darkdrgn2k Posted September 12, 2017 Share Posted September 12, 2017 Seems that USB is missing in the latest trunk pull Spoiler [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.13.0-sun50iw2 (root@YPC) (gcc version 7.1.1 20170707 (Linaro GCC 7.1-2017.08)) #2 SMP Mon Sep 11 23:11:59 EDT 2017 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Machine model: OrangePi Zero Plus2 [ 0.000000] Reserved memory: created CMA memory pool at 0x000000005c000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x000000005fffffff] [ 0.000000] NUMA: NODE_DATA [mem 0x5bfd5e80-0x5bfd797f] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000040000000-0x000000005fffffff] [ 0.000000] Normal empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x000000005fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff] [ 0.000000] On node 0 totalpages: 131072 [ 0.000000] DMA zone: 2048 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 131072 pages, LIFO batch:31 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv0.2 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] percpu: Embedded 24 pages/cpu @ffff80001bf72000 s58520 r8192 d31592 u98304 [ 0.000000] pcpu-alloc: s58520 r8192 d31592 u98304 alloc=24*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 129024 [ 0.000000] Policy zone: DMA [ 0.000000] Kernel command line: root=UUID=4b616a9e-46d6-44e3-8e50-743ef47f390a rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 panic=10 consoleblank=0 loglevel=1 ubootpart=14c4796b-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory swapaccount=1 [ 0.000000] log_buf_len individual max cpu contribution: 4096 bytes [ 0.000000] log_buf_len total cpu_extra contributions: 12288 bytes [ 0.000000] log_buf_len min size: 16384 bytes [ 0.000000] log_buf_len: 32768 bytes [ 0.000000] early log buf free: 13956(85%) [ 0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes) [ 0.000000] Memory: 424072K/524288K available (8574K kernel code, 670K rwdata, 2264K rodata, 448K init, 320K bss, 34680K reserved, 65536K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB) [ 0.000000] .text : 0xffff000008080000 - 0xffff0000088e0000 ( 8576 KB) [ 0.000000] .rodata : 0xffff0000088e0000 - 0xffff000008b20000 ( 2304 KB) [ 0.000000] .init : 0xffff000008b20000 - 0xffff000008b90000 ( 448 KB) [ 0.000000] .data : 0xffff000008b90000 - 0xffff000008c37808 ( 671 KB) [ 0.000000] .bss : 0xffff000008c37808 - 0xffff000008c87bd8 ( 321 KB) [ 0.000000] fixed : 0xffff7dfffe7fd000 - 0xffff7dfffec00000 ( 4108 KB) [ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB) B maximum) [ 0.000000] 0xffff7e0000000000 - 0xffff7e0000800000 ( 8 MB actual) [ 0.000000] memory : 0xffff800000000000 - 0xffff800020000000 ( 512 MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000131] Console: colour dummy device 80x25 [ 0.000144] console [tty1] enabled [ 0.000197] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000206] pid_max: default: 32768 minimum: 301 [ 0.000289] Security Framework initialized [ 0.000297] AppArmor: AppArmor disabled by boot time parameter [ 0.000664] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.000848] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes) [ 0.000872] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes) [ 0.000888] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes) [ 0.002001] ASID allocator initialised with 65536 entries [ 0.002063] Hierarchical SRCU implementation. [ 0.002425] smp: Bringing up secondary CPUs ... [ 0.003509] Detected VIPT I-cache on CPU1 [ 