Orange Pi R1
tkaiser
3 minutes ago, thanh_tan said:
Can this board be used as wifi marketing device?
Why not. It has onboard WiFi which can be configured as AP. It's not very powerful one and can't handle many clients at once.
spotted the first Orange Pi R1 at eBay (but only 3 x2 in auction).... dont know why so less :(
Orange Pi R1 H2 Quad Core Cortex-A7 Open-source 256MB DDR3 GPU/600MHz RJ45 Board
Item numbers:
382244596378
362116564021
311974248848
On 20.10.2017 at 3:51 PM, DreamDreams said:
I booted my R1 with Orange Pi Zero Ubuntu image. Both ethernet ports work, no wifi though
As expected. To get at least some information inserted into this thread what about posting output from 'armbianmonitor -u'? :)
I've not checked recently but if there's still no schematics released on orangepi.org but there are OS images available claiming working Wi-Fi then anyone of you should download such an OS image, see whether Wi-Fi works and if that's the case we need script.bin ('apt install sunxi-tools' then bin2fex is available) and the output of the following uploaded to an online pasteboard service:
lsmod
dmesg
iwconfig
It's only about the mmc1/wlan nodes in sys_config.fex (script.bin). As soon as they're known and adapted loading the 8189es driver should work (I guess you already tried out a 'modprobe 8189es' already?)
Edit: Hmm... I checked for this with an old OS image from Xunlong already half a year ago:
So does 'modprobe 8189es' work or not? In case someone tried out please output of 'iwconfig' afterwards and armbianmonitor -u again.
lsmod
dmesg
iwconfig
It's only about the mmc1/wlan nodes in sys_config.fex (script.bin). As soon as they're known and adaptec loading the 8189es driver should work (I guess you already tried out a 'modprobe 8189es' already?)
7
root@orangepizero:~# modprobe 8189es
modprobe: FATAL: Module 8189es not found in directory /lib/modules/4.13.8-sunxi
EDIT: there is an 8189fs but no 8189es module
root@orangepizero:~# iwconfig
enxc0742bfffc8c  no wireless extensions.
eth0      no wireless extensions.
lo        no wireless extensions.
http://sprunge.us/ARKT
There is an official OS image that has a working wifi:
https://mega.nz/#F!VG4l1aTL!JNWI52f-5NT0pyijQ-50Lw!VHpGHLbY
Boring. Why not using an Armbian image where 8189es is known to work (legacy)?
So someone can boot this image on the device, extract contents of script.bin and upload that and output from dmesg, lsmod and iwconfig to an online pasteboard service.
Tried, no wifi.
Will do
On 22.10.2017 at 2:00 PM, tkaiser said:
I forgot to mention that of course contents of /etc/modules have to be adjusted prior to such tests (at least removing the xradio occurences there).
@tkaiser @the-ice @Ivan Voronov because my OrangePi R1 did arrive today I did download today
the legacy xenial ubuntu and did a apt update/upgrade and cleared the 2 xradio entrys in /etc/modules:
root@orangepirone:/etc# more modules
#w1-sunxi
#w1-gpio
#w1-therm
#sunxi-cir
g_serial
Also deleted the entry for xradio in /etc/modprobe.d/ = xradio_wlan.conf
After a reboot the mod 8189es is loaded automatically (the OPi R1 did this already before) :
root@orangepirone:~# lsmod
Module                  Size  Used by
8189es               1076034  0
pcf8591                 3363  0
bmp085                  3487  0
cdc_ether               3679  0
usbnet                 14096  1 cdc_ether
g_serial               27617  2
btrfs                 712409  0
but no WiFi :(
A short Google-search did tell me that : RTL8189ftv is corresponding to 8189fs.ko, while RTL8189etv isc orresponding to 8189es.ko
(in https://de.scribd.com/document/356867489/OrangePi-Win-win-Plus-A64-User-Manual-v0-9-1 )
So the 8189es is WRONG for the RTL8189ftv on the OPi R1 Mainboard.
