lpt2007 Posted August 30, 2017 Share Posted August 30, 2017 Anybody try to install emby server on armbian? I try to use this howto: LINK But I get dependecy error: Quote The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 3.0~) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. Can somebody help? Link to comment Share on other sites More sharing options...
clarkss12 Posted August 30, 2017 Share Posted August 30, 2017 I have installed Emby server on several of my arm devices running Armbian, numerous times. Just use the download section from the Emby website, and follow the instructions for the Ubuntu 14.04, and just that version has the correct mono versions. https://emby.media/linux-server.html Link to comment Share on other sites More sharing options...
lpt2007 Posted August 31, 2017 Author Share Posted August 31, 2017 (edited) Spoiler On 30.8.2017 at 5:28 PM, clarkss12 said: I have installed Emby server on several of my arm devices running Armbian, numerous times. Just use the download section from the Emby website, and follow the instructions for the Ubuntu 14.04, and just that version has the correct mono versions. https://emby.media/linux-server.html I installed armbian image with debian 8.9 not ubuntu. Will instructions work anyway? Edited January 18, 2018 by Tido added spoiler Link to comment Share on other sites More sharing options...
Igor Posted August 31, 2017 Share Posted August 31, 2017 2 hours ago, lpt2007 said: I installed armbian image with debian 8.9 not ubuntu. Will instructions work anyway? Can't tell exactly for this case, but it's possible that you will need to start with the different - correct base. Some complex installations don't just work on Debian and Ubuntu at the same time. I can come out with one example (Openmediavaoult - OMV), which works on Debian but not on Ubuntu. At least not out of the box. This is one of the reasons why we provide Debian and Ubuntu base. Link to comment Share on other sites More sharing options...
Everett Ryan Posted January 18, 2018 Share Posted January 18, 2018 I finally managed to install emby-server on Raspbian Stretch. I had kept getting the same errors. Try this as su: curl -sSL https://get.docker.com/ | sh docker run -it --rm -v /usr/local/bin:/target emby/embyserver:armv7 instl Link to comment Share on other sites More sharing options...
