lightdm won't run -- new install -- jessie
pattena
Hello,
I am just trying to set up a pcduino3 nano with Debian Jessie.
I downloaded 4.9.7 and put it onto SD card, booted, logged into my sudo account, and then
apt-get install lightdm
followed by
apt-get update
apt-get upgrade
as per "Getting Started" guide.  I now have 4.9.12
LIghtdm fails to start with following message:
systemctl status lightdm.service -l
● lightdm.service - Light Display Manager
   Loaded: loaded (/lib/systemd/system/lightdm.service; enabled)
   Active: failed (Result: start-limit) since Tue 2017-03-07 21:41:18 CET; 17min ago
     Docs: man:lightdm(1)
  Process: 1460 ExecStart=/usr/sbin/lightdm (code=exited, status=1/FAILURE)
  Process: 1457 ExecStartPre=/bin/sh -c [ "$(cat /etc/X11/default-display-manager 2>/dev/null)" = "/usr/sbin/lightdm" ] (code=exited, status=0/SUCCESS)
 Main PID: 1460 (code=exited, status=1/FAILURE)
Mar 07 21:41:18 pcduino3nano systemd[1]: lightdm.service: main process exited, code=exited, status=1/FAILURE
Mar 07 21:41:18 pcduino3nano systemd[1]: Failed to start Light Display Manager.
Mar 07 21:41:18 pcduino3nano systemd[1]: Unit lightdm.service entered failed state.
Mar 07 21:41:18 pcduino3nano systemd[1]: lightdm.service holdoff time over, scheduling restart.
Mar 07 21:41:18 pcduino3nano systemd[1]: Stopping Light Display Manager...
Mar 07 21:41:18 pcduino3nano systemd[1]: Starting Light Display Manager...
Mar 07 21:41:18 pcduino3nano systemd[1]: lightdm.service start request repeated too quickly, refusing to start.
Mar 07 21:44:42 pcduino3nano systemd[1]: Stopped Light Display Manager.
I tried
dpkg-reconfigure lightdm
but no change.
Any suggestions?
Thanks for your reply MacBreaker.
The problem persisted, but I found a log file that said Xserver not found.  I (re?)installed Xserver and now I get a login screen, but
I can't log in with either my account or root --- no error message on screen -- just redisplay of login screen.
Does anybody know what log file I should be looking for to find out what's not working?
I think it was Xserver-xorg that I installed.  I don't know if that's the same thing.
I forget what I did after that, but I got sign-in working.  But the Synaptic that I installed doesn't prompt me for pswd and just disappears.
Anyway, it's all in the past now -- I've learned about SSH, and the little acrylic box is now sitting in a dark place with just power and ethernet cables in it
