NanoPi NEO AIR & CAM500B problem
Tanat
Hi all.
I install Ubuntu_xenial_default with kernel 3.4.113 and want record video from CAM500B with ov5640 image sensor.
I had edited camera section in fex file with next options:
[csi0]
vip_used                 = 1
vip_mode                 = 0
vip_dev_qty              = 1
vip_define_sensor_list   = 0
vip_csi_pck              = port:PE00<2><default><default><default>
vip_csi_mck              = port:PE01<2><default><default><default>
vip_csi_hsync            = port:PE02<2><default><default><default>
vip_csi_vsync            = port:PE03<2><default><default><default>
vip_csi_d0               = port:PE04<2><default><default><default>
vip_csi_d1               = port:PE05<2><default><default><default>
vip_csi_d2               = port:PE06<2><default><default><default>
vip_csi_d3               = port:PE07<2><default><default><default>
vip_csi_d4               = port:PE08<2><default><default><default>
vip_csi_d5               = port:PE09<2><default><default><default>
vip_csi_d6               = port:PE10<2><default><default><default>
vip_csi_d7               = port:PE11<2><default><default><default>
vip_csi_sck              = port:PE12<2><default><default><default>
vip_csi_sda              = port:PE13<2><default><default><default>
vip_dev0_mname           = "ov5640"
vip_dev0_pos             = "rear"
vip_dev0_lane            = 4
vip_dev0_twi_id          = 2
vip_dev0_twi_addr        = 0x78
vip_dev0_isp_used        = 1
vip_dev0_fmt             = 0
vip_dev0_stby_mode       = 1
vip_dev0_vflip           = 1
vip_dev0_hflip           = 0
vip_dev0_iovdd           = ""
vip_dev0_iovdd_vol       = 2800000
vip_dev0_avdd            = ""
vip_dev0_avdd_vol        = 2800000
vip_dev0_dvdd            = ""
vip_dev0_dvdd_vol        = 1500000
vip_dev0_afvdd           = ""
vip_dev0_afvdd_vol       = 2800000
vip_dev0_power_en        =
vip_dev0_reset           = port:PE14<1><default><default><default>
vip_dev0_pwdn            = port:PE15<1><default><default><default>
vip_dev0_flash_en        =
vip_dev0_flash_mode      =
vip_dev0_af_pwdn         =
vip_dev0_act_used        = 0
vip_dev0_act_name        = "ad5820_act"
vip_dev0_act_slave       = 0x18
vip_dev1_pos = "rear"
vip_dev1_lane = 1
vip_dev1_twi_id = 0
vip_dev1_twi_addr =
vip_dev1_isp_used = 0
vip_dev1_fmt = 1
vip_dev1_stby_mode = 0
vip_dev1_vflip = 0
vip_dev1_hflip = 0
vip_dev1_iovdd = ""
vip_dev1_iovdd_vol = 2800000
vip_dev1_avdd = ""
vip_dev1_avdd_vol = 2800000
vip_dev1_dvdd = ""
vip_dev1_dvdd_vol = 1500000
vip_dev1_afvdd = ""
vip_dev1_afvdd_vol = 2800000
vip_dev1_power_en =
vip_dev1_reset =
vip_dev1_pwdn =
vip_dev1_flash_en =
vip_dev1_flash_mode =
vip_dev1_af_pwdn =
And had added to file  /etc/modules
ov5640
vfe_v4l2
After reboot I can list video0 device in /dev
but dmesg | grep ov5640 and dmesg | grep VFE returns nothing.
And dmesg | grep OV5640 show
[    7.860317] [OV5640@lex]init_sensor - frame_rate: 0, max_win_size: 11
[    7.952205] [OV5640@lex]CSI_SUBDEV_PWR_ON!
[    8.020823] [OV5640@lex]sensor_init 0x0
[    8.065071] [OV5640@lex]CSI_SUBDEV_PWR_OFF!
Then ffmpeg -f v4l2 -s 640x480 -i /dev/video0 -r 30 -c:v mpeg4 ./test/test.avi returns error:
ioctl(VIDIOCENUMINPUT): invalid argument
/dev/video0: Invalid argument.
Please help me with this problem.
I had tried to boot without camera and dmesg | grep OV5640 displayed:
CSI_SUBDEV_PWR_ON!
sensor read rety=2
error at sensor_detect
chip found is not an target chip
CSI_SUBDEV_PWR_OFF!
