31 31
Peba
Asus Tinkerboard
OK, So for the boot issue, I just booted against every display in my home, including 2 televisions, no issues with the 4.14 kernel (4.14.80).  That, in my opinion, rules out u-boot to the extent that I can test.  Given my experience with the 4.4 kernel, I am of the opinion that it can't get any worse than it is, especially since we've been mangling the shite out of it to try to keep up with Rockchip and made one hell of a mess.  @JMCC if you have tested the 4.4 you've frozen so far, we can get that up to feature parity and move forward.  We can't keep dodging Rockchip updates, and we can't go back to the old MQMaker kernel because it's old enough to have moss growing on it.  I'll take a look at the patches and see which ones go where and how much work we're in for, things like the reboot I think need a complete rework, some of the later Rockchip work fixed it in a more correct fashion if I'm reading properly.
Share this post
Link to post
Share on other sites
Hi Tony,
Thank you for checking and if JMCC's (a working fork of RK BSP kernel) is working like a charm, is for sure better than random reboot's :-)
To avoid misunderstanding I never had HDMI issues, mine wouldn't do a cold start, just the red LED. No matter HDMI connected or not.
As I wrote here: https://forum.armbian.com/topic/3327-asus-tinkerboard/?do=findComment&comment=65557 dtb -> dtb-4.14.79-rockchip/  if you now run a 4.14.80 this issue maybe fixed by now.
Share this post
Link to post
No worries, I was testing to try to remove u-boot from the list of things that might be wrong.  :)
Share this post
Link to post
19 hours ago, Tido said:
Hi Tony,
Hello. I have the problem of hdmi that prevents me from booting with a screen that serves me for my tests.
I am currently on the kernel 4.14.76.
How to upgrade to this 4.14.80 kernel to test it?
Share this post
Link to post
It would seem booting it without the HDMI attached and adding it later works. Then, if you build your own kernel, install the dtb's. Now remember my testing was not exhaustive.
@Igor has there been any issue with Allwinner HDMI recently? This board and the Amlogic SoC's use the DW-HDMI, and Amlogic is a mess with HDMI right now as well. Probably unlikely, but seems odd.
Share this post
Link to post
I tested to intaller Mate desktop on next armbian ubuntu desktop 4.14.76. For that I had to purge the package "linux-bionic-root-next-tinkerboard". The installation is pass without much problem and I now have an armbian version on Mate.
So I would like to know what this package consists of: linux-bionic-root-next-tinkerboard ? Thanks
Share this post
Link to post
How exactly? It seems we have some bug if you had to remove our BSP package ... which is needed for proper functioning.
BTW. Our stock XFCE is faster (and nicer) than Mate desktop.
Share this post
Link to post
I give a shit about Mate on the deskotp I need the device to work and programms running. Everything else is putting lipstick on a pig. Such discussion are waste of precious time.
Question @Igor, if I restore again and run the update, will I get now 4.14.80 ?
Share this post
Link to post
@Tido I would suggest to take a step back. Relating one's experience and results is perfectly fine, as well as replying to such information reasonably. I also caution that my experience with 4.14 is of course with my hardware, not with your hardware.
Now then, I will have some time to review the bsp, at least the rockchip-specific part, directly. We can then reasonably and *with civil discourse* discuss the path forward. I would very much like the dmesg output you get when plugging your monitors in, and of course any serial debug output you can provide on failed boot events.
Share this post
Link to post
I run Mate on all my Desktop's Tower and Notebook, but I touch the Operating System or the Desktop Environment about 1% of my work, for the rest I use programs.
So I arranged myself with armbian's XFCE because it is not worth spending time for 1%.  That written I fully stand to what I wrote above - it is not worth spending time on such a topic.
However having no display or not booting at all is a really bad experience, in compare. So adding dragonlost's MATE on top of already serious topics, I wrote what I think about.
If you are running it on a tinker board, chances are quite small we have different HW.
UART, on which connectors/output will it sit with 4.14   5.54 ?
Share this post
Link to post
The following issue may have already been reported, so apologies if it has.