A short test of "modprobe 8189fs":
Module                  Size  Used by
8189fs               1050451  0
8189es               1076034  0
pcf8591                 3363  0
bmp085                  3487  0
cdc_ether               3679  0
g_serial               27617  2
btrfs                 712409  0
8189fs loaded successfully - AND some time before I did configure via nmtui  a WiFi-Connection I did get instantly my wlan0 with the configured address in ifconfig :)
root@orangepirone:~# ifconfig
enxc0742bffe8ff Link encap:Ethernet  HWaddr c0:74:2b:ff:e8:ff
          inet addr:192.168.6.151  Bcast:192.168.6.255  Mask:255.255.255.0
          inet6 addr: fe80::c274:2bff:feff:e8ff/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1301 errors:0 dropped:0 overruns:0 frame:0
          TX packets:854 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:118959 (118.9 KB)  TX bytes:133607 (133.6 KB)
eth0      Link encap:Ethernet  HWaddr e2:fc:56:2f:d5:dc
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:510 (510.0 B)
          Interrupt:114
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:76 errors:0 dropped:0 overruns:0 frame:0
          TX packets:76 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:6030 (6.0 KB)  TX bytes:6030 (6.0 KB)
wlan0     Link encap:Ethernet  HWaddr 08:ea:40:7c:02:ad
          inet addr:192.168.6.101  Bcast:192.168.6.101  Mask:255.255.255.255
          inet6 addr: fe80::aea:40ff:fe7c:2ad/64 Scope:Link
          RX packets:654 errors:0 dropped:2 overruns:0 frame:0
          TX packets:31 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:107527 (107.5 KB)  TX bytes:2689 (2.6 KB)
root@orangepirone:~# iwconfig
enxc0742bffe8ff  no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:"My_SSID"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:2.462 GHz  Access Point: C0:25:E9:44:71:68
          Bit Rate:72.2 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Power Management:off
          Link Quality=100/100  Signal level=71/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
but now I did try to unload 8189es via
modprobe -r 8189es
Did work, BUT then wlan0 disappears :(
In this moment it looks like to me that 8189fs.ko will only work if 8189es.ko is loaded (which armbian did automatically).
After reloading 8189es with
modprobe 8189es
wlan0 re-appears and is visible in ifconfig
For Information about this installation:
root@orangepirone:~# armbianmonitor -u
/var/log/armhwinfo.log has been uploaded to http://sprunge.us/QLbe
and a dmesg as attachment :)
dmesg_OPi_R1.txt
After successfully having wlan0 in legacy kernel (with using 8189es and 8189fs) I did take a look at
Armbian_5.34.171104_Orangepizero_Ubuntu_xenial_next_4.13.11
This 4.13.11 hasnt loaded xradio and did modprobe 8189fs fine:
root@orangepizero:/rtl8189ES_linux# lsmod
Module                  Size  Used by
8189fs                802816  0
but there is no 8189es. So I couldnt test if the combination of 8189es and 8189fs does work for the next kernel and wlan0.
So I did take a look at @y52s thread
and did try to compile the module 8189es on the next kernel:
armbian-config -> install kernel headers
exit
root@orangepizero:~# cd /usr/src/linux-headers-4.13.11-sunxi
root@orangepizero:/usr/src/linux-headers-4.13.11-sunxi# make scripts
 CHK     scripts/mod/devicetable-offsets.h
root@orangepizero:/usr/src/linux-headers-4.13.11-sunxi# cd /
root@orangepizero:~# git clone https://github.com/jwrdegoede/rtl8189ES_linux
root@orangepizero:/usr/src/linux-headers-4.13.11-sunxi# cd /rtl8189ES_linux/
root@orangepizero:/rtl8189ES_linux# make ARCH=arm CROSS_COMPILE= -C /usr/src/linux-headers-4.13.11-sunxi M=/rtl8189ES_linux
make: Entering directory '/usr/src/linux-headers-4.13.11-sunxi'
  Building modules, stage 2.
  MODPOST 0 modules
make: Leaving directory '/usr/src/linux-headers-4.13.11-sunxi'
But there is no module generated/compiled :(
Iam wondering about only ONE line after the "make script" in the linux-header directory because at the other thread there was many more line output:
root@orangepiplus:/usr/src/linux-headers-3.4.110-sun8i# make scripts
  CC      scripts/mod/empty.o
  HOSTCC  scripts/mod/mk_elfconfig
  MKELF   scripts/mod/elfconfig.h
  HOSTCC  scripts/mod/file2alias.o
  HOSTCC  scripts/mod/modpost.o
  HOSTCC  scripts/mod/sumversion.o
  HOSTLD  scripts/mod/modpost
  HOSTCC  scripts/kallsyms
  HOSTCC  scripts/conmakehash
The next-kernel seems to produce less heat than the legacy kernel :)
As information:
root@orangepizero:/rtl8189ES_linux# armbianmonitor -u
/var/log/armhwinfo.log has been uploaded to http://sprunge.us/LQbY
Can you try the following please on the image with legacy kernel and report back:
echo 'blacklist 8189es' >/etc/modprobe.d/blacklist-8189es.conf
update-initramfs -u
reboot
update-initramfs -u
reboot
The same as I did wrote yesterday... OK when blacklisted the module 8189es wouldnt be loaded, but after a
modprobe 8189fs only the module is loaded and I couldnt see wlan0 with ifconfig:
Module                  Size  Used by
8189fs               1050451  0
pcf8591                 3363  0
bmp085                  3487  0
cdc_ether               3679  0
g_serial               27617  2
btrfs                 712409  0
when loading 8189es "in top of 8189fs" I could see my wlan0 - so neither in legacy nor in next kernel 8189fs as a single module does enable wlan0:
root@orangepirone:~# modprobe 8189es
Module                  Size  Used by
8189es               1076034  0
8189fs               1050451  0
pcf8591                 3363  0
bmp085                  3487  0
cdc_ether               3679  0
g_serial               27617  2
btrfs                 712409  0
wlan0     IEEE 802.11bgn  ESSID:"MySSID"  Nickname:"<WIFI@REALTEK>"
          Link Quality=97/100  Signal level=71/100  Noise level=0/100
Ok, let's stop (I neither understand what you're doing now either on an 'orangepione' or using the image for this board nor do I understand why you claim 8189es is wrong and still try to load the module).
