gatnyeu Posted March 3, 2017 Share Posted March 3, 2017 (edited) Hi there! First of all thanks for all the great work that you do here! I did a fresh install of the latest nightly (5.26.170227) and I can't mount usb sotrage devices or acces their content. The OPiZero detects the device but it doens't mount it. I can see the device by running sudo fdisk -l However if I try to mount it manually I get this error: sudo mount /dev/sda /media/usb mount: wrong fs type, bad option, bad superblock on /dev/sda, missing codepage or helper program, or other error In some cases useful info is found in syslog - try dmesg | tail or so. I've tried with three devices and none of them work with the OPZero. They all work on my PC and Raspberry pi. Edited March 4, 2017 by zador.blood.stained Moved to "Free" section - no official support for nightlies Link to comment Share on other sites More sharing options...
gatnyeu Posted March 4, 2017 Author Share Posted March 4, 2017 Solved by mounting sda1 instead of sda. Running blkid actually reports the drive as sda1 instead of sda. Is there a way to enable automounting a drive when you plug it in? Thanks! Link to comment Share on other sites More sharing options...
gnasch Posted March 5, 2017 Share Posted March 5, 2017 apt-cache show usbmount apt-cache show pmount best, gnasch Link to comment Share on other sites More sharing options...
