How to set brightness setting on CAM500B
khushi
Is there any way to change brightness settings on CAM500B? I can't get clear images fswebcam.
Using nanopi neo air with CAM500B and Ubuntu core.
:~# v4l2-ctl -l
error 25 getting ctrl White Balance, Automatic
error 25 getting ctrl Exposure
error 25 getting ctrl Horizontal Flip
error 25 getting ctrl Vertical Flip
error 25 getting ctrl Color Effects
Thanks
:~# v4l2-ctl -l
Thanks
There is different / patched driver within Armbian kernel. This problem might be the same or not ... We can't support 3rd party image builds.
Yes I have tried same command with sudo
sudo v4l2-ctl -l
sudo: unable to resolve host FriendlyARM
Same error
Try to run the program cheese: sudo apt install cheese
Also check kernel messages with the command dmesg to see if the camera is detected, pluging the camera and checking dmesg messages.
If the camera is not detected maybe you will need to build the kernel with uvc driver.
I am using nanopi neo air with CAM500B.I want to set Camera parameters like brightness, contrast, hue,sharpness etc using command line (manually).Is there another method other then v4l2-utils.v4l2-ctl -l command giving me error.
Chances are you have issues with Auto Focus.
Auto Focus will work on video streaming.
You can try to use the parameter: --exposure 4 to get a "brighter" image. You can also try to skip some frames before saving the image with this parameter: -S 2 (where 2 is the # of frames skipped, adjust if needed).
It looks like the function that sets the brightness does nothing.
https://github.com/friendlyarm/linux-3.4.y/blob/nanopi2-lollipop-mr1/drivers/media/video/ov5640.c#L1528
Maybe I'm reading it wrong and brightness is a "standard" value that v4l2 controls.  I'm still digging in to the code to understand it.
To answer the original question, brightness for v4l2 drivers is supposed to be controlled with v4l2-ctl. eg v4l2-ctl -c brightness=200.
