Orange Pi Zero 2W overlay I2C SPI help
Go to solution Solved by kreestyahn,
How to enable i2c on PI8(SDA) and PI7(SCL)?
I'm newbie in linux and not really understand what am I actually doing so I tried to make it with chatgpt but still not working.
root@orangepizero2w:/# sudo i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- UU -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
It can't see any device, but there should be one on the 0x21.
Could somebody help me out with this?
dmesg | grep i2c [ 0.739582] i2c_dev: i2c /dev entries driver
[ 0.739878] mv64xxx_i2c 7081400.i2c: can't get pinctrl, bus recovery not supp orted
[ 0.740303] i2c 0-0036: Fixed dependency cycle(s) with /soc/pinctrl@300b000
[ 1.340117] sun50i-h616-pinctrl 300b000.pinctrl: unsupported function i2c0 on pin PI8
[ 1.340132] sun50i-h616-pinctrl 300b000.pinctrl: unsupported function i2c0 on pin PI7
[ 1.340141] mv64xxx_i2c 5002000.i2c: there is not valid maps for state defaul t
[ 1.340264] sun50i-h616-pinctrl 300b000.pinctrl: unsupported function i2c0 on pin PI8
[ 1.340279] sun50i-h616-pinctrl 300b000.pinctrl: unsupported function i2c0 on pin PI7
[ 1.340287] mv64xxx_i2c 5002000.i2c: there is not valid maps for state defaul t
[ 1.341370] axp20x-i2c 0-0036: AXP20x variant AXP313a found
[ 1.342890] axp20x-i2c 0-0036: AXP20X driver loaded
[ 269.046993] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 271.094978] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Tried to edit device tree via armbian-config (now it is probably kinda messy):
pinctrl@300b000 {
                        compatible = "allwinner,sun50i-h616-pinctrl";
                        reg = <0x300b000 0x400>;
                        interrupts = <0x00 0x33 0x04 0x00 0x34 0x04 0x00 0x35 0x04 0x00 0x2b 0x04 0x00 0x36 0x04 0x00 0x37 0x04 0x00 0x38 0x04 0x00 0x39 0x04>;
                        clocks = <0x02 0x1a 0x0f 0x10 0x00>;
                        clock-names = "apb\0hosc\0losc";
                        gpio-controller;
                        #gpio-cells = <0x03>;
                        interrupt-controller;
                        #interrupt-cells = <0x03>;
                        vcc-pc-supply = <0x11>;
                        vcc-pf-supply = <0x11>;
                        vcc-pg-supply = <0x12>;
                        vcc-ph-supply = <0x11>;
                        vcc-pi-supply = <0x11>;
                        phandle = <0x14>;
                        rgmii-pins {
                                pins = "PI0\0PI1\0PI2\0PI3\0PI4\0PI5\0PI7\0PI8\0PI9\0PI10\0PI11\0PI12\0PI13\0PI14\0PI15\0PI16";
                                function = "emac0";
                                drive-strength = <0x28>;
                                phandle = <0x29>;
                        i2c0-pins {
                                pins = "PI8\0PI7";
                                function = "i2c0";
                                bias-pull-up;
                                phandle = <0x1e>;
                        i2c2-ph-pins {
                                pins = "PH2\0PH3";
                                function = "i2c2";
                                phandle = <0x4b>;
                        i2c3-ph-pins {
                                pins = "PH4\0PH5";
                                function = "i2c3";
                                phandle = <0x4c>;
                        i2c4-ph-pins {
                                pins = "PH6\0PH7";
                                function = "i2c4";
                                phandle = <0x22>;
                        i2c3-pg-pins {
                                pins = "PG17\0PG18";
                                function = "i2c3";
                                phandle = <0x4d>;
                        i2c4-pg-pins {
                                pins = "PG15\0PG16";
                                function = "i2c4";
                                phandle = <0x4e>;
                        ir-rx-pin {
                                pins = "PH10";
                                function = "ir_rx";
                                phandle = <0x38>;
 mmc0-pins {
                                pins = "PF0\0PF1\0PF2\0PF3\0PF4\0PF5";
                                function = "mmc0";
                                drive-strength = <0x1e>;
                                bias-pull-up;
                                phandle = <0x13>;
                        mmc1-pins {
                                pins = "PG0\0PG1\0PG2\0PG3\0PG4\0PG5";
                                function = "mmc1";
                                bias-pull-up;
                                phandle = <0x15>;
                        mmc2-pins {
                                pins = "PC0\0PC1\0PC5\0PC6\0PC8\0PC9\0PC10\0PC11\0PC13\0PC14\0PC15\0PC16";
                                function = "mmc2";
                                bias-pull-up;
                                phandle = <0x19>;
                        rmii-pins {
                                pins = "PA0\0PA1\0PA2\0PA3\0PA4\0PA5\0PA6\0PA7\0PA8\0PA9";
                                function = "emac1";
                                phandle = <0x4f>;
                        spi0-pins {
                                pins = "PC0\0PC2\0PC4";
                                function = "spi0";
                                phandle = <0x24>;
                        spi0-cs0-pin {
                                pins = "PC3";
                                function = "spi0";
                                phandle = <0x25>;
