nemonein Posted February 19, 2017 Share Posted February 19, 2017 Hi. I'm using CubieTruck and Armbian mainline up to dated version. The CT is a headless server, so I don't connect any cable to it. However, one day the ssh server in CT did not work, I tried to connect CT to a monitor using HDMI cable. Even though I connect a cable, I could not see anything, and the monitor said 'No signal'. (Well, if the hdmi cable was connected, and CT is booted with it, the output is ok with hdmi signal.) If I connect with a vga cable, there is no problem. Here's what I want. I want to see the screen when I connect CT with a hdmi cable, even if the cable has not been connected. (I hope you understand what I mean..) I followed this, but there was no difference. https://docs.armbian.com/Hardware_Allwinner/#how-to-reconfigure-video-output Any help would be appreciated. Thanks. Link to comment Share on other sites More sharing options...
Igor Posted February 19, 2017 Share Posted February 19, 2017 I should already work out of the box - I think you get 1024x768 if EDID detection failed. Are you perhaps using self configured desktop? Link to comment Share on other sites More sharing options...
nemonein Posted February 19, 2017 Author Share Posted February 19, 2017 @Igor : Thank you for reply. It is not a desktop, just a server. I just installed a few packages(ftp server, nginx, nfs server, etc). Link to comment Share on other sites More sharing options...
zador.blood.stained Posted February 19, 2017 Share Posted February 19, 2017 I think if HDMI wasn't detected at boot time, it will switch off to VGA output and disable HDMI if we are talking about mainline/simplefb configuration. I think HPD can be disabled via u-boot environment to prevent HDMI shutdown and VGA support may have to be disabled at compile-time too. Link to comment Share on other sites More sharing options...
Igor Posted February 19, 2017 Share Posted February 19, 2017 Yes, I just checked. It's set to VGA if nothing come up on HDMI. This is the console output: U-Boot 2017.01-armbian (Feb 02 2017 - 02:21:14 +0100) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubietruck I2C: ready DRAM: 2 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment Setting up a 1024x768 vga console (overscan 0x0) In: serial Out: vga Err: vga SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c50000 Hit any key to stop autoboot: 0 6944 bytes read in 156 ms (43 KiB/s) switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Link to comment Share on other sites More sharing options...
nemonein Posted February 19, 2017 Author Share Posted February 19, 2017 Thank both of you. So, is it impossible to set to HDMI? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted February 19, 2017 Share Posted February 19, 2017 So, is it impossible to set to HDMI? Should be possible by setting u-boot environment - something like "monitor=hdmi" and "hpd=0" Link to comment Share on other sites More sharing options...
nemonein Posted February 19, 2017 Author Share Posted February 19, 2017 @zador.blood.stained I did try that, but nothing changes. I might have done something wrong. I just followed the document(https://docs.armbian.com/Hardware_Allwinner/#how-to-reconfigure-video-output), and succeeded to make boot.scr file. Is there anything I have to add? Link to comment Share on other sites More sharing options...
Igor Posted February 19, 2017 Share Posted February 19, 2017 Set some fixed resolution, monitor to hdmi, disabled hdp, disabled edid ... save that into u-boot environment, otherwise it wont work. Plan B: recompile u-boot with disabled VGA support and it should also be fine. Link to comment Share on other sites More sharing options...
nemonein Posted February 20, 2017 Author Share Posted February 20, 2017 I tried.. but failed. The output is always through the vga port. Here's my boot.cmd. setenv video-mode sunxi:1920x1080-24@60,monitor=hdmi,hpd=0,edid=0 saveenv reset Then I compiled it. sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr I rebooted the CT, twice(or more), but the result is the same. I changed the resolutions, but no difference. Link to comment Share on other sites More sharing options...
Igor Posted February 20, 2017 Share Posted February 20, 2017 Than proceed to plan B, which is less user friendly but it must work. http://git.denx.de/?p=u-boot.git;a=blob;f=configs/Cubietruck_defconfig;h=4ac128533826f66ad7cd92d9edf9574aad263489;hb=HEAD Comment out # CONFIG_VIDEO_VGA=y and recompile. Link to comment Share on other sites More sharing options...
nemonein Posted February 21, 2017 Author Share Posted February 21, 2017 I compiled and installed Uboot, but it does not work either. I compiled uboot using these tools. OS : Ubuntu 16.04(64bit) Source : git://git.denx.de/u-boot.git Toolchain : https://releases.linaro.org/components/toolchain/binaries/6.2-2016.11/arm-linux-gnueabihf/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf.tar.xz I successfully made u-boot-sunxi-with-spl.bin, and installed it to my SD card, using dd command. This is my Uboot file.(https://drive.google.com/file/d/0BwNiQ50_PJd2ZTVRWUg2LW5pVmc/view?usp=sharing) Vga output is defenitely dead. It's not working at all whether it is connected or not at the boot time. However, hdmi output is only working when it's connected at the boot time. I decide not to use hdmi out for the time being. Anyway, thank you for your concern. I really appreciate it. Link to comment Share on other sites More sharing options...
radojko Posted April 25, 2018 Share Posted April 25, 2018 Hi, did you find solution, I have the same problem Link to comment Share on other sites More sharing options...
nemonein Posted April 29, 2018 Author Share Posted April 29, 2018 @radojko No, I could not find any. Link to comment Share on other sites More sharing options...
radojko Posted April 29, 2018 Share Posted April 29, 2018 I found that my kernel is3.4.112-sun8i(my board is H3) so I have to change parameters using FEX(/boot/script.bin), not config file as in mainline kernel. But, I didn't found right parameters yet. Link to comment Share on other sites More sharing options...
