deb2016 Posted November 24, 2024 Posted November 24, 2024 I installed the latest stable (and updated) debian image on clearfogpro from SD card. I then chose "boot from SD, install on SATA ..." as I have a M.2 SSD card which is viewed as /dev/sda device, with the "armbian-install" utility. However, this one does not offer to boot directly from M2. SSD, which should be possible as there is a DIP switch configuration for it. I tried to burn the iso image on sata with "dd" and then, to "dd" the u-boot.sata on "/dev/sda" (bs=512 seek=1). When switching to sata boot (dip switch), it begins well, the sata device is found, but nothing happens after, the iso image is not loaded. How can I boot directly from M.2 SSD with system installed on it ? 0 Quote
blood Posted January 10 Posted January 10 I have a Clearfog Base but not a Pro - but I utilized the instructions here and have been running Armbian off a SATA m.2 stick for years now without issue. When I attach to the USB console and boot I begin to get console output immediately, first from the firmware, then from uBoot, and finally from the kernel and into userland. Can you share the end of the output that you see? Does it go as far as "Starting Kernel" (or similar, I forget exactly what it says). My first suspicion is that the img (not an ISO per se but I know what you mean) wasn't written to the block device in the manner the board is expecting and so the handoff to the boot loader isn't happening. Do you have a SATA m.2 to USB adapter that you could use to write the image to the media from another system? I'm pretty sure when I set mine up that's what I did rather than writing the image to the SATA drive from within the Clearfog itself (that was booted off SD). 0 Quote
blood Posted January 20 Posted January 20 I set about to update my clearfog base last night because it was a few Debian versions behind and I wanted to use some of the stuff in bookworm - and upon flashing the latest image along with the uboot sata, my board now will not boot at all when using this image - either when using it via an m.2 SATA drive or a microsd - and if I go back to my old SATA stick and boot off it, it continues to boot fine. Something seems to indeed be broken in the modern images! As it never seems to get past uboot, I'm going to try grabbing the uboot binary from my old install and see if it works any better. 0 Quote
blood Posted January 20 Posted January 20 When I attempt to boot I get: U-Boot SPL 2018.01-armbian (Feb 17 2023 - 23:33:49) High speed PHY - Version: 2.0 Detected Device ID 6828 board SerDes lanes topology details: | Lane # | Speed | Type | -------------------------------- | 0 | 3 | SATA0 | | 1 | 0 | SGMII1 | | 2 | 5 | PCIe1 | | 3 | 5 | USB3 HOST1 | | 4 | 5 | USB3 HOST0 | | 5 | 0 | SGMII2 | -------------------------------- PCIe, Idx 1: detected no link High speed PHY - Ended Successfully DDR3 Training Sequence - Ver TIP-1.29.0 DDR3 Training Sequence - Switching XBAR Window to FastPath Window DDR3 Training Sequence - Ended Successfully Trying to boot from SATA AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode Found 1 device(s). U-Boot 2018.01-armbian (Feb 17 2023 - 23:33:49 +0000) SoC: MV88F6828-A0 at 1600 MHz DRAM: 1 GiB (800 MHz, 32-bit, ECC not enabled) MMC: mv_sdh: 0 AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode Found 1 device(s). *** Warning - bad CRC, using default environment Model: SolidRun Clearfog Board: SolidRun ClearFog Base SCSI: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode Net: Warning: ethernet@70000 (eth1) using random MAC address - d2:63:b4:30:b5:09 eth1: ethernet@70000 Warning: ethernet@30000 (eth2) using incremented MAC address - d2:63:b4:30:b5:0a , eth2: ethernet@30000 Warning: ethernet@34000 (eth3) using incremented MAC address - d2:63:b4:30:b5:0b , eth3: ethernet@34000 Hit any key to stop autoboot: 0 scanning bus for devices... Device 0: (0:0) Vendor: ATA Prod.: TS120GMTS420S Rev: V011 Type: Hard Disk Capacity: 114473.4 MB = 111.7 GB (234441648 x 512) Found 1 device(s). Device 0: (0:0) Vendor: ATA Prod.: TS120GMTS420S Rev: V011 Type: Hard Disk Capacity: 114473.4 MB = 111.7 GB (234441648 x 512) ... is now current device Scanning scsi 0:1... Found U-Boot script /boot/boot.scr 2996 bytes read in 82 ms (35.2 KiB/s) ## Executing script at 03000000 Boot script loaded from scsi 191 bytes read in 80 ms (2 KiB/s) 26870 bytes read in 143 ms (182.6 KiB/s) 10631265 bytes read in 295 ms (34.4 MiB/s) 8551104 bytes read in 253 ms (32.2 MiB/s) Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... Card did not respond to voltage select! mmc_init: -95, time 19 starting USB... USB0: Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: device type unknown ... is now current device ** Bad device usb 0 ** ** Bad device usb 0 ** ethernet@70000 Waiting for PHY auto negotiation to complete................. TIMEOUT ! ethernet@70000: No link. ethernet@30000 Waiting for PHY auto negotiation to complete................. TIMEOUT ! ethernet@30000: No link. ethernet@34000 Waiting for PHY auto negotiation to complete. After this, the similar messages repeat for a while trying to network boot. What sticks out to me here is: Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... I don't know this well, but it seems like u-boot is trying to load the initial ramdisk before the kernel is started. On my functioning disk (based on an old Buster install) rather than those errors I get messages about the ramdisk, device tree, and then the kernel loads. So I suspect something is broken with the initrd. 0 Quote