                        spi1-pins {
                                pins = "PH6\0PH7\0PH8";
                                function = "spi1";
                                phandle = <0x26>;
                        spi1-cs0-pin {
                                pins = "PH5";
                                function = "spi1";
                                phandle = <0x50>;
                        spi1-cs1-pin {
                                pins = "PH9";
                                function = "spi1";
                                phandle = <0x27>;
                        uart0-ph-pins {
                                pins = "PH0\0PH1";
                                function = "uart0";
                                phandle = <0x1a>;
uart1-pins {
                                pins = "PG6\0PG7";
                                function = "uart1";
                                phandle = <0x51>;
                        uart1-rts-cts-pins {
                                pins = "PG8\0PG9";
                                function = "uart1";
                                phandle = <0x52>;
                        uart2-pins {
                                pins = "PI5\0PI6";
                                function = "uart2";
                                phandle = <0x53>;
                        uart2-rts-cts-pins {
                                pins = "PH7\0PH8";
                                function = "uart2";
                                phandle = <0x54>;
                        uart5-pins {
                                pins = "PH2\0PH3";
                                function = "uart5";
                                phandle = <0x55>;
                        i2c1-pi-pins {
                                pins = "PI7\0PI8";
                                function = "i2c1";
                                phandle = <0x57>;
                        i2c2-pi-pins {
                                pins = "PI9\0PI10";
                                function = "i2c2";
                                phandle = <0x58>;
                        i2c3-pa-pins {
                                pins = "PA10\0PA11";
                                function = "i2c3";
                                bias-pull-up;
                                phandle = <0x1f>;
                        uart2-pi-pins {
                                pins = "PI5\0PI6";
                                function = "uart2";
                                phandle = <0x1b>;
                        uart3-pi-pins {
                                pins = "PI9\0PI10";
                                function = "uart3";
                                phandle = <0x1c>;
                        uart4-pi-pins {
                                pins = "PI13\0PI14";
                                function = "uart4";
                                phandle = <0x1d>;
 pwm5-pin {
                                pins = "PA12";
                                function = "pwm5";
                                phandle = <0x3c>;
i2c@5002000 {
                        compatible = "allwinner,sun50i-h616-i2c\0allwinner,sun8i-v536-i2c\0allwinner,sun6i-a31-i2c";
                        reg = <0x5002000 0x400>;
                        interrupts = <0x00 0x06 0x04>;
                        clocks = <0x02 0x48>;
                        resets = <0x02 0x17>;
                        pinctrl-names = "default";
                        pinctrl-0 = <0x1e>;
                        status = "okay";
                        #address-cells = <0x01>;
                        #size-cells = <0x00>;
                        phandle = <0x62>;
                i2c@5002400 {
                        reg = <0x5002400 0x400>;
                        interrupts = <0x00 0x07 0x04>;
                        clocks = <0x02 0x49>;
                        resets = <0x02 0x18>;
                        status = "disabled";
                        phandle = <0x63>;
                i2c@5002800 {
                        reg = <0x5002800 0x400>;
                        interrupts = <0x00 0x08 0x04>;
                        clocks = <0x02 0x4a>;
                        resets = <0x02 0x19>;
                        phandle = <0x64>;
                i2c@5002c00 {
                        reg = <0x5002c00 0x400>;
                        interrupts = <0x00 0x09 0x04>;
                        clocks = <0x02 0x4b>;
                        resets = <0x02 0x1a>;
                        pinctrl-0 = <0x1f>;
                        phandle = <0x65>;
                        mfd@10 {
                                compatible = "x-powers,ac200";
                                reg = <0x10>;
                                clocks = <0x20>;
                                nvmem-cells = <0x21>;
                                nvmem-cell-names = "calibration";
                                phandle = <0x66>;
                                phy {
                                        compatible = "x-powers,ac200-ephy";
                                        status = "okay";
                                        phandle = <0x67>;
armbianEnv.txt:
verbosity=1
bootlogo=false
console=both
disp_mode=1920x1080p60
overlay_prefix=sun50i-h618
overlays=i2c0 i2c1 i2c2 i2c3 uart5
param_uart1_rtscts=1
param_uart2_rtscts=2
param_uart2_rtscts=3
param_uart2_rtscts=4
param_uart2_rtscts=5
rootdev=UUID=88b03ed8-436d-4226-bf01-975ceef8cc1b
rootfstype=ext4
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
4 часа назад, kreestyahn сказал:
chatgpt
You and I have more brains than this moron!
