DoubleMalt Posted March 23, 2017 Share Posted March 23, 2017 Any hints? Link to comment Share on other sites More sharing options...
0 Igor Posted March 23, 2017 Share Posted March 23, 2017 https://forum.armbian.com/index.php?/search/&q=dkms Link to comment Share on other sites More sharing options...
0 DoubleMalt Posted March 23, 2017 Author Share Posted March 23, 2017 The only thread that has some relationship to the problem is But it also doesn't talk about the problem. Is there any Kernel version that is known to work with ZFS? Is there any reason the mainline kernel on ARM cannot work with the SPL Kernel module? Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted March 23, 2017 Share Posted March 23, 2017 First, generic Ubuntu/Debian DKMS packages may not work on Armbian since we provide kernel versions that we can provide for different devices and not ones ubuntu/Debian has. Second, DKMS recompilation on kernel upgrade is broken, so please keep this in mind. If you want ZFS you need to find the latest zfs sources (this?) and either compile them on the device (if zfs supports out of tree builds) or use the Armbian build system on x64 Ubuntu Xenial to create a patched kernel packages. Please note that kernel headers package should be already installed so you don't need to install "linux-headers-$(uname -r)" if build instructions/tutorials suggest doing that. Link to comment Share on other sites More sharing options...
0 tkaiser Posted March 23, 2017 Share Posted March 23, 2017 And just to feed search engines or to influence hits a little bit: http://jrs-s.net/2015/02/03/will-zfs-and-non-ecc-ram-kill-your-data/ Armbian, ZFS, +no ECC DRAM, SBC, ECC, urban myth. Out of curiosity: why not btrfs instead since you're already using an advanced mainline kernel version? Link to comment Share on other sites More sharing options...
0 DoubleMalt Posted March 23, 2017 Author Share Posted March 23, 2017 Because I want to install https://flynn.io and that requires ZFS unfortunately. Otherwise I'd be happy to go with btrfs. Link to comment Share on other sites More sharing options...
0 tkaiser Posted March 23, 2017 Share Posted March 23, 2017 42 minutes ago, DoubleMalt said: Because I want to install https://flynn.io and that requires ZFS unfortunately. Well, if you want something that works almost as badly as on a i.MX6 then simply choose an ASRock C70M1 combined with 16.04 x64. Only downside: +20W idle consumption. I would walkd the extra mile and get an Intel box with ECC DRAM though for this type of application. Link to comment Share on other sites More sharing options...
0 DoubleMalt Posted March 23, 2017 Author Share Posted March 23, 2017 I just wanted to put my idle Cubox 4x4 to work for personal projects. If I would use it for something real, I would definitely go your way. Link to comment Share on other sites More sharing options...
Question
DoubleMalt
Any hints?
7 answers to this question
