aliend Posted May 9, 2017 Share Posted May 9, 2017 Hi first of all Please excuse my poor English ! I install ubuntu lagecy server on my orange pi pc + and then install it on nand using : $nand-sata-install now when i power on my board with sd card (sd card without any image file) my root file system will mount on mmcb1k0p1 and if I insert my sd card after power on root will mount on mmcb1k1p1 (I now both mmcb1k1p1 & mmcb1k0p1 are my emmc) Now i need to automount my sd card and in my case I insert sd card before power on and as a result I add this line in fstab file #/dev/mmcb1k0p1 /mnt ext4 0 1 but it doesn't work ! how can i mount my sd card automatically ? Link to comment Share on other sites More sharing options...
martinayotte Posted May 9, 2017 Share Posted May 9, 2017 You seems to confuse between "1" and "l" ... Also, make sure there is no more u-boot sectors in the inserted sdcard, otherwise it will boot from it. Link to comment Share on other sites More sharing options...
aliend Posted May 9, 2017 Author Share Posted May 9, 2017 1 hour ago, martinayotte said: You seems to confuse between "1" and "l" ... I correct my fstab file but still i can't automount sd card (there in no any u-boot sectors in sdcard) /dev/mmcblk0p1 /mnt ext4 0 1 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 9, 2017 Share Posted May 9, 2017 Mounting by UUID may be a solution for changing mmc device numbers. 1 Link to comment Share on other sites More sharing options...