Fresh install of both desktop 18.04 and Stretch next (Armbian_5.59_Tinkerboard_Debian_stretch_next_4.14.67) on the Tinkerboard Ethernet comes up but does not connect without manual intervention., on the desktop I had to login and connect manually, with the "server" edition I had to modify the interfaces file to get an address.
Intentional or a bug?
Share this post
Link to post
I can't imagine that being on purpose, sounds like an environment issue rather than a BSP package issue though, So it's not my department.
[edit]  My 4.14.80 build does not have any issues with bringing up LAN on boot.
Share this post
Link to post
# purge xfce
sudo apt-get -y purge xfce*
# purge next tinkerboard
sudo dpkg --purge linux-bionic-root-next-tinkerboard
# install lightdm
sudo apt-get -y install lightdm
sudo apt-get -y install xserver-xorg
sudo apt-get -y install lightdm-greeter
# select NoDm for test
# install Mate
sudo apt-get -y install mate
sudo apt-get -y install ubuntu-mate-core ubuntu-mate-desktop
sudo apt-get -y install ubuntu-mate-default-settings ubuntu-mate-icon-themes
sudo apt-get -y install ubuntu-mate-live-settings ubuntu-mate-guide
sudo apt-get -y install mate-desktop-environment-extras mate-indicator-applet
sudo apt-get -y install synaptic
sudo apt-get -y install engrapa
sudo apt-get -y install caja-actions
sudo apt-get -y install caja-wallpaper
sudo apt-get -y install caja-open-terminal
sudo apt-get -y install mozo
sudo apt-get -y install pluma
sudo apt-get -y install mate-tweak
sudo apt-get -y install mate-themes
sudo apt-get -y install mate-applets gnome-media
sudo apt-get -y install mate-panel
sudo apt-get -y install mate-system-monitor
sudo apt-get -y install blueman
sudo apt-get -y install firefox
sudo apt-get -y install ubuntu-mate-themes
sudo apt-get -y install pulseaudio indicator-sound indicator-sound-gtk2 libcanberra-pulse paprefs
sudo apt-get -y install pulseaudio-module-bluetooth pulse-audio-module-gconf pulseaudio-module-zeroconf
sudo alsa force-reload
it's not optimized. probably too many packages
Share this post
Link to post
This package contains some important services and optimisations. Just look into it. I don't understand why you think you need to remove that? MATE works with it just fine.
Share this post
Link to post
I do not want to delete it. It's just that if I keep it I can not install Mate because there is conflict:
Preparing to unpack .../39-ubuntu-mate-default-settings_18.04.17_armhf.deb ... Unpacking ubuntu-mate-default-settings (18.04.17) ... dpkg: error processing archive /tmp/apt-dpkg-install-E9v1ON/39-ubuntu-mate-default-settings_18.04.17_armhf.deb (--unpack): trying to overwrite '/usr/lib/chromium-browser/master_preferences', which is also in package linux-bionic-root-next-tinkerboard 5.60
he uses all 2 the same directory :  /usr/lib/chromium-browser/master_preferences
Share this post
Link to post
Split cold non-booting issue to own topic, still need to review HDMI topic.
In other news, I noticed my 4.14.80 install mentioned I had an SDR104 SDHC and that it had successfully tuned the phase, not something I remember seeing before (haven't looked in a long time)
So with the typical iozone parameters I got  > 66 MB/s random read, and  > 58 MB/s random write.  Not too shabby.   B)  (SD Card:  SanDisk Extreme 32 GB U3)
        File size set to 102400 kB
        Record Size 4 kB
        Record Size 16 kB
        Record Size 512 kB
        Record Size 1024 kB
        Record Size 16384 kB
        Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
        Output is in kBytes/sec
        Time Resolution = 0.000001 seconds.
        Processor cache size set to 1024 kBytes.
        Processor cache line size set to 32 bytes.
        File stride size set to 17 * record size.
                                                              random    random     bkwd    record    stride
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
          102400       4     3228     3295    12302    12802    11459     5036
          102400      16    10544    10785    30695    30729    30434    15796
          102400     512    51482    50931    62070    61959    61823    48392
          102400    1024    58030    58118    63218    63221    63333    53391
          102400   16384    57062    60069    68049    67967    68066    59411
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
31 31
