B.K.O. Posted June 29, 2017 Share Posted June 29, 2017 I'm a little out of ideas what is rong ? My OPiPC is functioning well with all 12v 19v and 24v + converter to 5v but OPi+2E sometimes flickers red led, one time functioned but mostly dosen't. Clearly I'm using methode 2 https://de.aliexpress.com/item/Hot-POE-Cable-Passive-Power-Over-Ethernet-Adapter-Cable-POE-Splitter-Injector-Power-Supply-Module-12/32695459204.html? https://de.aliexpress.com/item/New-Banana-Pi-M2-USB-Switch-Cable-USB-Wire-To-DC-Port-Charging-Switch-Cable-For/32521915580.html? https://de.aliexpress.com/item/Fine-6-24V-12V-24V-to-5V-3A-CAR-USB-Charger-Module-DC-Buck-step-down/32807024340.html? https://de.aliexpress.com/item/Free-Shipping-New-Arrival-DC-6V-40V-To-5V-3A-Double-USB-Charge-DC-DC-Step/32728305031.html? if im not over POE OPi+2E functions with both converters Link to comment Share on other sites More sharing options...
tkaiser Posted June 29, 2017 Share Posted June 29, 2017 1 hour ago, B.K.O. said: Clearly I'm using methode 2 Clearly you're off-topic here since this is about 'internal' PoE functionality with OPi Zero. Your external step-down converter + PoE adventures should go into 'SD card and power issues' forum (can a moderator please split the subthread off? 'Powering issues with external PoE splitter') I would believe item 2 of your list is the culprit responsible for a huge voltage drop. You can measure on OPi PC and Plus 2E on GPIO header pins 2/4 (5V, most probably in your case more likely 4.6V or below) and 6 (GND). In case you measure low voltages, then you can adjust the step-down converter to a higher voltage but should two measurements: the first idle, the second with 'stress -c 8' running. If values differ you need to replace one component and replace it with something showing less resistance (most probably the switch cable, at least I had issues with such a cable) Link to comment Share on other sites More sharing options...
chwe Posted July 31, 2017 Share Posted July 31, 2017 53 minutes ago, arendat said: My problem is similar, did the advice helped? Pls answer Did you test it by yourself and it didn't helped? It's obvious that underpowering leads in unstable armbian. We just made a subforum to collect this underpowering/unstable armbian questions. Just mesure the voltage on the GPIO header. Just measure the voltage on the GPIO header, share your voltage and people might answer if this is enough. Link to comment Share on other sites More sharing options...
RagnerBG Posted August 1, 2017 Share Posted August 1, 2017 OPi+2E is more power hungry than OPiPC and most of other OPI-s probably. It have more peripherals, but the main reason for hangs, as i noticed, is built-in wifi module. It usually freeze when wifi is turned on and try to connect, no matter the OS (Armbian, OpenElec, Android), if the power source is not good enough. In my case this is USB ports of SmartTV and PC, even 3.0 sometimes (i know it's a bad idea, but works well with OPiPC in ports, marked 1A at least). In this case, i think tkaiser is right and the main problem is this USB to DC cable with button. Even if the measurements show solid 5V (as in my cases), this means nothing if the device is not stable. Most of multimeters can't catch periodic micro drops in V of impulse power supplies. Link to comment Share on other sites More sharing options...
poepower Posted September 28, 2018 Share Posted September 28, 2018 On 6/29/2017 at 11:27 PM, B.K.O. said: I'm a little out of ideas what is rong ? My OPiPC is functioning well with all 12v 19v and 24v + converter to 5v but OPi+2E sometimes flickers red led, one time functioned but mostly dosen't. Clearly I'm using methode 2 https://de.aliexpress.com/item/Hot-POE-Cable-Passive-Power-Over-Ethernet-Adapter-Cable-POE-Splitter-Injector-Power-Supply-Module-12/32695459204.html? https://de.aliexpress.com/item/New-Banana-Pi-M2-USB-Switch-Cable-USB-Wire-To-DC-Port-Charging-Switch-Cable-For/32521915580.html? https://de.aliexpress.com/item/Fine-6-24V-12V-24V-to-5V-3A-CAR-USB-Charger-Module-DC-Buck-step-down/32807024340.html? https://de.aliexpress.com/item/Free-Shipping-New-Arrival-DC-6V-40V-To-5V-3A-Double-USB-Charge-DC-DC-Step/32728305031.html? if im not over POE OPi+2E functions with both converters I'd believe item 2 of the list is the culprit responsible for a massive voltage drop. You could calculate on OPi PC and Plus 2E on GPIO header pins 2/4 (5V, most likely in your case more likely 4.6V or below) and 6 (GND). Link to comment Share on other sites More sharing options...
