Disable u-boot serial console
I'm testing with bananapi m1 plus(ARMBIAN 5.31 stable Debian GNU/Linux 8 jessie 4.11.6-sunxi)
I want to remove booting output both in the lcd screen and the serial console(because I am using the ttys0 for other purpose), so changed /boot/boot.cmd.
I found these two line,
if test "${console}" = "display" || test "${console}" = "both"; then setenv consoleargs "console=tty1"; fi
if test "${console}" = "serial" || test "${console}" = "both"; then setenv consoleargs "${consoleargs} console=ttyS0, 115200"; fi
and changed it with those two lines below.
if test "${console}" = "display" || test "${console}" = "both"; then setenv consoleargs "console=tty3"; fi
if test "${console}" = "serial" || test "${console}" = "both"; then setenv consoleargs "console=tty3"; fi
I was able to remove booting output after kernel, but I wasn't for the u-boot booting output.
I also tried setenv stdout from serial,vga to vga. By this, I could remove some part of the booting output in the serial console, but I still have this in the serial console.
U-Boot SPL 2017.05-armbian (Jun 15 2017 - 02:10:40)
DRAM: 1024 MiB
CPU: 912000000Hz, AXI/AHB/APB: 3/2/2
Trying to boot from MMC1
U-Boot 2017.05-armbian (Jun 15 2017 - 02:10:40 +0200) Allwinner Technology
CPU:   Allwinner A20 (SUN7I)
Model: LeMaker Banana Pi
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0
HDMI connected: Setting up a 800x480 dvi console (overscan 0x0)
Error: no valid bmp image at 66000000
In:    serial
Out:   vga
Err:   vga
U
I want to also get rid of this. I tried searching in the web about this, and found that I should set these and compile the kernel and make patch
CONFIG_SILENT_CONSOLE
CONFIG_SYS_DEVICE_NULLDEV
CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC
http://developer.toradex.com/knowledge-base/how-to-disable-enable-debug-messages-in-linux
However, I cannot find which file I should insert those three lines to.
Can anybody help me how to disable u-boot serial console output?
Thanks,
Igor,
Thanks for the reply. The problem is I want to remove both the screen message and the serial console message from ttyS0. With this patch it seems that there still be a serial console message. I think the message below should be removed from u-boot.
DRAM: 1024 MiB
I2C:   ready
DRAM:  1 GiB
In:    serial
Out:   vga
Err:   vga
U
Try this :
Spoiler
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h
--- a/include/configs/sunxi-common.h
+++ b/include/configs/sunxi-common.h
@@ -487,8 +487,8 @@ extern int soft_i2c_gpio_scl;
 #ifdef CONFIG_VIDEO
 #define CONSOLE_STDOUT_SETTINGS \
-	"stdout=serial,vga\0" \
-	"stderr=serial,vga\0"
+	"stdout=\0" \
+	"stderr=\0"
 #else
 	"stdout=serial\0" \
I'm in the same situation, I was able to hide all the boot messages after u-boot via settings in armbianEnv.txt.
Then I copied the SD to eMMC (faced this issue so I had to changed the boot script and regenerate) and updated the bootloader via nand-sata-install and now I have a verbose u-boot...
How should I apply the patch mentioned above ? Compile u-boot ? Any guidance on how to proceed ?
Thanks in advance for your help guys, much appreciated
OrangepiPC+ / 5.73 Jessie Legacy (yes, I know it's old but I need 'advanced' graphic control)
How to disable the Serial Console log in LCD during the U-Boot stage?
I am using Lime2 Rev.K board "A20-OLinuXino-LIME2-e4Gs16M" with a 7" LCD. Image used is "Armbian_5.89 with Ubuntu bionic".
There is a serial console log displayed on the LCD during the U-Boot stage which stays on for a brief period of less than 5 seconds.
Quote
Printenv:: (only selected outputs..)
console=ttyS0,115200
lcd_olinuxino=7859
monitor=lcd
serial#=00007f98
stdout=serial,vga
Anyone know how to completely disable console output for ttyS2 on RK3328?
Are there also getty services using it by default?
When I go to /dev there are only files for ttyS0, ttyS1 & ttyS3.
I need to have console completely disabled for ttyS2 since I need to use bluetooth over ttyS2.
Bluetooth chip is a RTL8723DS that is sdio + uart.
When Armbian for RK3328 is build, it shows this message.
How to stop it from enabling ttyS2?
o.k. ] Enabling serial console [ ttyS2 ]
