[request] missing "build" link to build kernel modules
Hello Igor, greatings everyone,
I have realized the "build" link is missing to the /usr/src/linux-headers-x.x.x-sunxi
Ubuntu Trusty (x86/amd64 kernel) provides such a link
I was building a small kernel module from source (frandom-dkms) on my labomo-r1
gr@bpi:/lib/modules/4.2.3-sunxi$ ll
total 1260
drwxr-xr-x 4 root root   4096 Oct 13 18:34 ./
drwxr-xr-x 3 root root   4096 Oct 13 15:20 ../
lrwxrwxrwx 1 root root     34 Oct 13 14:23 build -> /usr/src/linux-headers-4.2.3-sunxi/
drwxr-xr-x 9 root root   4096 Oct 13 15:20 kernel/
-rw-r--r-- 1 root root 360156 Oct 13 18:34 modules.alias
-rw-r--r-- 1 root root 367304 Oct 13 18:34 modules.alias.bin
-rw-r--r-- 1 root root  14935 Oct 11 14:12 modules.builtin
-rw-r--r-- 1 root root  17813 Oct 13 18:34 modules.builtin.bin
-rw-r--r-- 1 root root  82602 Oct 13 18:34 modules.dep
-rw-r--r-- 1 root root 128280 Oct 13 18:34 modules.dep.bin
-rw-r--r-- 1 root root    128 Oct 13 18:34 modules.devname
-rw-r--r-- 1 root root  40034 Oct 11 14:12 modules.order
-rw-r--r-- 1 root root    131 Oct 13 18:34 modules.softdep
-rw-r--r-- 1 root root 103401 Oct 13 18:34 modules.symbols
-rw-r--r-- 1 root root 131685 Oct 13 18:34 modules.symbols.bin
drwxr-xr-x 3 root root   4096 Oct 13 18:34 updates/
without the link:
gr@bpi:~/frandom/frandom-master$ ls
CHANGELOG  debian  description-pak  etc  frandom.c  INSTALL  Makefile  README  usr
gr@bpi:~/frandom/frandom-master$ make
make -C /lib/modules/4.2.3-sunxi/build SUBDIRS=/home/gr/frandom/frandom-master modules
make: *** /lib/modules/4.2.3-sunxi/build: No such file or directory.  Stop.
make: *** [default] Error 2
with the link:
make[1]: Entering directory `/home2/src/linux-headers-4.2.3-sunxi'
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (                \
        echo >&2;                                                       \
        echo >&2 "  ERROR: Kernel configuration is invalid.";           \
        echo >&2 "         include/generated/autoconf.h or include/config/auto.conf are missing.";\
        echo >&2 "         Run 'make oldconfig && make prepare' on kernel src to fix it.";      \
        echo >&2 ;                                                      \
        /bin/false)
mkdir -p /home/gr/frandom/frandom-master/.tmp_versions ; rm -f /home/gr/frandom/frandom-master/.tmp_versions/*
make -f ./scripts/Makefile.build obj=/home/gr/frandom/frandom-master
  gcc -Wp,-MD,/home/gr/frandom/frandom-master/.frandom.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.8/include -I./arch/arm/include -Iarch/arm/include/generated/uapi -Iarch/arm/include/generated  -Iinclude -I./arch/arm/include/uapi -Iarch/arm/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-dwarf2-cfi-asm -mabi=aapcs-linux -mno-thumb-interwork -mfpu=vfp -funwind-tables -marm -D__LINUX_ARM_ARCH__=7 -march=armv7-a -msoft-float -Uarm -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fno-var-tracking-assignments -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -DCC_HAVE_ASM_GOTO  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(frandom)"  -D"KBUILD_MODNAME=KBUILD_STR(frandom)" -c -o /home/gr/frandom/frandom-master/frandom.o /home/gr/frandom/frandom-master/frandom.c
(cat /dev/null;   echo kernel//home/gr/frandom/frandom-master/frandom.ko;) > /home/gr/frandom/frandom-master/modules.order
make -f ./scripts/Makefile.modpost
