reamond Posted February 11, 2017 Share Posted February 11, 2017 I would like to remove wifi from my Zero... dont need it. The device will not be used network connected.It will serve as an OTG usb dongle only.How to remove or reinstall all wifi related components?It would be also great how to enable / disable ethernet connection from command line... is it justnmcli network off / nmcli network onor is there a more efficient way to do it? Link to comment Share on other sites More sharing options...
martinayotte Posted February 12, 2017 Share Posted February 12, 2017 If you use Mainline, then simply remove the whole xradio paragraph in DT. Link to comment Share on other sites More sharing options...
reamond Posted February 13, 2017 Author Share Posted February 13, 2017 ... I am not not sure what you mean...?I removed xradio from the /etc/modules#gpio_sunxi#w1-sunxi#w1-gpio#w1-therm#sunxi-cirxradio_wlanxradio_wlanIs that make the trick? I also see that there have been two lines with xradio... I wonder why. /R Link to comment Share on other sites More sharing options...
martinayotte Posted February 13, 2017 Share Posted February 13, 2017 That is also another solution ... Link to comment Share on other sites More sharing options...
reamond Posted February 14, 2017 Author Share Posted February 14, 2017 So, I did the change in the /etc/modules ,and checked that the modules are not loaded with the command "less /proc/modules"and I also set "h3consumption wifi-hw off"Strangely after the reboot when I do "nmcli radio"WIFI-HW WIFI WWAN-HW WWAN enabled disabled enabled enabled It shows basicly wifi-hw enabled...., but at the same time if I run h3consumption -p...all wifi related data is gone from the printout.So... is it on or off?... Or only partly initiated? Link to comment Share on other sites More sharing options...
