martinayotte Posted April 25, 2017 Share Posted April 25, 2017 I've added new patches for OrangePi-ZeroPlus and commited them. Like for OPiPrime done yesterday, the OrangePi-ZeroPlus WiFi still not working. I don't know why yet, although is more encouraging than OPiPrime, since at least the driver comes up in "lsmod" in the OrangePi-ZeroPlus, while for the Prime it didn't. Also another issue : OrangePi-ZeroPlus has an eMMC, I was able to do "nand-install-sata", but I'm unable to boot from it, although the MMC2 DT is part of U-Boot, for some reasons, it doesn't scan it. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted April 25, 2017 Share Posted April 25, 2017 8 minutes ago, martinayotte said: Also another issue : OrangePi-ZeroPlus has an eMMC, I was able to do "nand-install-sata", but I'm unable to boot from it, although the MMC2 DT is part of U-Boot, for some reasons, it doesn't scan it. Serial console messages? Link to comment Share on other sites More sharing options...
martinayotte Posted April 25, 2017 Author Share Posted April 25, 2017 Without any SD inserted : U-Boot SPL 2017.01-rc1-g5df570f-dirty (Apr 25 2017 - 10:01:27) DRAM: 512 MiB Failed to set core voltage! Can't set CPU frequency Trying to boot from MMC2MMC Device 1 not found spl: could not find mmc device. error: -19 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### And booting from SD, but stopping before kernel to get into U-Boot shell, "mmcinfo" just shows the MMC0, no MMC2 detected. It probably require an additionnal patch for SPL itself. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted April 26, 2017 Share Posted April 26, 2017 Is CONFIG_MMC_SUNXI_SLOT_EXTRA=2 set for the SPL defconfig? Link to comment Share on other sites More sharing options...
martinayotte Posted April 26, 2017 Author Share Posted April 26, 2017 Yes, I've forgotten that one, although I've used it a year ago for the Plus2E ... I'm was than able to access mmc2 with "ls mmc 1". But unfortunately I was still not able to boot, simply because I forgot that both SPL and U-Boot needed that, not only u-Boot. I'm currently redoing new build... EDIT : new build tested successfully ... Link to comment Share on other sites More sharing options...
happyzax Posted April 27, 2017 Share Posted April 27, 2017 Just wanted to chime in to say thanks for your efforts and ask if there is anything in need of testing. I spent the day running through the build and was able to get an image for the H5 version. I'm pretty new to Armbian, so I didn't do much with it. These boards run hot! I'm going to need some heat sinks and active cooling before I try to push it too hard. Anyway, I hope to contribute something to the effort eventually... when I figure out what I am doing! Link to comment Share on other sites More sharing options...
