utdrmac Posted March 28, 2017 Share Posted March 28, 2017 Hi. Is there no support for btrfs in the latest armbian-ubuntu-xenial for Pine64s? Linux pine54 3.10.104-pine64 #2 SMP PREEMPT Thu Feb 23 22:26:21 CET 2017 aarch64 aarch64 aarch64 GNU/Linux root@pine54:~# mkfs.btrfs /dev/sda1 btrfs-progs v4.4 See http://btrfs.wiki.kernel.org for more information. failed to open /dev/btrfs-control skipping device registration: No such file or directory Label: (null) UUID: d8362fb9-1b9c-4d92-8222-6745f842efcf Node size: 16384 Sector size: 4096 Filesystem size: 7.04GiB Block group profiles: Data: single 8.00MiB Metadata: DUP 368.62MiB System: DUP 12.00MiB SSD detected: no Incompat features: extref, skinny-metadata Number of devices: 1 Devices: ID SIZE PATH 1 7.04GiB /dev/sda1 root@pine54:~# mount /dev/sda1 /opt/ mount: unknown filesystem type 'btrfs' root@pine54:~# modprobe btrfs modprobe: FATAL: Module btrfs not found in directory /lib/modules/3.10.104-pine64 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted March 28, 2017 Share Posted March 28, 2017 BTRFS is enabled only on kernels 4.4 and higher. You can recompile this kernel with BTRFS support, but dealing with any issues, instability and possible incompatibilities with such an old version is up to you. 2 Link to comment Share on other sites More sharing options...
