ARMBIAN's GCC for OPi Zero doesn't compile threads
serkam
Hi
I am trying to compile a program test for my new OPi Zero that is running ARMBIAN.
From a Hello World program test, I am trying to create a thread that will blink the led at PA17 gpio pin, but GCC's linker complains saying that can't locate pthread_create() function. I am using pthread.h.
Somebody found similar issue?
Sergio
Hi jernej
The problem is that I am using Visual Studio with Linux Extension Plugin to remotely compile my program and, despite the program is compiled inside OPi Zero environment, I don't know where in VS I can modify the compiling parameters to adjust -lpthread option.
I am searching for how to place -lpthread option yet.
Sergio
Hi jernej and martinayotte.
Yessss, apparently worked.
I put in Visual Studio's Project/Configuration Properties/Linker/Additional Options/-lpthread and immediately the compilation was done.
I don't know if all the rest is OK.
I will post the results soon.
Thank you all.
Sergio
Working perfectly:
#include <unistd.h>
#include <pthread.h>
#include <cstdio>
#include <stdlib.h>
#include <stdio.h>
#include <time.h>
#include "string.h"
#include "gpio_lib.h"
void *thread_BLINKY(void *arg);
int main()
	char status = 1;
	char dado[80];
	int ret = 0;
	pthread_t s_thread_BLINKY;
	printf("hello from ConsoleApplication1! %s %s\n", __DATE__, __TIME__);
	ret = pthread_create(&s_thread_BLINKY, NULL, thread_BLINKY, (void *)NULL);
	if (ret < 0)
		printf("WARPTEC: nao conseguiu criar thread BLINKY\n");
	while (status)
		printf("comando = ");
		scanf("%s", dado);
		if (!strcmp("fim", dado)) status = 0;
    return 0;
	sunxi_gpio_init();
	sunxi_gpio_set_cfgpin(SUNXI_GPA(17), SUNXI_GPIO_OUTPUT);
	while (1)
		sunxi_gpio_output(SUNXI_GPA(17), 1);
		usleep(200000);
		sunxi_gpio_output(SUNXI_GPA(17), 0);
		usleep(100000);
		usleep(200000);
		usleep(500000);
Thank you.
Sergio
