Cubieboard1 problem running from nand <fs mount fail, jump to fel>
blades
Hi to all, I have a Cubieboard1 and it seems it can't boot from nand after running nand-sata-install script.
The output I get through ttl is:
HELLO! BOOT0 is starting!
boot0 version : 1.5.1
dram size =1024
Succeed in opening nand flash.
Succeed in reading Boot1 file head.
The size of Boot1 is 0x0003c000.
The file stored in 0X00000000 of block 2 is perfect.
Check is correct.
Ready to disable icache.
Succeed in loading Boot1.
Jump to Boot1.
[       0.133] boot1 version : 1.4.0
[       0.133] pmu type = 3
[       0.134] bat vol = 0
[       0.161] axi:ahb:apb=3:2:2
[       0.161] set dcdc2=1400, clock=1008 successed
[       0.163] key
[       0.175] no key found
[       0.175] flash init start
[       2.468] flash init finish
[       2.468] fs init ok
[       2.469] unkown fs type in the input file, FS_FAIL!
[       2.473] fs mount fail, jump to fel
and stops there.
I tested both Debian and Ubuntu server and gui images
/tmp/nand-sata-install.log shows mkfs.vfat /dev/nand1 fails.
mkfs.vfat: invalid option -- 'q'
I guess "-qF" was added just like what is done for all mkfs.ext4 in the script.
Can this be fixed next version? Cubieboard is declared 'end of support' now.
5 minutes ago, ykchavan said:
It is from vanilla "Armbian_5.25_Cubieboard_Ubuntu_xenial_default_3.4.113_desktop". I did not do "apt-get upgrade" because last time it upgraded kernel to 4.11.
That's not possible unless you manually installed NEXT (4.11.x) packages. default can only upgrade to next default kernel, which is still 3.4.113, last Armbian build is 5.30
This is the log link  http://sprunge.us/PRDE
Somehow usb-wifi dongle is getting detected as 'enx0013ef70247b' and not as 'wlan0'.
Last  installation, I replaced /usr/lib/arm-linux-gnueabihf/mesa/* with '/usr/lib/arm-linux-gnueabihf/glshim/*'. Openarena worked nicely until reboot. Then I started getting 'mali_drm' related errors like mentioned glshim thread.