0.003563] CPU1: Booted secondary processor [410fd034] [ 0.004277] Detected VIPT I-cache on CPU2 [ 0.004303] CPU2: Booted secondary processor [410fd034] [ 0.004963] Detected VIPT I-cache on CPU3 [ 0.004988] CPU3: Booted secondary processor [410fd034] [ 0.005043] smp: Brought up 1 node, 4 CPUs [ 0.005047] SMP: Total of 4 processors activated. [ 0.005053] CPU features: detected feature: 32-bit EL0 Support [ 0.005161] CPU: All CPU(s) started at EL2 [ 0.005180] alternatives: patching kernel code [ 0.005982] devtmpfs: initialized [ 0.010156] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.010205] futex hash table entries: 1024 (order: 5, 131072 bytes) [ 0.012549] xor: measuring software checksum speed [ 0.052177] 8regs : 1566.000 MB/sec [ 0.092217] 8regs_prefetch: 1396.000 MB/sec [ 0.132270] 32regs : 1925.000 MB/sec [ 0.172310] 32regs_prefetch: 1618.000 MB/sec [ 0.172314] xor: using function: 32regs (1925.000 MB/sec) [ 0.172325] pinctrl core: initialized pinctrl subsystem [ 0.173027] random: get_random_u32 called from bucket_table_alloc+0x10c/0x260 with crng_init=0 [ 0.173111] NET: Registered protocol family 16 [ 0.174054] cpuidle: using governor menu [ 0.174649] vdso: 2 pages (1 code @ ffff0000088e6000, 1 data @ ffff000008b94000) [ 0.174663] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.176687] DMA: preallocated 2048 KiB pool for atomic allocations [ 0.176740] Serial: AMBA PL011 UART driver [ 0.185280] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.252457] raid6: int64x1 gen() 281 MB/s [ 0.320496] raid6: int64x1 xor() 310 MB/s [ 0.388691] raid6: int64x2 gen() 443 MB/s [ 0.456683] raid6: int64x2 xor() 403 MB/s [ 0.524742] raid6: int64x4 gen() 703 MB/s [ 0.592821] raid6: int64x4 xor() 498 MB/s [ 0.660877] raid6: int64x8 gen() 666 MB/s [ 0.728902] raid6: int64x8 xor() 507 MB/s [ 0.797068] raid6: neonx1 gen() 490 MB/s [ 0.865089] raid6: neonx1 xor() 494 MB/s [ 0.933163] raid6: neonx2 gen() 784 MB/s [ 1.001209] raid6: neonx2 xor() 696 MB/s [ 1.069279] raid6: neonx4 gen() 1022 MB/s [ 1.137335] raid6: neonx4 xor() 799 MB/s [ 1.205411] raid6: neonx8 gen() 1072 MB/s [ 1.273462] raid6: neonx8 xor() 814 MB/s [ 1.273465] raid6: using algorithm neonx8 gen() 1072 MB/s [ 1.273467] raid6: .... xor() 814 MB/s, rmw enabled [ 1.273470] raid6: using intx1 recovery algorithm [ 1.274100] SCSI subsystem initialized [ 1.274267] usbcore: registered new interface driver usbfs [ 1.274301] usbcore: registered new interface driver hub [ 1.274348] usbcore: registered new device driver usb [ 1.274504] pps_core: LinuxPPS API ver. 1 registered [ 1.274507] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.274524] PTP clock support registered [ 1.274772] Advanced Linux Sound Architecture Driver Initialized. [ 1.275485] clocksource: Switched to clocksource arch_sys_counter [ 1.275666] VFS: Disk quotas dquot_6.6.0 [ 1.275720] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.281691] NET: Registered protocol family 2 [ 1.282214] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 1.282277] TCP bind hash table entries: 4096 (order: 4, 65536 bytes) [ 1.282365] TCP: Hash tables configured (established 4096 bind 4096) [ 1.282461] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 1.282482] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 1.282640] NET: Registered protocol family 1 [ 1.282951] RPC: Registered named UNIX socket transport module. [ 1.282954] RPC: Registered udp transport module. [ 1.282956] RPC: Registered tcp transport module. [ 