None of us devs has this board yet (Xunlong for whatever reasons never sent out the promised dev samples), there are no schematics that match reality released, I assumed it would be 8189ETV based on pictures of the board, you're the first user having the hardware in his hands pointing out that it's 8189FTV in reality (true?).
Edit: Realized that it reads 'orangepirone' and not 'orangepione' -- though still a waste of time...
... pointing out that it's 8189FTV in reality (true?).
OK - I did think its a 8189FTV because when I used my magnifying glass I only could read 8189FTV (not seeing the bottom line of the E) AND
on the Orange Pi R1 product page they also wrote 8189FTV ( Onboard WIFI Realtek RTL8189FTV, IEEE 802.11 b/g/n):
http://www.orangepi.org/OrangePiR1/
and as third I could get a wlan0 with ifconfig.
So while thinking its a 8189FTV I did read the following in a Orange Pi Handbook:
And after having module 8189es (loaded by armbian boot) I did load 8192fs and did (now I know its wrong - but surprisingly it worked) gives me a working wlan0
This in mind I did try this in the next kernel....but there is no 8189es.ko - and 8189fs did modprobe without errors.
So now the only idea I got is the difference between USB and SDIO compiled Realtek Drivers ( http://linux-sunxi.org/Wifi#Realtek )
Well, thanks for confirming that it is an 8189ETV. Then we have the following 'issues':
In other words: As already explained in this thread it's absolutely useless to try out this board with mainline kernel yet (since driver not ready) and there might be different settings needed to correctly get the Wi-Fi module running.
So we know we have no schematics that correctly describe the hardware, we know that Xunlong's own OS image correctly enables Wi-Fi, I asked several times in the meantime for a few bits of information (the f*cking fex file, lsmod and dmesg output!) and what happens instead? Not the needed information is provided but people only try what can't work as already explained. Please also note that all three links above are from this very same thread here. It's frustrating.
update-initramfs -u
reboot
Strange - the whole time I had to load 8189fs additionally to 8189es for wlan0 in legacy....but now i reverted the change above (because we have a 8189ETV Chip) and now after a reboot legacy shows me wlan0 without the 8189fs
root@orangepirone:~# dmesg|grep -i wifi
[    1.670725] [rf_pm]: set losc_out 32k out[wifi_pm]: set wl_reg_on 1 !
[    1.771327] [wifi_pm]: get wifi_sdc_id failed
[    1.871370] [wifi_pm]: wifi gpio init is OK !!
[   11.955034] [wifi_pm]: set wl_reg_on 1 !
@tkaiser Dont be frustrated -  now that I got my R1 here is fex-file, lsmod, iwconfig and dmesg from their image for the R1: ubuntu_server_xenial_H2_R1_V0.1.img
ubuntu_server_xenial_H2_R1_V0.1.img:
Linux OrangePizero 3.4.39 #2 SMP PREEMPT Fri Apr 14 14:05:55 CST 2017 armv7l armv7l armv7l GNU/Linux
(running hot like the armbian legacy)
root@OrangePizero:~# iwconfig
gre0      no wireless extensions.
tunl0     no wireless extensions.
wlan1     unassociated  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated
          Sensitivity:0/0
          Encryption key:off
          Link Quality=0/100  Signal level=0 dBm  Noise level=0 dBm
eth1      no wireless extensions.
wlan5     unassociated  Nickname:"<WIFI@REALTEK>"
          Sensitivity:0/0
          Encryption key:off
sit0      no wireless extensions.
ip6tnl0   no wireless extensions.