This is the diagram of your device.
Please publish the part of the DTS extracted directly from the working device:
dtc --sort -I fs -O dts  /sys/firmware/devicetree/base > dts-spi-out.txt
Only nodes: pio, i2c0_pins
And if you can find a complete pinout of the 40pin connector.
We will try to make the correct overlay.
Link to comment
                        rgmii-pins {
                                function = "emac0";
                                phandle = <0x29>;
                        i2c0-pins {
                                pins = "PI8\0PI7";
                                function = "i2c0";
                                bias-pull-up;
                                phandle = <0x1e>;
I apologize. I didn't notice the spoiler.
It seems that all PI pins (7, 8, 9, 10) are already occupied?
Link to comment
Well.. there was a little problem so i reinstalled the whole OS.
Currently I only modified armbianEnv.txt. I added this line: overlays:i2c0
I also installed armbian-config and found i2c0-pi in System/Hardware so I enabled it.
The device tree is currently unmodified so it has default configuration.
Should I remove the PI7-8 from rgmii-pins and then change the i2c0-pins to "PI8\0PI7"?
It has also a i2c0-pi-pins. Which one should I modify?
i2c0-pi-pins {
  pins = "PI5\0PI6";
  function = "i2c0";
  phandle = <0x56>;
i2c0-pins {
  pins = "PI6\0PI7";
  function = "i2c0";
  phandle = <0x1e>;
Link to comment
9 часов назад, kreestyahn сказал:
I'm at a loss.
I have a dataset h616.
And this corresponds to the DTS:
sun50i-h616.dtsi#L171
Probably nothing needs to be modified.
Just enable (apply standard overlay):
Write an overlay file sun50i-h616-i2c0.dts:
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun50i-h616-i2c";
	fragment@0 {
		target-path = "/aliases";
		__overlay__ {
			i2c0 = "/soc/i2c@5002000";
	fragment@1 {
		target = <&i2c0>;
		__overlay__ {
			status = "okay";
Compile the overlay:
dtc -I dts -O dtb -o sun50i-h616-i2c0.dtso sun50i-h616-i2c0.dts
copy sun50i-h616-i2c0.dtso file to /boot/dtb-**-sunxi/overlay/
armbianEnv.txt:
overlay_prefix=sun50i-h616
overlays=i2c0
P.S.
pins = "PI6", "PI7";
40-pin: 22, 5 number
Please check it out
Edited by going
Add P.S.
Link to comment
Yeah, I just realized that after the reinstall everything worked fine. Maybe I just messed up something before. Thank you for your help!
Now I have another issue with SPI. Can I write here or should I open a new topic?
Link to comment
  • going changed the title to Orange Pi Zero 2W overlay I2C SPI help
24 минуты назад, kreestyahn сказал:
Name topik: Orange Pi Zero 2W overlay I2C SPI help
Write here
Link to comment
  • Solution
Thanks,
So I have an SD Card module connected to SPI1 (CS0) pins.
root@orangepizero2w:~# dmesg | grep -i 'spi'
[    1.336073] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517
[    1.336093] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    1.336368] sun50i-h616-pinctrl 300b000.pinctrl: pin-230 (5011000.spi) status -517
[    1.336385] sun6i-spi 5011000.spi: Error applying setting, reverse things back
[    1.349503] spi-nor spi0.0: supply vdd not found, using dummy regulator
[    1.364641] spi-nor spi0.0: spi-nor-generic (16384 Kbytes)
[  234.215538] /dev/spidev1.0: Can't lookup blockdev
spidev-test:
root@orangepizero2w:/home/kvl/spidev-test# ./spidev_test -D /dev/spidev1.0 -v
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D  | ......@....▒..................▒.
