Clearfogbase - change dtb
tbcdns
Hi,
I have a clearfogbase board. I successfully installed armbian (4.4.45 upgraded to 4.4.51).
Most of the components are working fine (SFP, intel 7260 wifi...), however I think I am using the dtb file of the clearfog pro, the second ethernet port is not working:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.51-mvebu (root@devel) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #5 SMP Thu Feb 23 21:02:25 CET 2017
[    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=50c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: SolidRun Clearfog Pro A1
[    0.000000] Malformed early option 'loglevel'
[    0.000000] cma: Reserved 16 MiB at 0x3f000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 262144
[    0.000000] free_area_init_node: node 0, pgdat c0b983c0, node_mem_map ef6f8000
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:31
[    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
[    0.000000] PERCPU: Embedded 366 pages/cpu @ef3fa000 s1467312 r8192 d23632 u1499136
[    0.000000] pcpu-alloc: s1467312 r8192 d23632 u1499136 alloc=366*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260416
[    0.000000] Kernel command line: selinux=0 cgroup_disable=memory scandelay root=/dev/mmcblk0p1 rw rootfstype=ext4 console=ttyS0,115200 loglevel=${verbosity} rootwait
[    2.886555] mvneta f1030000.ethernet eth1: [0]: could not detect attached switch
[    2.886560] mvneta f1030000.ethernet eth1: [0]: couldn't create dsa switch instance (error -22)
I tried to update /boot/armbianEnv.txt and /boot/boot.cmd to specify the armada-388-clearfog-base dtb file, without success.
How could I load the correct dtb, should I re-compile u-boot?
Thanks
Just installed and updated a fresh Xenial/default image.  Works fine out of the box
root@clearfogbase:~# cat /proc/device-tree/model ; echo
SolidRun Clearfog Base A1
root@clearfogbase:~# dpkg -l | grep linux-u-boot
ii  linux-u-boot-clearfogbase-default 5.25                            armhf        Uboot loader 2013.01
