol multicast
[    3.510638] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.520806] L2TP core driver, V2.0
[    3.528087] PPPoL2TP kernel driver, V2.0
[    3.535995] L2TP IP encapsulation support (L2TPv3)
[    3.544926] L2TP netlink interface
[    3.552258] L2TP ethernet pseudowire support (L2TPv3)
[    3.561697] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    3.573886] ThumbEE CPU extension supported.
[    3.582222] Registering SWP/SWPB emulation handler
[    3.591979] cmdline,disp=
[    3.629487] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-02 15:57:33 UTC (143853)
[    3.642264] ths_fetch_sysconfig_para: type err  device_used = 1.
[    3.653962] CPU Budget:Register notifier
[    3.661996] CPU Budget:register Success
[    3.669821] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    3.686496] ALSA device list:
[    3.693559]   #0: audiocodec
[    3.700455]   #1: sndhdmi
[    4.230061] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    7.401281] EXT4-fs (mmcblk0p2): recovery complete
[    7.414302] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    7.427375] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    7.438365] Freeing init memory: 324K
[    7.918278] init: Failed to create pty - disabling logging for job
[    7.929502] init: Temporary process spawn error: No such file or directory
[    7.969205] init: Failed to create pty - disabling logging for job
[    7.981261] init: Temporary process spawn error: No such file or directory
[    8.076671] init: Failed to create pty - disabling logging for job
[    8.088742] init: Temporary process spawn error: No such file or directory
[    8.103885] init: Failed to create pty - disabling logging for job
[    8.116079] init: Temporary process spawn error: No such file or directory
[    8.131416] init: Failed to create pty - disabling logging for job
[    8.143639] init: Temporary process spawn error: No such file or directory
[    8.369951] init: Failed to create pty - disabling logging for job
[    8.381849] init: Temporary process spawn error: No such file or directory
[    8.405900] init: Failed to create pty - disabling logging for job
[    8.417942] init: Temporary process spawn error: No such file or directory
[    8.438212] init: Failed to create pty - disabling logging for job
[    8.454745] init: Temporary process spawn error: No such file or directory
[    8.476736] init: Failed to create pty - disabling logging for job
[    8.489585] init: Temporary process spawn error: No such file or directory
[    8.505562] init: Failed to create pty - disabling logging for job
[    8.523290] init: Failed to create pty - disabling logging for job
[    8.552596] init: Failed to create pty - disabling logging for job
[    8.583415] init: Failed to create pty - disabling logging for job
[    8.599026] init: Failed to create pty - disabling logging for job
[    8.613592] init: Failed to create pty - disabling logging for job
[    8.718529] init: Failed to create pty - disabling logging for job
[    8.746995] init: Failed to create pty - disabling logging for job
[    8.777812] init: Failed to create pty - disabling logging for job
[    8.795384] init: Failed to create pty - disabling logging for job
[    8.814510] init: Failed to create pty - disabling logging for job
[    9.069827] init: Failed to create pty - disabling logging for job
[    9.088864] init: Failed to create pty - disabling logging for job
[    9.208412] init: Failed to create pty - disabling logging for job
[    9.224610] init: Failed to create pty - disabling logging for job
[    9.269189] init: Failed to create pty - disabling logging for job
[    9.284793] init: Failed to create pty - disabling logging for job
[    9.301157] init: Failed to create pty - disabling logging for job
[    9.325083] init: Failed to create pty - disabling logging for job
[    9.344112] init: Failed to create pty - disabling logging for job
[    9.358476] init: Failed to create pty - disabling logging for job
[    9.372694] init: Failed to create pty - disabling logging for job
[    9.394145] init: Failed to create pty - disabling logging for job
[    9.408119] init: Failed to create pty - disabling logging for job
What am I still doing wrong, any clues/hints, because no login shell is not shown?
Sincerely,
Marko
Do you have this in your kernel .config ?
CONFIG_UNIX98_PTYS=y
Yes, I do:
# Character devices
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
# CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_DEVPTS_MULTIPLE_INSTANCES=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=0
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
