Peter_1 Posted April 9, 2017 Share Posted April 9, 2017 I have a 3TB drive attached via SATA, with independent PSU. Despite my best efforts I cannot get it to be recognized as anything more than 801GB/746GiB. This drive works in another machine fine. I tried a low-level wipe (dd if=/dev/zero of=/dev/sda bs=1M), as well as creating new GPT partition tables. hdparm -I does correctly report info, but `cat /sys/class/block/sda/queue/physical_block_size` reports block size at 512. Any thoughts? Device Details: Orange Pi+ 2 Armbian Debian 3.4 image Linux XX 3.4.113-sun8i #10 SMP PREEMPT armv7l GNU/Linux WD 3TB Green (WD30EZRX) OS installed on eMMC on system Excerpt from kernel log when attaching drive: [ 4.534594] sd 0:0:0:0: [sda] 1565565868 512-byte logical blocks: (801 GB/746 GiB) [ 4.550334] sd 0:0:0:0: [sda] Write Protect is off [ 4.561887] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00 [ 4.562827] sd 0:0:0:0: [sda] No Caching mode page found [ 4.574843] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 4.590700] sd 0:0:0:0: [sda] No Caching mode page found [ 4.623980] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 4.698642] sda: sda1 [ 4.702202] sd 0:0:0:0: [sda] No Caching mode page found [ 4.702214] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 4.702226] sd 0:0:0:0: [sda] Attached SCSI disk hdparm -I : ATA device, with non-removable media Model Number: WDC WD30EZRX-00MMMB0 Serial Number: WD-WCAWZ1242100 Firmware Revision: 80.00A80 Transport: Serial, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0 Standards: Supported: 8 7 6 5 Likely used: 8 Configuration: Logical max current cylinders 16383 16383 heads 16 16 sectors/track 63 63 -- CHS current addressable sectors: 16514064 LBA user addressable sectors: 268435455 LBA48 user addressable sectors: 5860533168 Logical Sector size: 512 bytes Physical Sector size: 4096 bytes Logical Sector-0 offset: 0 bytes device size with M = 1024*1024: 2861588 MBytes device size with M = 1000*1000: 3000592 MBytes (3000 GB) cache/buffer size = unknown Capabilities: LBA, IORDY(can be disabled) Queue depth: 32 Standby timer values: spec'd by Standard, with device specific minimum R/W multiple sector transfer: Max = 16 Current = 0 DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 *udma4 udma5 udma6 Cycle time: min=120ns recommended=120ns PIO: pio0 pio1 pio2 pio3 pio4 Cycle time: no flow control=120ns IORDY flow control=120ns Link to comment Share on other sites More sharing options...
tkaiser Posted April 9, 2017 Share Posted April 9, 2017 7 minutes ago, Peter_1 said: I have a 3TB drive attached via SATA Most probably not. Orange Pi Plus 2 has no SATA, just a crappy/broken/ultra-slow USB-to-SATA catastrophe called GL830: http://www.cnx-software.com/2017/03/16/suptronics-x800-2-5-sata-drive-expansion-board-and-cases-for-raspberry-pi-23-and-odroid-c2-boards/#comments 2 Link to comment Share on other sites More sharing options...
Peter_1 Posted April 9, 2017 Author Share Posted April 9, 2017 OK, well it should be slower than crap but should still recognize the drive correctly, right? Link to comment Share on other sites More sharing options...
tkaiser Posted April 9, 2017 Share Posted April 9, 2017 No idea, the same crappy IC is on a Banana Pi M3 and there a connected WD with 4TB and a 3TB Seagate were recognized. IMO you should forget about the 'SATA connector' and better choose an external enclosure with some of those chips here: http://linux-sunxi.org/USB/UAS Link to comment Share on other sites More sharing options...
