RK3399 Orange Pi
Igor
piter75 thanks a lot, now it works as it should.
Be sure to ask the developer to fix this in the following distributions.
Do you know how to get the standard audio output to work?
Aplay -l command output:
**** List of PLAYBACK Hardware Devices ****
card 0: Dummy [Dummy], device 0: Dummy PCM [Dummy PCM]
  Subdevices: 7/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
card 1: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
  Subdevices: 7/8
card 1: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
  Subdevices: 8/8
card 2: realtekrt5651co [realtek,rt5651-codec], device 0: ff880000.i2s-rt5651-aif1 rt5651-aif1-0 [ff880000.i2s-rt5651-aif1 rt5651-aif1-0]
  Subdevices: 0/1
card 3: rockchiphdmi [rockchip,hdmi], device 0: ff8a0000.i2s-i2s-hifi i2s-hifi-0 [ff8a0000.i2s-i2s-hifi i2s-hifi-0]
  Subdevices: 0/1
card 4: ROCKCHIPSPDIF [ROCKCHIP,SPDIF], device 0: ff870000.spdif-dit-hifi dit-hifi-0 [ff870000.spdif-dit-hifi dit-hifi-0]
  Subdevices: 0/1
good day everyone. The situation with bluetooth was repeated again after the last update. Only now the service file is called not rk3399-bluetooth.service, but bluetooth.service and the content is different there. Please help fix the problem.
You can share instructions on how you build fresh kernels for orange pi rk3399 @martinayotte
Maybe something from these kernels is like https://github.com/radxa/debos-radxa/releases
with minimal patches?
I lived on the official kernel for quite a long time with loading via eMMC, but something went wrong and I want to try a fresh kernel
I also ask you to give a link to a fresh image of ubuntu.
It is also not clear that the images from orange pi4 are suitable for the orange pi rk3399 board ?
https://www.armbian.com/orange-pi-4/
PS. I don't need bluetooth and wifi
Edited by whitefox
They are not.
Orangepi 4/4B and Orangepi RK3399 are independent boards. Latter does not have a maintainer to take care of it, therefore no automatic built images are available for download. However you can always use the build framework to build your own image. However no guarantee that everything works or boots at all. https://docs.armbian.com/Developer-Guide_Build-Preparation/
21.06.2022 в 21:12, Werner сказал:
They are not.
Thanks. I build current image
total size is 45.84M  speedup is 1.00
[ .... ] Updating initramfs... [ update-initramfs -uv -k 5.15.49-rockchip64 ]
[ o.k. ] Updated initramfs. [ for details see: /root/build/output/debug/install.log ]
[ .... ] Re-enabling [ initramfs-tools hook for kernel ]
[ o.k. ] Unmounting [ /root/build/.tmp/mount-478cc97c-5aea-436e-a8f9-72514acb9f5b/ ]
[ o.k. ] Free SD cache [ 11% ]
[ o.k. ] Mount point [ 92% ]
[ o.k. ] Writing U-boot bootloader [ /dev/loop5 ]
[ o.k. ] SHA256 calculating [ Armbian_22.08.0-trunk_Orangepi-rk3399_jammy_current_5.15.49_minimal.img ]
[ warn ] GPG signing skipped - no GPG_PASS [ Armbian_22.08.0-trunk_Orangepi-rk3399_jammy_current_5.15.49_minimal.img ]
[ o.k. ] Done building [ /root/build/.tmp/image-478cc97c-5aea-436e-a8f9-72514acb9f5b/Armbian_22.08.0-trunk_Orangepi-rk3399_jammy_current_5.15.49_minimal.img ]
[ o.k. ] Runtime [ 296 min ]
[ o.k. ] Repeat Build Options [ ./compile.sh  BOARD=orangepi-rk3399 BRANCH=current RELEASE=jammy BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img  ]
After installing the current kernel, I noticed that the processor became very hot when idle
launched top
214 root       0 -20       0      0      0 R  48.8   0.0   1:46.14 kworker/u13:0-brcmf_wq/mmc0:0001:1
cat /proc/214/status
Umask:	0000
State:	D (disk sleep)
Tgid:	214
Ngid:	0
Pid:	214
PPid:	2
TracerPid:	0
Uid:	0	0	0	0
Gid:	0	0	0	0
FDSize:	64
Groups:
NStgid:	214
NSpid:	214
NSpgid:	0
NSsid:	0
Threads:	1
SigQ:	0/14866
SigPnd:	0000000000000000
ShdPnd:	0000000000000000
SigBlk:	0000000000000000
SigIgn:	ffffffffffffffff
SigCgt:	0000000000000000
CapInh:	0000000000000000
CapPrm:	000001ffffffffff
CapEff:	000001ffffffffff
CapBnd:	000001ffffffffff
CapAmb:	0000000000000000
NoNewPrivs:	0
Seccomp:	0
Seccomp_filters:	0
Speculation_Store_Bypass:	vulnerable
SpeculationIndirectBranch:	unknown
Cpus_allowed:	3f
Cpus_allowed_list:	0-5
Mems_allowed:	1
Mems_allowed_list:	0
voluntary_ctxt_switches:	11448782
nonvoluntary_ctxt_switches:	4691
What could be the problem of constant CPU consumption while idle? @Igor
How to disable this module?
update
Now it's clear why
Edited by whitefox