1.282959] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.283136] Unpacking initramfs... [ 1.571261] Freeing initrd memory: 4880K [ 1.572400] random: fast init done [ 1.575237] audit: initializing netlink subsys (disabled) [ 1.575348] audit: type=2000 audit(1.571:1): state=initialized audit_enabled=0 res=1 [ 1.575675] workingset: timestamp_bits=44 max_order=17 bucket_order=0 [ 1.580666] zbud: loaded [ 1.582202] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.582805] NFS: Registering the id_resolver key type [ 1.582833] Key type id_resolver registered [ 1.582836] Key type id_legacy registered [ 1.582846] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.582850] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 1.583650] 9p: Installing v9fs 9p2000 file system support [ 1.588311] NET: Registered protocol family 38 [ 1.588570] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 1.588663] io scheduler noop registered [ 1.588667] io scheduler deadline registered [ 1.588787] io scheduler cfq registered (default) [ 1.588790] io scheduler mq-deadline registered [ 1.588794] io scheduler kyber registered [ 1.588827] io scheduler bfq registered [ 1.590750] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver [ 1.593142] sun50i-h5-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 1.664532] ------------[ cut here ]------------ [ 1.664554] WARNING: CPU: 0 PID: 1 at drivers/clk/sunxi-ng/ccu_common.c:41 ccu_helper_wait_for_lock.part.0+0x88/0xa0 [ 1.664557] Modules linked in: [ 1.664568] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.13.0-sun50iw2 #2 [ 1.664571] Hardware name: OrangePi Zero Plus2 (DT) [ 1.664575] task: ffff80001a910000 task.stack: ffff80001a918000 [ 1.664580] PC is at ccu_helper_wait_for_lock.part.0+0x88/0xa0 [ 1.664586] LR is at ccu_helper_wait_for_lock.part.0+0x40/0xa0 045 [ 1.664592] sp : ffff80001a91ba70 [ 1.664594] x29: ffff80001a91ba70 x28: ffff800019709d80 [ 1.664601] x27: ffff000008a76000 x26: ffff000008a79ed8 [ 1.664608] x25: ffff000008a79e30 x24: 00000000016e3600 [ 1.664614] x23: ffff000008bf0318 x22: 0000000000000001 [ 1.664621] x21: 0000000010000000 x20: 0000000062ff8b1a [ 1.664627] x19: 0000000003001100 x18: 0000000000000001 [ 1.664633] x17: 0000000000000001 x16: 0000000000000071 [ 1.664639] x15: ffffffffffffffff x14: 000000006335aa61 [ 1.664646] x13: 0000000000000000 x12: ffff80001a910100 [ 1.664652] x11: 0000000000000000 x10: 0000000000000980 [ 1.664658] x9 : ffff80001a91b910 x8 : ffff80001a9109e0 [ 1.664665] x7 : ffffffffffd227d5 x6 : 000000000f6f2a07 [ 1.664671] x5 : 00ffffffffffffff x4 : 002756cd002f5d00 [ 1.664677] x3 : 0000000000000018 x2 : 0000000000000342 [ 1.664683] x1 : 0000000029aaaaab x0 : 000000006300d293 [ 1.664691] Call trace: [ 1.664696] Exception stack(0xffff80001a91b8a0 to 0xffff80001a91b9d0) [ 1.664702] b8a0: 0000000003001100 0001000000000000 ffff80001a91ba70 ffff000008562d10 [ 1.664708] b8c0: ffff80001a91b8d0 ffff0000080d6fd4 ffff80001a91b8f0 ffff0000080d729c [ 1.664714] b8e0: ffff80001a910100 ffff80001a910000 ffff80001a91b930 ffff0000088d49c0 [ 1.664720] b900: ffff80001bf7f280 ffff80001a910000 ffff000008ba0f80 ffff000008bb9ad0 [ 1.664725] b920: ffff000008b7f000 ffff0000088d4ddc ffff80001a91b990 ffff0000088d4ddc [ 1.664731] b940: 000000006300d293 0000000029aaaaab 0000000000000342 0000000000000018 [ 1.664736] b960: 002756cd002f5d00 00ffffffffffffff 000000000f6f2a07 ffffffffffd227d5 [ 1.664742] b980: ffff80001a9109e0 ffff80001a91b910 0000000000000980 0000000000000000 [ 1.664748] b9a0: ffff80001a910100 0000000000000000 