bulletim3 Posted August 6, 2017 Share Posted August 6, 2017 Hello. Is there a way of resetting the USB subsystem in Armbian for Orange Pi Zero? I don't want to unplug and plug a USB device or reboot the system just to reset the plugged USB devices. The above is doable on a PC running Ubuntu with something like this: $: cd /sys/bus/pci/drivers/ehci_hcd $: ls 0000:00:14.0 bind module new_id remove_id uevent unbind $: echo -n "0000:00:14.0" > unbind $: echo -n "0000:00:14.0" > bind Wondering if something similar (I don't really care if the solution is not similar) is doable on Armbian for OPIZ. Cheers! Link to comment Share on other sites More sharing options...
kris777 Posted August 6, 2017 Share Posted August 6, 2017 Maybe this way for raspberry pi will be helpful .....(raspbian) How do I reset a USB device using a script? https://gist.github.com/x2q/5124616 Link to comment Share on other sites More sharing options...