RX | FF FF FF FF FF FF FC 17 FF FF FF FF FF FF FF FF FF FF F0 5F FF FF FF FF FF FF FF FF FF FF FF FF  | ......▒...........▒_............
armbian-config> System/Hardware: kp.png.7a510b298a75f6ffa4206c859353ffcc.png
armbian-config> device tree:
pinctrl@300b000 {
                        gpio-controller;
                        phandle = <0x14>;
                        rgmii-pins {
                                function = "emac0";
                                phandle = <0x29>;
                        i2c0-pins {
                                pins = "PI6\0PI7";
                                function = "i2c0";
                                phandle = <0x1e>;
                        i2c2-ph-pins {
                                pins = "PH2\0PH3";
                                function = "i2c2";
                                phandle = <0x4b>;
                        i2c3-pg-pins {
                                function = "i2c3";
                                phandle = <0x4d>;
                        i2c4-pg-pins {
                                function = "i2c4";
                                phandle = <0x4e>;
                        ir-rx-pin {
                                pins = "PH10";
                                function = "ir_rx";
                                phandle = <0x38>;
                        mmc0-pins {
                                function = "mmc0";
                                bias-pull-up;
                                phandle = <0x13>;
mmc1-pins {
                                function = "mmc1";
                                bias-pull-up;
                                phandle = <0x15>;
                        mmc2-pins {
                                function = "mmc2";
                                bias-pull-up;
                                phandle = <0x19>;
                        rmii-pins {
                                function = "emac1";
                                phandle = <0x4f>;
                        spi0-pins {
                                function = "spi0";
                                phandle = <0x24>;
                        spi0-cs0-pin {
                                pins = "PC3";
                                function = "spi0";
                                phandle = <0x25>;
                        spi1-pins {
                                function = "spi1";
                                phandle = <0x26>;
                        spi1-cs0-pin {
                                pins = "PH5";
                                function = "spi1";
                                phandle = <0x50>;
                        spi1-cs1-pin {
                                pins = "PH9";
                                function = "spi1";
                                phandle = <0x27>;
                        uart0-ph-pins {
                                pins = "PH0\0PH1";
                                function = "uart0";
                                phandle = <0x1a>;
                        uart1-pins {
                                pins = "PG6\0PG7";
                                function = "uart1";
                                phandle = <0x51>;
                                pins = "PG8\0PG9";
                                function = "uart1";
                                phandle = <0x52>;
                        uart5-pins {
                                pins = "PH2\0PH3";
                                function = "uart5";
                                phandle = <0x55>;
                        i2c0-pi-pins {
                                pins = "PI7\0PI8";
                                function = "i2c0";
                                phandle = <0x56>;
                        i2c1-pi-pins {
                                pins = "PI7\0PI8";
                                function = "i2c1";
                                phandle = <0x57>;
                        i2c2-pi-pins {
                                pins = "PI9\0PI10";
                                function = "i2c2";
                                phandle = <0x58>;
                        i2c3-pa-pins {
                                function = "i2c3";
                                bias-pull-up;
                                phandle = <0x1f>;
                        uart2-pi-pins {
                                pins = "PI5\0PI6";
                                function = "uart2";
                                phandle = <0x1b>;
                        uart3-pi-pins {
                                pins = "PI9\0PI10";
                                function = "uart3";
                                phandle = <0x1c>;
                        uart4-pi-pins {
                                function = "uart4";
                                phandle = <0x1d>;
                        pwm5-pin {
                                pins = "PA12";
                                function = "pwm5";
                                phandle = <0x3c>;
                spi@5010000 {
                        compatible = "allwinner,sun50i-h616-spi\0allwinner,sun8i-h3-spi";
                        reg = <0x5010000 0x1000>;
                        interrupts = <0x00 0x0c 0x04>;
                        clocks = <0x02 0x4f 0x02 0x4d>;
                        clock-names = "ahb\0mod";
                        dmas = <0x23 0x16 0x23 0x16>;
                        dma-names = "rx\0tx";
                        resets = <0x02 0x1c>;
                        pinctrl-0 = <0x24 0x25>;
                        phandle = <0x69>;
                        flash@0 {
                                #size-cells = <0x01>;
                                compatible = "jedec,spi-nor";
                                reg = <0x00>;
                                spi-max-frequency = <0x2625a00>;
                spi@5011000 {
                        reg = <0x5011000 0x1000>;
                        interrupts = <0x00 0x0d 0x04>;
                        clocks = <0x02 0x50 0x02 0x4e>;
                        dmas = <0x23 0x17 0x23 0x17>;
                        resets = <0x02 0x1d>;
                        pinctrl-0 = <0x26 0x27 0x50>;
                        status = "okay";
                        phandle = <0x6a>;
                        spidev@0 {
                                compatible = "rohm,dh2228fv";
                                status = "okay";
                                reg = <0x00>;
                                spi-max-frequency = <0xf4240>;
Link to comment