And tried to boot with had connected camera then dmasg | grep OV5640 displayed next:
CSI_SUBDEV_PWR_ON!
sensor_init 0x0
CSI_SUBDEV_PWR_OFF!
Then agian I may list /dev/video0 but no access to this device
I tried to recompile ov5640 and vfe modules with DEV_DBG_EN 1
and now after commands modprobe ov5640 vfe_v4l2 I can see next:
dmesg | grep VFE
[ 1621.705770] [VFE]Welcome to Video Front End driver
[ 1621.706258] [VFE]pdev->id = 0
[ 1621.706270] [VFE]dev->mipi_sel = 0
[ 1621.706278] [VFE]dev->vip_sel = 0
[ 1621.706285] [VFE]dev->isp_sel = 0
[ 1621.712469] [VFE_WARN]vfe vpu clock is null
[ 1621.720171] [VFE]..........................vfe clk open!.......................
[ 1621.720442] [VFE]vfe_init end
[ 1621.730275] [VFE]probe_work_handle start!
[ 1621.730308] [VFE]v4l2 subdev register input_num = 0
[ 1621.730320] [VFE]vfe sensor detect start! input_num = 0
[ 1621.730337] [VFE]Find sensor name is "ov5640", i2c address is 78, type is "YUV" !
[ 1621.730350] [VFE]Sub device register "ov5640" i2c_addr = 0x78 start!
[ 1621.730366] [VFE]v4l2_device_register_subdev return 0
[ 1621.730377] [VFE]registered sensor subdev is OK!
[ 1621.730385] [VFE]Check sensor!
[ 1621.743731] [VFE]mclk on
[ 1621.860358] [VFE]mclk off
[ 1621.872420] [VFE]Sub device register "ov5640" is OK!
[ 1621.872804] [VFE]V4L2 device registered as video0
[ 1621.872843] [VFE]..........................vfe clk close!.......................
[ 1621.872866] [VFE]probe_work_handle end!
[ 1621.881727] [VFE]vfe_open
[ 1621.881754] [VFE]..........................vfe clk open!.......................
[ 1621.881798] [VFE]vfe_open ok
[ 1621.882233] [VFE]vfe_close
[ 1621.882247] [VFE]vfe select input flag = 0, s_input have not be used .
[ 1621.882269] [VFE]..........................vfe clk close!.......................
[ 1621.882304] [VFE]vfe_close end
and grep | ov5640
[ 1613.793181] [OV5640@lex]init_sensor - frame_rate: 0, max_win_size: 11
[ 1621.742431] [OV5640@lex]CSI_SUBDEV_PWR_ON!
[ 1621.810043] [OV5640@lex]sensor_init 0x0
[ 1621.848152] [OV5640@lex]write sensor in function sensor_init=OK
[ 1621.849336] [OV5640@lex]sensor_init DONE - exit
[ 1621.849347] [OV5640@lex]CSI_SUBDEV_STBY_ON!
[ 1621.849355] [OV5640@lex]sensor_s_release_af
[ 1621.860033] [OV5640@lex]disalbe oe!
Then I try to streaming video with mjpg-streamer but unsuccessful
dmesg | grep VFE and grep OV5640 shows
[ 1737.333490] [VFE]vfe_open
[ 1737.333514] [VFE]..........................vfe clk open!.......................
[ 1737.333571] [VFE]vfe_open ok
[ 1737.512792] [VFE_ERR]bsp_csi_set_fmt error at vidioc_s_fmt_vid_cap!
[ 1737.519970] [VFE]vfe_close
[ 1737.519983] [VFE]vfe select input flag = 0, s_input have not be used .
[ 1737.520063] [VFE]..........................vfe clk close!.......................
[ 1737.520102] [VFE]vfe_close end
[ 1737.333646] [OV5640@lex]sensor_s_fmt
[ 1737.333658] [OV5640@lex]capture_mode: 0 - V4L2_MODE_???
[ 1737.510072] [OV5640@lex]s_fmt set width = 640, height = 480
[ 1737.512425] [OV5640@lex]** pre_div = 3,mul = 70,sys_div = 1,pll_rdiv = 2,sclk_rdiv = 2
[ 1737.512439] [OV5640@lex]read pclk = 56000000
[ 1737.512452] [OV5640@lex]pv_fps(30) = pv_pclk(56000000) / ((vts_extra(0) + vts(984)) * hts(1896))
[ 1737.512465] [OV5640@lex]pv fps = 30 - ulres = 30
Please somebody help :(