000000006335aa61 ffffffffffffffff [ 1.664752] b9c0: 0000000000000071 0000000000000001 [ 1.664757] [<ffff000008562d10>] ccu_helper_wait_for_lock.part.0+0x88/0xa0 [ 1.664763] [<ffff000008562db8>] ccu_helper_wait_for_lock+0x10/0x20 [ 1.664771] [<ffff0000085655ec>] ccu_nm_set_rate+0x194/0x200 [ 1.664780] [<ffff00000855b818>] clk_change_rate+0x1b0/0x270 [ 1.664786] [<ffff00000855b93c>] clk_core_set_rate_nolock+0x64/0xd0 [ 1.664792] [<ffff00000855b9d8>] clk_set_rate+0x30/0x50 [ 1.664797] [<ffff0000085601d4>] of_clk_set_defaults+0x1e4/0x378 [ 1.664807] [<ffff0000085f95d4>] platform_drv_probe+0x24/0xb8 [ 1.664813] [<ffff0000085f7a48>] driver_probe_device+0x228/0x2d0 [ 1.664819] [<ffff0000085f7ba8>] __driver_attach+0xb8/0xc0 [ 1.664825] [<ffff0000085f5c9c>] bus_for_each_dev+0x4c/0x98 [ 1.664831] [<ffff0000085f7370>] driver_attach+0x20/0x28 [ 1.664836] [<ffff0000085f6f6c>] bus_add_driver+0x1b4/0x220 [ 1.664842] [<ffff0000085f8538>] driver_register+0x60/0xf8 [ 1.664848] [<ffff0000085f9558>] __platform_driver_register+0x40/0x48 [ 1.664856] [<ffff000008b3f3c8>] sunxi_de2_clk_driver_init+0x18/0x20 [ 1.664864] [<ffff000008082900>] do_one_initcall+0x38/0x120 [ 1.664874] [<ffff000008b20cb8>] kernel_init_freeable+0x18c/0x230 [ 1.664880] [<ffff0000088d3b08>] kernel_init+0x10/0x100 [ 1.664885] [<ffff0000080826c0>] ret_from_fork+0x10/0x50 [ 1.664895] ---[ end trace 0dfcc846c0a987f5 ]--- [ 1.669769] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 1.670823] console [ttyS0] disabled [ 1.690956] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 16, base_baud = 1500000) is a U6_16550A [ 1.691006] console [ttyS0] enabled [ 1.691662] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 1.695827] loop: module loaded [ 1.696408] libphy: Fixed MDIO Bus: probed [ 1.696869] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.696873] ehci-platform: EHCI generic platform driver [ 1.696933] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.696943] ohci-platform: OHCI generic platform driver [ 1.697055] usbcore: registered new interface driver usb-storage [ 1.697274] mousedev: PS/2 mouse device common for all mice [ 1.697690] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0 [ 1.697695] sun6i-rtc 1f00000.rtc: RTC enabled [ 1.697725] i2c /dev entries driver [ 1.698282] thermal thermal_zone0: failed to read out thermal zone (-16) [ 1.698558] sdhci: Secure Digital Host Controller Interface driver [ 1.698561] sdhci: Copyright(c) Pierre Ossman [ 1.698580] Synopsys Designware Multimedia Card Interface Driver [ 1.699944] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 1.739625] sunxi-mmc 1c0f000.mmc: base:0xffff000009038000 irq:7 [ 1.779503] sunxi-mmc 1c11000.mmc: base:0xffff00000903c000 irq:8 [ 1.779590] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.780116] ledtrig-cpu: registered to indicate activity on CPUs [ 1.780282] hidraw: raw HID events driver (C) Jiri Kosina [ 1.780470] usbcore: registered new interface driver usbhid [ 1.780473] usbhid: USB HID core driver [ 1.780845] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.781265] NET: Registered protocol family 10 [ 1.794284] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.797130] Segment Routing with IPv6 [ 1.797212] NET: Registered protocol family 17 [ 1.797287] 8021q: 802.1Q VLAN Support v1.8 [ 1.797335] 9pnet: Installing 9P2000 support [ 1.797418] Key type dns_resolver registered [ 1.797925] mmc0: new high speed SDHC card at address 0007 [ 1.798133] registered taskstats version 1 [ 1.798235] zswap: loaded