root@OrangePizero:~# lsmod
Module                  Size  Used by
r8152                  49914  0
cdc_ether               3187  0
usbnet                 14152  1 cdc_ether
sunxi_ir_rx             9150  0
gpio_sunxi              8265  0
8189es                996645  0
root@OrangePizero:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 76:92:b2:d9:2d:6d
          inet6 addr: fe80::7492:b2ff:fed9:2d6d/64 Scope:Link
          Interrupt:114
eth1      Link encap:Ethernet  HWaddr c0:74:2b:ff:e8:ff
          inet addr:192.168.6.153  Bcast:192.168.6.255  Mask:255.255.255.0
          RX packets:1253 errors:0 dropped:0 overruns:0 frame:0
          TX packets:994 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:122366 (122.3 KB)  TX bytes:133846 (133.8 KB)
          RX packets:142 errors:0 dropped:0 overruns:0 frame:0
          TX packets:142 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:11895 (11.8 KB)  TX bytes:11895 (11.8 KB)
wlan1     Link encap:Ethernet  HWaddr 0e:ea:40:7c:02:ad
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan5     Link encap:Ethernet  HWaddr 08:ea:40:7c:02:ad
root@OrangePizero:~# find / -name script.bin
/media/boot/script.bin
root@OrangePizero:/media/boot# ls
boot.scr  script.bin  System Volume Information  uImage
root@OrangePizero:/boot# ls
boot0_OPI.fex             script.bin.OPI-PC_1080p50    script.bin.OPI-PLUS_1080p60  uImage
script.bin.OPI-2_1080p50  script.bin.OPI-PC_1080p60    script.bin.OPI-PLUS_720p50   uImage_OPI-2
script.bin.OPI-2_1080p60  script.bin.OPI-PC_720p50     script.bin.OPI-PLUS_720p60   uImage_OPI-2_NO_BUDGET_COOLING
script.bin.OPI-2_720p50   script.bin.OPI-PC_720p60     u-boot_OPI-emmc.fex          uImage_OPI-PLUS
script.bin.OPI-2_720p60   script.bin.OPI-PLUS_1080p50  u-boot_OPI.fex               uImage_OPI-PLUS_NO_BUDGET_COOLING
dmesg_Opi_R1.txt
script.bin
script.fex
Here's http://kaiser-edv.de/tmp/NumpU8/Armbian_5.34_Orangepi-r1_Ubuntu_xenial_default_3.4.113.img.xz based on the fex contents from there (MD5 sum: 566d614f3bc7a0dd27e2bd848be6f5ee)
Please connect a single Ethernet cable to one of the two ports, boot it, login through network or serial console, if the image asks for a reboot (likely due to rootfs resize), then reboot and finally provide output from 'armbianmonitor -u' and iwconfig.
Please note that /etc/network/interfaces is empty on this image so you either configure everything with nmtui (recommended) or fiddle around filling this file. But at least I would be interested in results from using nmtui only, configuring both eth interfaces with static or dynamic settings and also activate Wi-Fi (if possible). Then of course 'armbianmonitor -u' and iwconfig again :)
tkaiser OPi R1 Image:
Linux orangepi 3.4.113-sun8i #13 SMP PREEMPT Sat Nov 4 07:45:43 PDT 2017 armv7l armv7l armv7l GNU/Linux
After resize-boot armbianmonitor/iwconfig:
root@orangepi:~# armbianmonitor -u
/var/log/armhwinfo.log has been uploaded to http://sprunge.us/EVRd
root@orangepi:~# iwconfig
wlan0     unassociated  Nickname:"<WIFI@REALTEK>"
          Sensitivity:0/0
          Encryption key:off
          Link Quality:0  Signal level:0  Noise level:0
after configuring the interfaces via nmtui - without problems:
/var/log/armhwinfo.log has been uploaded to http://sprunge.us/HOVb
          Link Quality=100/100  Signal level=70/100  Noise level=0/100
root@orangepi:~# ifconfig
          inet addr:192.168.6.154  Bcast:192.168.6.255  Mask:255.255.255.0
          RX packets:10302 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1086 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1316838 (1.3 MB)  TX bytes:349868 (349.8 KB)
          RX bytes:0 (0.0 B)  TX bytes:238 (238.0 B)
          Interrupt:114
          RX packets:388 errors:0 dropped:0 overruns:0 frame:0
          TX packets:388 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:95697 (95.6 KB)  TX bytes:95697 (95.6 KB)
          inet addr:192.168.6.152  Bcast:192.168.6.255  Mask:255.255.255.0
          RX packets:8559 errors:0 dropped:0 overruns:0 frame:0
          TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1553591 (1.5 MB)  TX bytes:3347 (3.3 KB)
root@orangepi:~# lsmod
Module                  Size  Used by
8189es               1075930  0
zram                    8964  4
pcf8591                 3363  0
bmp085                  3487  0
cdc_ether               3679  0
g_serial               28549  0
btrfs                 712409  0