blood Posted January 20 Posted January 20 I should have mentioned, the above output came from using an old u-boot.sata that I rescued off my old install. When I used the one included in the new build, I didn't get any console output from uboot at all. I have since reverted to an older image from the archive (Armbian_23.11.1_Clearfogbase_bookworm_current_6.1.63.img). Using its u-boot.sata I also got no console output, but with my older one, I have been able to at least get this image to boot! So there's a recipe at least for getting something somewhat modern (if you consider an image that's over a year old "modern" - and from where I'm coming from I do!). Do I dare try to move its kernel forward? Or should I just settle with what I have and move along... I'm attaching a copy of the older u-boot.sata file that is working for me in case it's useful to anyone else. Oh, who am I kidding - this is a really old board and nobody is using them now. u-boot.sata 0 Quote
blood Posted January 20 Posted January 20 So I don't know exactly what is wrong with the latest posted clearfog images (other than the u-boot.sata binary doesn't work), but after using the process I detailed above, I just let apt upgrade everything - including the kernel to 6.6.63-current-mvebu) and so far everything seems to be working after a reboot. I might get this back into production as my home router today after all once I run a few more smoke tests! 0 Quote
blood Posted April 10 Posted April 10 As seen in some other threads for mvebu-based boards (helios4, etc), the current images for clearfog base (and I assume) pro are broken in that it appears the initrd can't be loaded. I also haven't been able to use the u-boot for SATA booting in a while. I have been hitting both of these issues for a while and as I showed above in the past you can still flash old images, use an even older u-boot binary for SATA and get up and running - but now (and I'm not sure when it started) any upgrade to current packages renders the system unbootable. It's unfortunate, but it seems these boards are old enough that their support is rotting (and to be clear, I'm not blaming Armbian for this). While this hardware is old it's plenty performant as my home firewall to the Internet and so I don't want to replace it - but it's maybe time to start looking for a replacement anyways. Just a few nights ago, I installed updates for the first time in a few months and when I rebooted it, it failed to come back up. Considering this is my router, that really cramped my style! But I got another box in place in this role and since then I've poked at this a bit. It's easy to reproduce: Flash a copy of Armbian_23.11.1_Clearfogbase_bookworm_current_6.1.63.img to an m.2 SATA drive (if this isn't available any more, ping me and I can post it somewhere). Write a copy of the old u-boot for SATA support to the beginning of the drive (dd if=u-boot.sata of=/dev/foobarbaz bs=512 seek=1) Put the m.2 SATA drive into your clearfog and configure the jumpers to boot off SATA - see here. Plug in ethernet and micro USB to another system and attach to it for console (picocom -b 115200 /dev/ttyUSBFOOBARBAZ) Power it on and hopefully observe it boot - then go through the initial setup Update and upgrade packages (apt update && apt upgrade) Reboot - and watch it stall before it gets anywhere The trick then is to put a "hold" on the kernel and firmware packages before doing #6. The latest kernel I've been able to get running stable is 6.6.63-current-mvebu (installed via armbian-config). for pkg in armbian-bsp-cli-clearfogbase-current armbian-firmware linux-dtb-current-mvebu linux-image-current-mvebu linux-u-boot-clearfogbase-current; do echo "$pkg hold" | dpkg --set-selections done Then you should be able to upgrade everything else and reboot and have it not break. That list of packages is likely larger than it really needs to be, but after rebuilding my drive a couple of times I decided to not take any chances. The rest is either pure Debian or at least things that shouldn't break due to bit rot. If I have more time I'll try to actually dig in and figure out what's wrong with the ramdisk (or whatever it is that causes this) and submit a fix, but this is better than nothing for now. 1 Quote
blood Posted April 28 Posted April 28 I suspect I'm talking to myself here, but for anyone with a clearfog base or pro system, by following similar steps to what was outlined here I've been able to get my clearfog base system to boot and operate correctly using the latest kernel image and other packages. Additionally, as I covered previously in this thread, I had been dragging an old sata-capable u-boot binary around but I installed u-boot to SPI using armbian-config and after doing that I don't think it's necessary and longer (and maybe hasn't been for a very long time...) to fuss with installing it to the boot media. Just change the jumpers to use SPI and let it go. To use the latest kernels, there's an issue where the kernel and initrd grew and overlap now which caused the breakage. Add this to /boot/armbianEnv.txt before installing the new kernel: Quote ramdisk_addr_r=3000000 script_addr_r=4000000 pxefile_addr_r=4100000 I then unheld all the packages and rebooted and now I'm on all current software. 0 Quote
Vodalex Posted May 2 Posted May 2 Thank you for your contribution! I will try this on my Kobol HELIOS 4.. 0 Quote
laibsch Posted Wednesday at 03:47 AM Posted Wednesday at 03:47 AM @blood Thank you for documenting your progress. I recently got hold of a Helios4 and also want to get it to boot directly off SATA. I'm currently working on getting uboot for the Helios4 updated in Armbian. Let's collaborate and maybe do the same for the Clearfog? 0 Quote
blood Posted Wednesday at 08:30 PM Posted Wednesday at 08:30 PM @laibsch - I have my clearfog booting directly off SATA at this point. I achieved this a while ago by writing a "special" uboot binary to the very start of my SATA SSD, and later by writing an enhanced uboot image via `armbian-config` to SPI flash which doesn't require anything else. It's a very simple configuration now and much preferred over the old way. Good luck keeping your system operational and running well! 0 Quote