  find /home/gr/frandom/frandom-master/.tmp_versions -name '*.mod' | xargs -r grep -h '\.ko$' | sort -u | sed 's/\.ko$/.o/' | scripts/mod/modpost   -i ./Module.symvers -I /home/gr/frandom/frandom-master/Module.symvers  -o /home/gr/frandom/frandom-master/Module.symvers -S -w  -s -T -
  gcc -Wp,-MD,/home/gr/frandom/frandom-master/.frandom.mod.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.8/include -I./arch/arm/include -Iarch/arm/include/generated/uapi -Iarch/arm/include/generated  -Iinclude -I./arch/arm/include/uapi -Iarch/arm/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-dwarf2-cfi-asm -mabi=aapcs-linux -mno-thumb-interwork -mfpu=vfp -funwind-tables -marm -D__LINUX_ARM_ARCH__=7 -march=armv7-a -msoft-float -Uarm -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fno-var-tracking-assignments -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -DCC_HAVE_ASM_GOTO  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(frandom.mod)"  -D"KBUILD_MODNAME=KBUILD_STR(frandom)" -DMODULE  -c -o /home/gr/frandom/frandom-master/frandom.mod.o /home/gr/frandom/frandom-master/frandom.mod.c
  ld -EL -r  -T ./scripts/module-common.lds --build-id  -o /home/gr/frandom/frandom-master/frandom.ko /home/gr/frandom/frandom-master/frandom.o /home/gr/frandom/frandom-master/frandom.mod.o
make[1]: Leaving directory `/home2/src/linux-headers-4.2.3-sunxi'
CHANGELOG  description-pak  frandom.c   frandom.mod.c  frandom.o  Makefile       Module.symvers  usr
debian     etc              frandom.ko  frandom.mod.o  INSTALL    modules.order  README
thanks!
Guillaume
There is / must be a link to headers / sources on all images for at least a year. If you did an kernel upgrade, than you need to upgrade headers too.
I checked some of my running configurations and all have a valid link.
Ahaa, I see. Naming is wrong.
BTW. Latest image works as expected. I compiled some driver without a problem.
Igor,
let's see with 4.6 :ph34r: I keep you in touch if needed.
1/ I have observed the situation from Armbian 4.3 -> 4.5
2/ Or is it the "image-only" kernel 4.5 you tendered me to check if zram module was ok. I switched back to 4.4 after, reinstalling all the 4.4 (kernel, header, boot, etc.), then installing my own compiled 4.5, then overwritten with the Armbian 4.5 you have published.
=> you cannot imagine all the tricky things your users(&fans) can do!
Thks!
@Igor
testing beta Armbian 4.6 kernel 4.2.5-sunxi => link is here: FIXED or NON-ISSUE :) thanks!
gr@bpi:~$ ll /lib/modules/4.2.5-sunxi/
total 1272
drwxr-xr-x 3 root root   4096 Nov  1 21:34 ./
drwxr-xr-x 4 root root   4096 Nov  1 21:32 ../
lrwxrwxrwx 1 root root     34 Nov  1 21:07 build -> /usr/src/linux-headers-4.2.5-sunxi/
drwxr-xr-x 9 root root   4096 Nov  1 21:34 kernel/
-rw-r--r-- 1 root root 363960 Nov  1 21:07 modules.alias
-rw-r--r-- 1 root root 371810 Nov  1 21:07 modules.alias.bin
-rw-r--r-- 1 root root  15005 Nov  1 21:07 modules.builtin
-rw-r--r-- 1 root root  17938 Nov  1 21:07 modules.builtin.bin
-rw-r--r-- 1 root root  84867 Nov  1 21:07 modules.dep
-rw-r--r-- 1 root root 132053 Nov  1 21:07 modules.dep.bin
-rw-r--r-- 1 root root    128 Nov  1 21:07 modules.devname
-rw-r--r-- 1 root root  41209 Nov  1 21:07 modules.order
-rw-r--r-- 1 root root     55 Nov  1 21:07 modules.softdep
-rw-r--r-- 1 root root 104578 Nov  1 21:07 modules.symbols
-rw-r--r-- 1 root root 133118 Nov  1 21:07 modules.symbols.bin
Edited by wildcat_paris
