Stable vs mainline for Next
ytn
Igor,
I noticed that your build script automatically parses a URL to determine what the current stable release is for "Next".
Since 4.3 is now officially released and has a number of features worth checking out, it would be nice if the build script offered an option to pick from stable vs. mainline.
For now I am just manually setting the KernelTag to "4.3", but it would be nice not to have to modify any of the scripts manually and have this be an option you can pick from.
Just a suggestion...
Thanks.
hi ytn,
in configuration.sh just replace "stable" by "mainline" and also comment non relevant patches in patching.sh
kernel 4.3.0 compiles ok, working also, but new features as sunxi-ss are not working I get
[    5.097091] sun4i-ss 1c15000.crypto-engine: no reset control found
[    5.098655] sun4i-ss 1c15000.crypto-engine: Die ID 0
[    5.098672] sun4i-ss 1c15000.crypto-engine: Fail to register md5
[    5.098947] sun4i-ss: probe of 1c15000.crypto-engine failed with error -22
otherwise the patch to test the sunxi prng doesn't work. Other new features seem to have no effect.
Edited by wildcat_paris
Just define a KERNELTAG in a call script and this way you override automatic selection.
We can also add a parameter for MAINLINE / STABLE if that is less confusing?
Hi Igor,
A command line parameter to compile.sh would be nice e.g. "./compile.sh mainline"
if no parameter is passed in, then it could default to stable. That would make things a lot simpler and not require modifying any of the lib files or having to create separate call scripts to define KERNELTAG.
ytn,
thanks for the patch, you have spared me some time :)
ss seems to work in /proc/crypto
Linux version 4.3.0-sunxi (root@server1404) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #8 SMP Sat Nov 7 16:55:14 CET 2015
driver       : ecb-des3-sun4i-ss
module       : sun4i_ss
selftest     : passed
internal     : no
driver       : cbc-des3-sun4i-ss
driver       : ecb-des-sun4i-ss
driver       : cbc-des-sun4i-ss
driver       : ecb-aes-sun4i-ss
driver       : cbc-aes-sun4i-ss
driver       : sha1-sun4i-ss
driver       : md5-sun4i-ss
I am unsure about "just" a ./compile.sh mainline
as one need to be careful with patch management & kernel config in Igor's Armbian tools
ytn,
Thanks for the feedback on the testing. Any plans to test the other stuff like AES, SHA1 etc?
good question, I need to read soon or later the details of the crypto tests included in the kernel, I only see the following logs (the one with higher priorities for the kernel)
gr@bpi:~$ dmesg | grep test
[    0.410187] prandom: seed boundary self test passed
[    0.413319] prandom: 100 self tests passed
[    3.749688] alg: rsa: test failed on vector 4, err=-74
[    3.770417] alg: No test for 842 (842-generic)
[    3.809805] crc32: self tests passed, processed 225944 bytes in 1094875 nsec
[    3.810947] crc32c: self tests passed, processed 225944 bytes in 555042 nsec
[    3.877363] crc32_combine: 8373 self tests passed
[    3.945251] crc32c_combine: 8373 self tests passed
[    7.586234] xz_dec_test: module loaded
[    7.586260] xz_dec_test: Create a device node with 'mknod xz_dec_test c 248 0' and write .xz files to it.
as well as the tests marked as "passed" for sun4i_ss/arm/neon
gr@bpi:~$ cat /proc/crypto
module       : sun4i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : no
blocksize    : 8
min keysize  : 24
max keysize  : 24
ivsize       : 8
geniv        : <default>
module       : sun4i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : no
blocksize    : 8
min keysize  : 24
max keysize  : 24
ivsize       : 8
geniv        : <default>
module       : sun4i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : no
blocksize    : 8
min keysize  : 8
max keysize  : 8
ivsize       : 0
geniv        : <default>
module       : sun4i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : no
blocksize    : 8
min keysize  : 8
max keysize  : 8
ivsize       : 8
geniv        : <default>
module       : sun4i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : no
blocksize    : 16
min keysize  : 16
max keysize  : 32
ivsize       : 16
geniv        : <default>
module       : sun4i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : no
blocksize    : 16
min keysize  : 16
max keysize  : 32
ivsize       : 16
geniv        : <default>
module       : sun4i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ahash
async        : no
blocksize    : 64
digestsize   : 20
module       : sun4i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ahash
async        : no
blocksize    : 64
digestsize   : 16
driver       : hmac(sha256-neon)
module       : kernel
priority     : 250
refcnt       : 3
selftest     : passed
internal     : no
type         : shash
blocksize    : 64
digestsize   : 32
driver       : sha512-neon
module       : kernel
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : shash
blocksize    : 128
digestsize   : 64
driver       : sha384-neon
module       : kernel
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : shash
blocksize    : 128
digestsize   : 48
driver       : sha512-arm
module       : kernel
priority     : 250
refcnt       : 1
selftest     : passed
internal     : no
type         : shash
blocksize    : 128
digestsize   : 64
driver       : sha384-arm
module       : kernel
priority     : 250
refcnt       : 1
selftest     : passed
internal     : no
type         : shash
blocksize    : 128
digestsize   : 48
driver       : sha224-neon
module       : kernel
priority     : 250
refcnt       : 1
selftest     : passed
internal     : no
type         : shash
blocksize    : 64
digestsize   : 28
driver       : sha256-neon
module       : kernel
priority     : 250
refcnt       : 4
selftest     : passed
internal     : no
type         : shash
blocksize    : 64
digestsize   : 32
driver       : sha224-asm
module       : kernel
priority     : 150
refcnt       : 1
selftest     : passed
internal     : no
type         : shash
blocksize    : 64
digestsize   : 28
driver       : sha256-asm
module       : kernel
priority     : 150
refcnt       : 1
selftest     : passed
internal     : no
type         : shash
blocksize    : 64
digestsize   : 32
driver       : sha1-neon
module       : kernel
priority     : 250
refcnt       : 1
selftest     : passed
internal     : no
type         : shash
blocksize    : 64
digestsize   : 20
driver       : sha1-asm
module       : kernel
priority     : 150
refcnt       : 1
selftest     : passed
internal     : no
type         : shash
blocksize    : 64
digestsize   : 20
driver       : xts-aes-neonbs
module       : kernel
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : yes
blocksize    : 16
min keysize  : 32
max keysize  : 64
ivsize       : 16
geniv        : <default>
driver       : ctr-aes-neonbs
module       : kernel
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : yes
blocksize    : 1
min keysize  : 16
max keysize  : 32
ivsize       : 16
geniv        : <default>
driver       : cbc-aes-neonbs
module       : kernel
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : yes
blocksize    : 16
min keysize  : 16
max keysize  : 32
ivsize       : 16
geniv        : <default>
driver       : aes-asm
module       : kernel
priority     : 200
refcnt       : 5
selftest     : passed
internal     : no
type         : cipher
blocksize    : 16
min keysize  : 16
max keysize  : 32
Im trying to build the mainline kernel instead of the stable branch. In this topic i read that i need to change stable to mainline in configuration.sh, however i can not find where i need to do this.
Is it this line:  LINUXKERNEL="git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git" ?
Could someone point me into the right direction ?
To achieve this in current script is a bit hard but you are welcome to jump into testing branch, where this is possible out of the box. This was also one of the core reasons to rework the script.
Use this branch:
https://github.com/igorpecovnik/lib -b master
Remember to alter branch in this line before start and start from clean dir.
https://github.com/igorpecovnik/lib/blob/master/compile.sh#L78
It's a dev branch so please be patient ... and report if you encounter strange behavior.
Use this branch:
Thanks Igor, i will post my progress here.