using pool lzo/zbud [ 1.798371] mmcblk0: mmc0:0007 SD32G 29.0 GiB [ 1.799289] Btrfs loaded, crc32c=crc32c-arm64-ce [ 1.799581] mmcblk0: p1 [ 1.806280] Key type encrypted registered [ 1.811112] of_cfs_init [ 1.811198] of_cfs_init: OK [ 1.811353] ALSA device list: [ 1.811356] No soundcards found. [ 1.811929] Freeing unused kernel memory: 448K [ 1.852837] mmc1: new high speed MMC card at address 0001 [ 1.853470] mmcblk1: mmc1:0001 8WPD3R 7.28 GiB [ 1.853693] mmcblk1boot0: mmc1:0001 8WPD3R partition 1 4.00 MiB [ 1.853900] mmcblk1boot1: mmc1:0001 8WPD3R partition 2 4.00 MiB [ 1.855315] mmcblk1: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 > [ 1.855344] mmcblk1: p1 size 6873088 extends beyond EOD, truncated [ 3.051311] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 3.474961] systemd[1]: System time before build time, advancing clock. [ 3.506106] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN) [ 3.506480] systemd[1]: Detected architecture arm64. [ 3.520494] systemd[1]: Set hostname to <orangepizeroplus2>. [ 3.867605] systemd[1]: Listening on fsck to fsckd communication Socket. [ 3.879808] systemd[1]: Listening on Journal Socket. [ 3.891754] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 3.903980] systemd[1]: Created slice System Slice. [ 3.917789] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 3.935858] systemd[1]: Listening on udev Kernel Socket. [ 3.949531] systemd[1]: Starting Nameserver information manager... [ 4.191769] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 4.613426] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SSFS from PID 1 [ 6.280149] random: crng init done [ 6.568597] Bluetooth: Core ver 2.22 [ 6.568700] NET: Registered protocol family 31 [ 6.568704] Bluetooth: HCI device and connection manager initialized [ 6.568726] Bluetooth: HCI socket layer initialized [ 6.568740] Bluetooth: L2CAP socket layer initialized [ 6.568774] Bluetooth: SCO socket layer initialized root@orangepizeroplus2:~# lsusb -v shows nothing Link to comment Share on other sites More sharing options...
darkdrgn2k Posted September 13, 2017 Author Share Posted September 13, 2017 I copied over the Driver Tree from the nightly build and usb came up! something def got broke there... Link to comment Share on other sites More sharing options...
darkdrgn2k Posted October 29, 2017 Author Share Posted October 29, 2017 Reinstalled using all the nightlies, all of the have missing USB Drivers Armbian_5.34.171026_Orangepizeroplus2-h5_Ubuntu_xenial_next_4.13.9.7z 2017-10-25 03:56 228.0 MB ar-ubuntu-server Armbian_5.34.171027_Orangepizeroplus2-h5_Ubuntu_xenial_next_4.13.9.7z 2017-10-26 03:57 233.7 MB ar-ubuntu-server Armbian_5.34.171028_Orangepizeroplus2-h5_Ubuntu_xenial_next_4.13.9.7z 2017-10-27 04:41 235.9 MB ar-ubuntu-server Armbian_5.34.171029_Orangepizeroplus2-h5_Ubuntu_xenial_next_4.13.10.7z Link to comment Share on other sites More sharing options...
Paco Posted October 30, 2017 Share Posted October 30, 2017 (edited) USB is disable in Driver Tree files. You can convert DTB to DTS and modify this. I don´t know why. I have edited the file and I have modified the disable references for okay of the USB and they have worked for me Edited October 30, 2017 by Paco Link to comment Share on other sites More sharing options...
tkaiser Posted October 30, 2017 Share Posted October 30, 2017 1 hour ago, Paco said: I don´t know why. https://docs.armbian.com/User-Guide_Allwinner_overlays/ Link to comment Share on other sites More sharing options...
