Cubietruck / A20: HDD more than 2TB?
HoSnoopy
It is possible. At least for banana pi M1 (A20) it can handle a 3TB hdd with no issues.
Just remember that you have to change your disk partition table to GPT instead of standard MBR because the latter is limited to 2.2 gb.
This is regarding SATA connection, if you use some kind of usb-to-sata adaptor, check that it is able to handle >2.2 TB
